I added epicsThreadSleep(1.0) after creating motor controller and axes. I use camonitor to trace the VAL/RBV of motor records of three axes. I rebooted ioc nine times. Please see the following log. I noticed that axes Z1 and Z2 successfully restored the VAL/RBV from the controller every time. But the behavior of axis ThetaM is strange. Two out of nine reboots, the VAL field of ThetaM record is successfully restored. One out of nine reboots, the VAL field of ThetaM record is set to zero. Six out of nine reboots, the VAL field of ThetaM record is set to (previous value - 0.02). Why -0.02? DCM:Z1.VAL 2025-01-02 16:28:46.483683 -0.04 DCM:Z1.RBV 2025-01-02 16:28:46.483683 -0.0401 DCM:Z2.VAL 2025-01-02 20:41:47.713687 0.0657 DCM:Z2.RBV 2025-01-02 20:41:47.713687 0.0653 DCM:ThetaM.VAL 2025-01-02 16:28:50.353358 7.53376 <-- DCM:ThetaM.RBV 2025-01-02 16:28:50.353358 7.53376 ioc reboot DCM:Z1.VAL 2025-01-03 08:46:20.410653 -0.0401 DCM:Z1.RBV 2025-01-03 08:46:20.410653 -0.04 DCM:Z2.VAL 2025-01-03 08:46:20.350513 0.0653 DCM:Z2.RBV 2025-01-03 08:46:20.350513 0.0657 DCM:ThetaM.VAL 2025-01-03 08:46:20.500699 7.53376 <-- same as previous DCM:ThetaM.RBV 2025-01-03 08:46:20.500699 7.53376 ioc reboot DCM:Z1.VAL 2025-01-03 08:54:04.045355 -0.04 DCM:Z1.RBV 2025-01-03 08:54:04.045355 -0.0401 DCM:Z2.VAL 2025-01-03 08:54:03.985246 0.0657 DCM:Z2.RBV 2025-01-03 08:54:03.985246 0.0653 DCM:ThetaM.VAL 2025-01-03 08:54:05.156115 7.51376 <-- different -0.02 DCM:ThetaM.RBV 2025-01-03 08:54:05.156115 7.52741 <-- motor move DCM:ThetaM.RBV 2025-01-03 08:54:05.335235 7.52131 DCM:ThetaM.RBV 2025-01-03 08:54:05.505113 7.51621 DCM:ThetaM.RBV 2025-01-03 08:54:05.675255 7.51376 DCM:ThetaM.RBV 2025-01-03 08:54:05.845205 7.51361 DCM:ThetaM.VAL 2025-01-03 08:54:05.845205 7.51376 DCM:ThetaM.RBV 2025-01-03 08:54:05.995251 7.51356 DCM:ThetaM.RBV 2025-01-03 08:54:06.495140 7.51371 DCM:ThetaM.RBV 2025-01-03 08:54:06.795186 7.51376 DCM:ThetaM.RBV 2025-01-03 08:54:06.965241 7.51381 ioc reboot DCM:Z1.VAL 2025-01-03 09:00:47.829590 -0.0401 DCM:Z1.RBV 2025-01-03 09:00:47.829590 -0.04 DCM:Z2.VAL 2025-01-03 09:00:47.769508 0.0653 DCM:Z2.RBV 2025-01-03 09:00:47.769508 0.0657 DCM:ThetaM.VAL 2025-01-03 09:00:49.279478 7.49377 <-- different -0.01999 DCM:ThetaM.RBV 2025-01-03 09:00:49.279478 7.49611 <-- motor move DCM:ThetaM.RBV 2025-01-03 09:00:49.449660 7.49371 DCM:ThetaM.RBV 2025-01-03 09:00:49.619596 7.49351 DCM:ThetaM.VAL 2025-01-03 09:00:49.619596 7.49377 DCM:ThetaM.RBV 2025-01-03 09:00:49.939543 7.49356 DCM:ThetaM.RBV 2025-01-03 09:00:50.269661 7.49376 Manually move ThetaM to 7.553761 DCM:ThetaM.VAL 2025-01-03 09:04:05.044900 7.55378 DCM:ThetaM.VAL 2025-01-03 09:04:05.045646 7.55376 DCM:ThetaM.RBV 2025-01-03 09:04:05.371519 7.49566 DCM:ThetaM.RBV 2025-01-03 09:04:05.541574 7.50071 DCM:ThetaM.RBV 2025-01-03 09:04:05.711567 7.50711 DCM:ThetaM.RBV 2025-01-03 09:04:05.881592 7.51536 DCM:ThetaM.RBV 2025-01-03 09:04:06.061484 7.52551 DCM:ThetaM.RBV 2025-01-03 09:04:06.231575 7.53506 DCM:ThetaM.RBV 2025-01-03 09:04:06.402009 7.54296 DCM:ThetaM.RBV 2025-01-03 09:04:06.571571 7.54866 DCM:ThetaM.RBV 2025-01-03 09:04:06.741529 7.55221 DCM:ThetaM.RBV 2025-01-03 09:04:06.911574 7.55296 DCM:ThetaM.VAL 2025-01-03 09:04:06.911574 7.55376 DCM:ThetaM.RBV 2025-01-03 09:04:07.071671 7.55301 DCM:ThetaM.RBV 2025-01-03 09:04:07.241982 7.55326 DCM:ThetaM.RBV 2025-01-03 09:04:07.561637 7.55381 DCM:ThetaM.RBV 2025-01-03 09:04:07.881647 7.55346 DCM:ThetaM.RBV 2025-01-03 09:04:08.211724 7.55356 DCM:ThetaM.RBV 2025-01-03 09:04:08.531501 7.55376 ioc reboot DCM:Z1.VAL 2025-01-03 09:05:56.102804 -0.04 DCM:Z1.RBV 2025-01-03 09:05:56.102804 -0.0401 DCM:Z2.VAL 2025-01-03 09:05:56.042681 0.0657 DCM:Z2.RBV 2025-01-03 09:05:56.042681 0.0653 DCM:ThetaM.VAL 2025-01-03 09:05:56.174482 7.55376 <-- same as previous DCM:ThetaM.RBV 2025-01-03 09:05:56.174482 7.55376 <-- but motor move DCM:ThetaM.RBV 2025-01-03 09:05:57.012778 7.55206 DCM:ThetaM.RBV 2025-01-03 09:05:57.502889 7.54196 DCM:ThetaM.RBV 2025-01-03 09:05:57.822823 7.54366 DCM:ThetaM.RBV 2025-01-03 09:05:57.992678 7.54791 DCM:ThetaM.RBV 2025-01-03 09:05:58.162720 7.55171 DCM:ThetaM.RBV 2025-01-03 09:05:58.342759 7.55266 DCM:ThetaM.RBV 2025-01-03 09:05:58.492806 7.55271 DCM:ThetaM.RBV 2025-01-03 09:05:58.662711 7.55371 DCM:ThetaM.RBV 2025-01-03 09:05:58.962828 7.55376 DCM:ThetaM.RBV 2025-01-03 09:05:59.132771 7.55381 DCM:ThetaM.RBV 2025-01-03 09:06:02.762853 7.55386 ioc reboot DCM:Z1.VAL 2025-01-03 09:09:37.385148 -0.0401 DCM:Z1.RBV 2025-01-03 09:09:37.385148 -0.04 DCM:Z2.VAL 2025-01-03 09:09:37.325204 0.0653 DCM:Z2.RBV 2025-01-03 09:09:37.325204 0.0657 DCM:ThetaM.VAL 2025-01-03 09:09:38.354986 0 <-- different, zero! DCM:ThetaM.RBV 2025-01-03 09:09:38.354986 7.55181 <-- motor move DCM:ThetaM.RBV 2025-01-03 09:09:38.535008 7.54706 DCM:ThetaM.RBV 2025-01-03 09:09:38.704917 7.54026 DCM:ThetaM.RBV 2025-01-03 09:09:38.875048 7.53131 DCM:ThetaM.RBV 2025-01-03 09:09:39.045385 7.52046 DCM:ThetaM.RBV 2025-01-03 09:09:39.215134 7.50731 DCM:ThetaM.RBV 2025-01-03 09:09:39.385166 7.49361 DCM:ThetaM.RBV 2025-01-03 09:09:39.555112 7.48036 DCM:ThetaM.RBV 2025-01-03 09:09:39.725153 7.46636 DCM:ThetaM.RBV 2025-01-03 09:09:39.894942 7.45281 DCM:ThetaM.RBV 2025-01-03 09:09:40.064989 7.43961 DCM:ThetaM.RBV 2025-01-03 09:09:40.234971 7.42526 DCM:ThetaM.RBV 2025-01-03 09:09:40.405113 7.41221 DCM:ThetaM.RBV 2025-01-03 09:09:40.585072 7.39761 DCM:ThetaM.RBV 2025-01-03 09:09:40.755044 7.38401 DCM:ThetaM.RBV 2025-01-03 09:09:40.925113 7.37066 DCM:ThetaM.RBV 2025-01-03 09:09:42.095077 7.31426 DCM:ThetaM.VAL 2025-01-03 09:09:42.095077 7.31426 <-- I stop the motor. DCM:ThetaM.RBV 2025-01-03 09:09:46.705116 7.31421 ioc reboot DCM:Z1.VAL 2025-01-03 09:12:18.906995 -0.04 DCM:Z1.RBV 2025-01-03 09:12:18.906995 -0.0401 DCM:Z2.VAL 2025-01-03 09:12:18.846984 0.0657 DCM:Z2.RBV 2025-01-03 09:12:18.846984 0.0653 DCM:ThetaM.VAL 2025-01-03 09:12:21.346979 7.29431 <-- different −0.01995 DCM:ThetaM.RBV 2025-01-03 09:12:21.346979 7.29431 <-- motor move ioc reboot DCM:Z1.VAL 2025-01-03 09:18:20.230656 -0.0401 DCM:Z1.RBV 2025-01-03 09:18:20.230656 -0.04 DCM:Z2.VAL 2025-01-03 09:18:20.170608 0.0653 DCM:Z2.RBV 2025-01-03 09:18:20.170608 0.0657 DCM:ThetaM.VAL 2025-01-03 09:18:20.311337 7.27437 <-- different −0.01994 DCM:ThetaM.RBV 2025-01-03 09:18:20.311337 7.29431 <-- motor move DCM:ThetaM.RBV 2025-01-03 09:18:21.150538 7.29231 DCM:ThetaM.RBV 2025-01-03 09:18:21.320404 7.28771 DCM:ThetaM.RBV 2025-01-03 09:18:21.500407 7.28171 DCM:ThetaM.RBV 2025-01-03 09:18:21.670389 7.27681 DCM:ThetaM.RBV 2025-01-03 09:18:21.840686 7.27421 DCM:ThetaM.RBV 2025-01-03 09:18:22.010457 7.27406 DCM:ThetaM.VAL 2025-01-03 09:18:22.010457 7.27437 DCM:ThetaM.RBV 2025-01-03 09:18:22.330451 7.27421 DCM:ThetaM.RBV 2025-01-03 09:18:22.660350 7.27431 DCM:ThetaM.RBV 2025-01-03 09:18:22.960309 7.27436 DCM:ThetaM.RBV 2025-01-03 09:18:23.130896 7.27441 ioc reboot DCM:Z1.VAL 2025-01-03 09:22:00.722740 -0.04 DCM:Z1.RBV 2025-01-03 09:22:00.722740 -0.0401 DCM:Z2.VAL 2025-01-03 09:22:00.662695 0.0657 DCM:Z2.RBV 2025-01-03 09:22:00.662695 0.0653 DCM:ThetaM.VAL 2025-01-03 09:22:02.912859 7.25442 <-- different −0.01995 DCM:ThetaM.RBV 2025-01-03 09:22:02.912859 7.25441 <-- motor move ioc reboot DCM:Z1.VAL 2025-01-03 09:33:58.400417 -0.0401 DCM:Z1.RBV 2025-01-03 09:33:58.400417 -0.04 DCM:Z2.VAL 2025-01-03 09:33:58.340350 0.0653 DCM:Z2.RBV 2025-01-03 09:33:58.340350 0.0657 DCM:ThetaM.VAL 2025-01-03 09:33:59.330344 7.23447 <-- different −0.01995 DCM:ThetaM.RBV 2025-01-03 09:33:59.330344 7.25241 <-- motor move DCM:ThetaM.RBV 2025-01-03 09:33:59.500272 7.24781 DCM:ThetaM.RBV 2025-01-03 09:33:59.680584 7.24186 DCM:ThetaM.RBV 2025-01-03 09:33:59.850291 7.23701 DCM:ThetaM.RBV 2025-01-03 09:34:00.020355 7.23431 DCM:ThetaM.RBV 2025-01-03 09:34:00.190267 7.23416 DCM:ThetaM.VAL 2025-01-03 09:34:00.190267 7.23447 DCM:ThetaM.RBV 2025-01-03 09:34:00.510337 7.23431 DCM:ThetaM.RBV 2025-01-03 09:34:00.840415 7.23441 DCM:ThetaM.RBV 2025-01-03 09:34:01.140389 7.23446 DCM:ThetaM.RBV 2025-01-03 09:34:01.310255 7.23451 On Thu, Jan 2, 2025 at 11:26 AM LiangChih Chiang <yehnan174 at gmail.com> wrote:
ANJ, 03 Jan 2025 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
