1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Is there a minimum version requirement for glibc and GCC using EPICS
From: Zhibang Shen via Tech-talk <[email protected]>
To: [email protected]
Date: Sat, 21 Dec 2024 10:59:32 +0800 (GMT+08:00)
I have developed a modbus protocol based motor submodule in my own environment. It is successfully compiled and running without any issue in my development setup.
However, while migrating the module to the production environment, we encounter an error of low version library.
[hp@localhost iocLeadshine]$ ./st.cmd
../../bin/linux-x86_64/leadshine: /usr/lib64/libc.so.6: version `GLIBC_2.34' not found (required by ../../bin/linux-x86_64/leadshine)
The libc.so.6 can be found at directory /usr/lib64. It seems to be an issue that the glibc version is too low.
[hp@localhost iocLeadshine]$ strings /usr/lib64/libc.so.6 | grep GLIBC_
GLIBC_2.0
GLIBC_2.1
GLIBC_2.1.1
GLIBC_2.1.2
GLIBC_2.1.3
GLIBC_2.2
GLIBC_2.2.1
GLIBC_2.2.2
GLIBC_2.2.3
GLIBC_2.2.4
GLIBC_2.2.6
GLIBC_2.3
GLIBC_2.3.2
GLIBC_2.3.3
GLIBC_2.3.4
GLIBC_2.4
GLIBC_2.5
GLIBC_2.6
GLIBC_2.7
GLIBC_2.8
GLIBC_2.9
GLIBC_2.10
GLIBC_2.11
GLIBC_2.12
GLIBC_2.13
GLIBC_2.14
GLIBC_2.15
GLIBC_2.16
GLIBC_2.17
GLIBC_PRIVATE
Is there a minimum version requirement for glibc when using the synApps/motor package?
We tried to compile the glibc from the source. But it is prompted that the gcc version is also not appropriate.
As a reference, here are the version of the packages in the production environment.
EPICS base 3.15.9
asyn R4-41
seq 2-2-5
busy R1-7
modbus R3-2
motor R7-1
Best regards,
Zhibang
Re: Is there a minimum version requirement for glibc and GCC using EPICS Maren Purves via Tech-talk
Prev: Re: brushless dc motor MRES IS N/A Peterson, Kevin M. via Tech-talk
Next: Re: Is there a minimum version requirement for glibc and GCC using EPICS Maren Purves via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
