1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Question Regarding HLS/LLS Settings and DIR Values
From: Torsten Bögershausen via Tech-talk <[email protected]>
To: [email protected], "[email protected]" <[email protected]>
Date: Mon, 20 Jan 2025 14:40:50 +0100
Hej Zhibang Shen,
everything is working as it should, I think.
There is HLS and LLs, which are in the "User" coordinate system.
See motorRecord.dbd:
        field(HLS,DBF_SHORT) {
                prompt("User High Limit Switch")
                special(SPC_NOMOD)
        field(LLS,DBF_SHORT) {
                prompt("User Low Limit Switch")
                special(SPC_NOMOD)
        field(RHLS,DBF_SHORT) {
                prompt("Raw High Limit Switch")
                special(SPC_NOMOD)
        field(RLLS,DBF_SHORT) {
                prompt("Raw Low Limit Switch")
                special(SPC_NOMOD)
The ones that are not swapped by DIR are RLLS and RHLS
Please let us know, if there are more questions.
/Torsten
On 2025-01-20 14:09, Zhibang Shen via Tech-talk wrote:
I am using motor-R7-1.
In the motor submodule developed by myself, I check the status of the hard limit switch and directly set motorStatusHighLimit_ and motorStatusLowLimit_.
// Read the limit status
status = pC_->readReg16(axisNo_+1, LIMIT, &read_val, DEFAULT_CONTROLLER_TIMEOUT);
//low limit
limit = (read_val & 0x2);
setIntegerParam(pC_->motorStatusLowLimit_, limit);
//high limit
limit = (read_val & 0x1);
setIntegerParam(pC_->motorStatusHighLimit_, limit);
And I find something interesting that when the motor hits the high limit switch, and the DIR is set to Positive, the HLS will be illuminated. And if I switch the DIR to Neg, without moving the motor, the LLS will become 1 and the HLS will be 0.
Is the logic intentionally designed this way, or is it because my code is not good enough?
Zhibang Shen
Institute of High Energy Physics, Chinese Academy of Sciences
19B Yuquan Road, Shijingshan District, Beijing, China
100049
Re: Re: Question Regarding HLS/LLS Settings and DIR Values Zhibang Shen via Tech-talk
Prev: Question Regarding HLS/LLS Settings and DIR Values Zhibang Shen via Tech-talk
Next: Re: Re: Question Regarding HLS/LLS Settings and DIR Values Zhibang Shen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
