I added epicsThreadSleep(1.0) after creating motor controller and axes.
I use camonitor to trace the VAL/RBV of motor records of three axes.
I rebooted ioc nine times.
Please see the following log.
I noticed that axes Z1 and Z2 successfully restored the VAL/RBV from the
controller every time.
But the behavior of axis ThetaM is strange.
Two out of nine reboots, the VAL field of ThetaM record is successfully
restored.
One out of nine reboots, the VAL field of ThetaM record is set to zero.
Six out of nine reboots, the VAL field of ThetaM record is set to
(previous value - 0.02).
Why -0.02?
DCM:Z1.VAL 2025-01-02 16:28:46.483683 -0.04
DCM:Z1.RBV 2025-01-02 16:28:46.483683 -0.0401
DCM:Z2.VAL 2025-01-02 20:41:47.713687 0.0657
DCM:Z2.RBV 2025-01-02 20:41:47.713687 0.0653
DCM:ThetaM.VAL 2025-01-02 16:28:50.353358 7.53376 <--
DCM:ThetaM.RBV 2025-01-02 16:28:50.353358 7.53376
ioc reboot
DCM:Z1.VAL 2025-01-03 08:46:20.410653 -0.0401
DCM:Z1.RBV 2025-01-03 08:46:20.410653 -0.04
DCM:Z2.VAL 2025-01-03 08:46:20.350513 0.0653
DCM:Z2.RBV 2025-01-03 08:46:20.350513 0.0657
DCM:ThetaM.VAL 2025-01-03 08:46:20.500699 7.53376 <-- same
as previous
DCM:ThetaM.RBV 2025-01-03 08:46:20.500699 7.53376
ioc reboot
DCM:Z1.VAL 2025-01-03 08:54:04.045355 -0.04
DCM:Z1.RBV 2025-01-03 08:54:04.045355 -0.0401
DCM:Z2.VAL 2025-01-03 08:54:03.985246 0.0657
DCM:Z2.RBV 2025-01-03 08:54:03.985246 0.0653
DCM:ThetaM.VAL 2025-01-03 08:54:05.156115 7.51376 <--
different -0.02
DCM:ThetaM.RBV 2025-01-03 08:54:05.156115 7.52741 <--
motor move
DCM:ThetaM.RBV 2025-01-03 08:54:05.335235 7.52131
DCM:ThetaM.RBV 2025-01-03 08:54:05.505113 7.51621
DCM:ThetaM.RBV 2025-01-03 08:54:05.675255 7.51376
DCM:ThetaM.RBV 2025-01-03 08:54:05.845205 7.51361
DCM:ThetaM.VAL 2025-01-03 08:54:05.845205 7.51376
DCM:ThetaM.RBV 2025-01-03 08:54:05.995251 7.51356
DCM:ThetaM.RBV 2025-01-03 08:54:06.495140 7.51371
DCM:ThetaM.RBV 2025-01-03 08:54:06.795186 7.51376
DCM:ThetaM.RBV 2025-01-03 08:54:06.965241 7.51381
ioc reboot
DCM:Z1.VAL 2025-01-03 09:00:47.829590 -0.0401
DCM:Z1.RBV 2025-01-03 09:00:47.829590 -0.04
DCM:Z2.VAL 2025-01-03 09:00:47.769508 0.0653
DCM:Z2.RBV 2025-01-03 09:00:47.769508 0.0657
DCM:ThetaM.VAL 2025-01-03 09:00:49.279478 7.49377 <--
different -0.01999
DCM:ThetaM.RBV 2025-01-03 09:00:49.279478 7.49611 <--
motor move
DCM:ThetaM.RBV 2025-01-03 09:00:49.449660 7.49371
DCM:ThetaM.RBV 2025-01-03 09:00:49.619596 7.49351
DCM:ThetaM.VAL 2025-01-03 09:00:49.619596 7.49377
DCM:ThetaM.RBV 2025-01-03 09:00:49.939543 7.49356
DCM:ThetaM.RBV 2025-01-03 09:00:50.269661 7.49376
Manually move ThetaM to 7.553761
DCM:ThetaM.VAL 2025-01-03 09:04:05.044900 7.55378
DCM:ThetaM.VAL 2025-01-03 09:04:05.045646 7.55376
DCM:ThetaM.RBV 2025-01-03 09:04:05.371519 7.49566
DCM:ThetaM.RBV 2025-01-03 09:04:05.541574 7.50071
DCM:ThetaM.RBV 2025-01-03 09:04:05.711567 7.50711
DCM:ThetaM.RBV 2025-01-03 09:04:05.881592 7.51536
DCM:ThetaM.RBV 2025-01-03 09:04:06.061484 7.52551
DCM:ThetaM.RBV 2025-01-03 09:04:06.231575 7.53506
DCM:ThetaM.RBV 2025-01-03 09:04:06.402009 7.54296
DCM:ThetaM.RBV 2025-01-03 09:04:06.571571 7.54866
DCM:ThetaM.RBV 2025-01-03 09:04:06.741529 7.55221
DCM:ThetaM.RBV 2025-01-03 09:04:06.911574 7.55296
DCM:ThetaM.VAL 2025-01-03 09:04:06.911574 7.55376
DCM:ThetaM.RBV 2025-01-03 09:04:07.071671 7.55301
DCM:ThetaM.RBV 2025-01-03 09:04:07.241982 7.55326
DCM:ThetaM.RBV 2025-01-03 09:04:07.561637 7.55381
DCM:ThetaM.RBV 2025-01-03 09:04:07.881647 7.55346
DCM:ThetaM.RBV 2025-01-03 09:04:08.211724 7.55356
DCM:ThetaM.RBV 2025-01-03 09:04:08.531501 7.55376
ioc reboot
DCM:Z1.VAL 2025-01-03 09:05:56.102804 -0.04
DCM:Z1.RBV 2025-01-03 09:05:56.102804 -0.0401
DCM:Z2.VAL 2025-01-03 09:05:56.042681 0.0657
DCM:Z2.RBV 2025-01-03 09:05:56.042681 0.0653
DCM:ThetaM.VAL 2025-01-03 09:05:56.174482 7.55376 <-- same
as previous
DCM:ThetaM.RBV 2025-01-03 09:05:56.174482 7.55376 <-- but
motor move
DCM:ThetaM.RBV 2025-01-03 09:05:57.012778 7.55206
DCM:ThetaM.RBV 2025-01-03 09:05:57.502889 7.54196
DCM:ThetaM.RBV 2025-01-03 09:05:57.822823 7.54366
DCM:ThetaM.RBV 2025-01-03 09:05:57.992678 7.54791
DCM:ThetaM.RBV 2025-01-03 09:05:58.162720 7.55171
DCM:ThetaM.RBV 2025-01-03 09:05:58.342759 7.55266
DCM:ThetaM.RBV 2025-01-03 09:05:58.492806 7.55271
DCM:ThetaM.RBV 2025-01-03 09:05:58.662711 7.55371
DCM:ThetaM.RBV 2025-01-03 09:05:58.962828 7.55376
DCM:ThetaM.RBV 2025-01-03 09:05:59.132771 7.55381
DCM:ThetaM.RBV 2025-01-03 09:06:02.762853 7.55386
ioc reboot
DCM:Z1.VAL 2025-01-03 09:09:37.385148 -0.0401
DCM:Z1.RBV 2025-01-03 09:09:37.385148 -0.04
DCM:Z2.VAL 2025-01-03 09:09:37.325204 0.0653
DCM:Z2.RBV 2025-01-03 09:09:37.325204 0.0657
DCM:ThetaM.VAL 2025-01-03 09:09:38.354986 0 <--
different, zero!
DCM:ThetaM.RBV 2025-01-03 09:09:38.354986 7.55181 <--
motor move
DCM:ThetaM.RBV 2025-01-03 09:09:38.535008 7.54706
DCM:ThetaM.RBV 2025-01-03 09:09:38.704917 7.54026
DCM:ThetaM.RBV 2025-01-03 09:09:38.875048 7.53131
DCM:ThetaM.RBV 2025-01-03 09:09:39.045385 7.52046
DCM:ThetaM.RBV 2025-01-03 09:09:39.215134 7.50731
DCM:ThetaM.RBV 2025-01-03 09:09:39.385166 7.49361
DCM:ThetaM.RBV 2025-01-03 09:09:39.555112 7.48036
DCM:ThetaM.RBV 2025-01-03 09:09:39.725153 7.46636
DCM:ThetaM.RBV 2025-01-03 09:09:39.894942 7.45281
DCM:ThetaM.RBV 2025-01-03 09:09:40.064989 7.43961
DCM:ThetaM.RBV 2025-01-03 09:09:40.234971 7.42526
DCM:ThetaM.RBV 2025-01-03 09:09:40.405113 7.41221
DCM:ThetaM.RBV 2025-01-03 09:09:40.585072 7.39761
DCM:ThetaM.RBV 2025-01-03 09:09:40.755044 7.38401
DCM:ThetaM.RBV 2025-01-03 09:09:40.925113 7.37066
DCM:ThetaM.RBV 2025-01-03 09:09:42.095077 7.31426
DCM:ThetaM.VAL 2025-01-03 09:09:42.095077 7.31426 <-- I
stop the motor.
DCM:ThetaM.RBV 2025-01-03 09:09:46.705116 7.31421
ioc reboot
DCM:Z1.VAL 2025-01-03 09:12:18.906995 -0.04
DCM:Z1.RBV 2025-01-03 09:12:18.906995 -0.0401
DCM:Z2.VAL 2025-01-03 09:12:18.846984 0.0657
DCM:Z2.RBV 2025-01-03 09:12:18.846984 0.0653
DCM:ThetaM.VAL 2025-01-03 09:12:21.346979 7.29431 <--
different −0.01995
DCM:ThetaM.RBV 2025-01-03 09:12:21.346979 7.29431 <--
motor move
ioc reboot
DCM:Z1.VAL 2025-01-03 09:18:20.230656 -0.0401
DCM:Z1.RBV 2025-01-03 09:18:20.230656 -0.04
DCM:Z2.VAL 2025-01-03 09:18:20.170608 0.0653
DCM:Z2.RBV 2025-01-03 09:18:20.170608 0.0657
DCM:ThetaM.VAL 2025-01-03 09:18:20.311337 7.27437 <--
different −0.01994
DCM:ThetaM.RBV 2025-01-03 09:18:20.311337 7.29431 <--
motor move
DCM:ThetaM.RBV 2025-01-03 09:18:21.150538 7.29231
DCM:ThetaM.RBV 2025-01-03 09:18:21.320404 7.28771
DCM:ThetaM.RBV 2025-01-03 09:18:21.500407 7.28171
DCM:ThetaM.RBV 2025-01-03 09:18:21.670389 7.27681
DCM:ThetaM.RBV 2025-01-03 09:18:21.840686 7.27421
DCM:ThetaM.RBV 2025-01-03 09:18:22.010457 7.27406
DCM:ThetaM.VAL 2025-01-03 09:18:22.010457 7.27437
DCM:ThetaM.RBV 2025-01-03 09:18:22.330451 7.27421
DCM:ThetaM.RBV 2025-01-03 09:18:22.660350 7.27431
DCM:ThetaM.RBV 2025-01-03 09:18:22.960309 7.27436
DCM:ThetaM.RBV 2025-01-03 09:18:23.130896 7.27441
ioc reboot
DCM:Z1.VAL 2025-01-03 09:22:00.722740 -0.04
DCM:Z1.RBV 2025-01-03 09:22:00.722740 -0.0401
DCM:Z2.VAL 2025-01-03 09:22:00.662695 0.0657
DCM:Z2.RBV 2025-01-03 09:22:00.662695 0.0653
DCM:ThetaM.VAL 2025-01-03 09:22:02.912859 7.25442 <--
different −0.01995
DCM:ThetaM.RBV 2025-01-03 09:22:02.912859 7.25441 <--
motor move
ioc reboot
DCM:Z1.VAL 2025-01-03 09:33:58.400417 -0.0401
DCM:Z1.RBV 2025-01-03 09:33:58.400417 -0.04
DCM:Z2.VAL 2025-01-03 09:33:58.340350 0.0653
DCM:Z2.RBV 2025-01-03 09:33:58.340350 0.0657
DCM:ThetaM.VAL 2025-01-03 09:33:59.330344 7.23447 <--
different −0.01995
DCM:ThetaM.RBV 2025-01-03 09:33:59.330344 7.25241 <--
motor move
DCM:ThetaM.RBV 2025-01-03 09:33:59.500272 7.24781
DCM:ThetaM.RBV 2025-01-03 09:33:59.680584 7.24186
DCM:ThetaM.RBV 2025-01-03 09:33:59.850291 7.23701
DCM:ThetaM.RBV 2025-01-03 09:34:00.020355 7.23431
DCM:ThetaM.RBV 2025-01-03 09:34:00.190267 7.23416
DCM:ThetaM.VAL 2025-01-03 09:34:00.190267 7.23447
DCM:ThetaM.RBV 2025-01-03 09:34:00.510337 7.23431
DCM:ThetaM.RBV 2025-01-03 09:34:00.840415 7.23441
DCM:ThetaM.RBV 2025-01-03 09:34:01.140389 7.23446
DCM:ThetaM.RBV 2025-01-03 09:34:01.310255 7.23451
On Thu, Jan 2, 2025 at 11:26 AM LiangChih Chiang <[email protected]
<mailto:[email protected]>> wrote:
>To explain a little more, it is important that the driver has
completed the first poll cycle for the position and status of each
axis before iocInit.
>This is because the motor record looks at those positions during
iocInit, and if there are non-zero it uses those values as the
current position.
>You can add the following to your startup script after you create
the controller and axes to sleep for 1 second.
I did add epicsThreadSleep(1.0).
There are 5 motors(axis 1 to 5) connected to the motor controller.
After epicsThreadSleep(1.0) added, it seems that the VAL/RBV of
motor records of axis 2 to 5 can be successfully loaded back from
the controller after IOC reboot.
But the behavior of axis 0 (this axis is the most important) is strange.
After IOC reboot, the motor record of axis 0 will move.
It seems that the VAL field is set to a new value
and I can't figure out the relationship between the new and old values.
The axis 0 is the main axis(Bragg angle) of a double crystal
monochromator,
and it has corresponding pseudo motor to represent the Energy of x-
ray beam.
On Wed, Nov 20, 2024 at 11:04 PM Mark Rivers
each axis before iocInit. This is because the motor record
looks at those positions during iocInit, and if there are non-
zero it uses those values as the current position. You can add
the following to your startup script after you create the
Let us know if this does not fix the problem.
[email protected]>> on behalf of Torsten Bögershausen via
Tech-talk <[email protected] <mailto:[email protected]>>
*Sent:* Wednesday, November 20, 2024 5:15 AM
*To:* LiangChih Chiang <[email protected]
<mailto:[email protected]>>; [email protected]
<mailto:[email protected]> <[email protected]
*Subject:* Re: I implemented the Model 3 of EPICS motor driver
support, but the VAL and RBV of motor record are zero after IOC
reboot.
Hej,
without having seen ypur code, I would speculate that you run
into a not-unknown issue using Model 3 motors, connected via
a serial cable, USB or Ethernet?
The value that the motorRecord needs is read from the driver,
wich must have been able to read it from your hardware.
Here are ESS we have a patched motor, which can handle this.
If you use the upstream version, the easist workaround may be
to add a sleep() after the createController() line in your st.cmd
HTH
/Torsten
On 2024-11-20 09:47, LiangChih Chiang via Tech-talk wrote:
> Hello, EPICS mates.
> I implemented the Model 3 of EPICS motor driver support for
some motor
> controller,
> but the VAL and RBV of the motor record are zero after IOC
reboot.
> I think the motor record doesn't restore the values of motor
pulse and
> encoder count from the motor controller after IOC reboot.
> What member functions of asynMotorController and
asynMotorAxis classes
> should I implement?
> Best regards.
