1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: motor record/Aerotech Automation1
Cc: "Eric J. Edwards" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 16 Dec 2024 20:41:07 +0000
Hi John,
Motor drivers usually have a “moving poll period” and an “idle poll period “.
From your timestamps it looks like moving is 0.1 second and idle is 1 second.
You might want to reduce the moving period to .02 or .01 second.
The driver may be reporting the position before it reports the moving status in the poll function.
Perhaps those should be swapped, so the final position is correct.
Sent from my iPhone
On Dec 16, 2024, at 2:29 PM, Mark Rivers via Tech-talk <[email protected]> wrote:
 Hi John,
Is this a DC motor with an encoder?
If so, then the definition of “done” is a bit fuzzy, since the controller is constantly doing feedback to minimize the error.
Controllers have different algorithms for deciding when a move is complete, e.g.
- The error is less than some threshold for a defined time period.
- The velocity is less than some threshold
- The theoretical move profile is complete.
In some cases these criteria can be adjusted by the user.
Sent from my iPhone
On Dec 16, 2024, at 2:18 PM, John Dobbins via Tech-talk <[email protected]> wrote:
All,
I don't have a lot of experience with EPICS motors , so I don't know if this issue is specific to the motor record or the Aerotech Automation1 support.
[ Alma 9,  base-7.0.6, motor - current master, Automation1 - master from October ]
If I command a move, DMOV goes high before the move is complete.  Here is an example camonitor output for the motor RRBV and DMOV
S5C1_DCM_BRG_MTR:m1.RRBV       2024-12-16 14:49:02.376122 0
S5C1_DCM_BRG_MTR:m1.RRBV       2024-12-16 14:49:03.380158 2
S5C1_DCM_BRG_MTR:m1.RRBV       2024-12-16 14:49:04.384190 -1
S5C1_DCM_BRG_MTR:m1.RRBV       2024-12-16 14:49:05.389343 1
S5C1_DCM_BRG_MTR:m1.RRBV       2024-12-16 14:49:06.394224 3
S5C1_DCM_BRG_MTR:m1.RRBV       2024-12-16 14:49:07.398213 -1
S5C1_DCM_BRG_MTR:m1.DMOV       2024-12-16 14:49:07.398213 0
S5C1_DCM_BRG_MTR:m1.RRBV       2024-12-16 14:49:07.754199 0
S5C1_DCM_BRG_MTR:m1.RRBV       2024-12-16 14:49:07.858188 17189
S5C1_DCM_BRG_MTR:m1.RRBV       2024-12-16 14:49:07.962166 105223
S5C1_DCM_BRG_MTR:m1.RRBV       2024-12-16 14:49:08.066075 263412
S5C1_DCM_BRG_MTR:m1.RRBV       2024-12-16 14:49:08.170173 441394
S5C1_DCM_BRG_MTR:m1.RRBV       2024-12-16 14:49:08.274134 622471
S5C1_DCM_BRG_MTR:m1.RRBV       2024-12-16 14:49:08.378163 776297
S5C1_DCM_BRG_MTR:m1.RRBV       2024-12-16 14:49:08.482268 854418
S5C1_DCM_BRG_MTR:m1.DMOV       2024-12-16 14:49:08.482268 1
S5C1_DCM_BRG_MTR:m1.RRBV       2024-12-16 14:49:09.487278 874672
S5C1_DCM_BRG_MTR:m1.RRBV       2024-12-16 14:49:10.491359 874669
S5C1_DCM_BRG_MTR:m1.RRBV       2024-12-16 14:49:11.495310 874668
S5C1_DCM_BRG_MTR:m1.RRBV       2024-12-16 14:49:12.499206 874666
S5C1_DCM_BRG_MTR:m1.RRBV       2024-12-16 14:49:13.503320 874668
One can see that DMOV has transitioned to one simultaneous with a position short of the final value.
What can I do about this?
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
RE: motor record/Aerotech Automation1 Pearson, Matthew via Tech-talk
motor record/Aerotech Automation1 John Dobbins via Tech-talk
Re: motor record/Aerotech Automation1 Mark Rivers via Tech-talk
Prev: Re: motor record/Aerotech Automation1 Mark Rivers via Tech-talk
Next: RE: motor record/Aerotech Automation1 Pearson, Matthew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
