1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: Re: Question Regarding HLS/LLS Settings and DIR Values
To: "[email protected]" <[email protected]>, Torsten Bögershausen <[email protected]>
Date: Mon, 20 Jan 2025 17:13:17 +0000
> But I still have one question, could you please tell me whether should I set the RHLS and RLLS by myself in the code or all these have been done automatically by EPICS motor?
The motor record will set those based on the limit status that your driver is passing back.  You don't need to do it yourself in your code.
The problem with SPEC seems strange, because I would have expected this to have been reported by other users.  Many beamlines use SPEC with EPICS motors, and I am sure that many of those motors have DIR=negative.
I will ask the SPEC experts on our beamlines and see if we can test it.
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Zhibang Shen via Tech-talk
Sent: Monday, January 20, 2025 9:43 AM
To: Torsten Bögershausen <[email protected]>
Cc: [email protected]
Subject: Re: Re: Question Regarding HLS/LLS Settings and DIR Values
Thank you for your information.
The reason I raise this question is that I would like to use this motor in SPEC.
If I set the DIR positive, SPEC will throw out a notification that the motor hits the limit switch. But if the DIR is set negative, no warning will be given.
I asked the developer of SPEC, about which kind of limit switch is used for showing the hard limit notification. He mentioned that the limits are related to the dial position. However, according to the available PVs of standard EPICS motor, shown at
https://urldefense.us/v3/__https://certif.com/spec_help/epics.html__;!!G_uCfscf7eWS!eO1OIlekREazv9thMyWvKAYqxPOELmJSbhzvO7JWRlBzBdKyOBaLLoUOwe7aOx1_NDqWoEsaL3KTrYGpnSudWg$
, and also your information about the limits. It seems that the raw limit RHLS and RLLS should be used to determine which limit switch has been hit.
Maybe I should ask more about the details from SPEC developer. But I still have one question, could you please tell me whether should I set the RHLS and RLLS by myself in the code or all these have been done automatically by EPICS motor?
Best regards,
Zhibang
> -----原始邮件-----
> 发件人: "Torsten Bögershausen" <[email protected]>
> 发送时间:2025-01-20 21:40:50 (星期一)
> 收件人: [email protected], "[email protected]"
> <[email protected]>
> 主题: [SPAM] Re: Question Regarding HLS/LLS Settings and DIR Values
> Hej Zhibang Shen,
> everything is working as it should, I think.
> There is HLS and LLs, which are in the "User" coordinate system.
> See motorRecord.dbd:
>          field(HLS,DBF_SHORT) {
>                  prompt("User High Limit Switch")
>                  special(SPC_NOMOD)
>          field(LLS,DBF_SHORT) {
>                  prompt("User Low Limit Switch")
>                  special(SPC_NOMOD)
>          field(RHLS,DBF_SHORT) {
>                  prompt("Raw High Limit Switch")
>                  special(SPC_NOMOD)
>          field(RLLS,DBF_SHORT) {
>                  prompt("Raw Low Limit Switch")
>                  special(SPC_NOMOD)
> The ones that are not swapped by DIR are RLLS and RHLS Please let us
> know, if there are more questions.
> /Torsten
> On 2025-01-20 14:09, Zhibang Shen via Tech-talk wrote:
> > Hi,
> > I am using motor-R7-1.
> > In the motor submodule developed by myself, I check the status of
> > the hard limit switch and directly set motorStatusHighLimit_ and
> > motorStatusLowLimit_.
> > // Read the limit status
> > status = pC_->readReg16(axisNo_+1, LIMIT, &read_val,
> > DEFAULT_CONTROLLER_TIMEOUT);
> > //low limit
> > limit = (read_val & 0x2);
> > setIntegerParam(pC_->motorStatusLowLimit_, limit);
> > //high limit
> > limit = (read_val & 0x1);
> > setIntegerParam(pC_->motorStatusHighLimit_, limit);
> > And I find something interesting that when the motor hits the high
> > limit switch, and the DIR is set to Positive, the HLS will be
> > illuminated. And if I switch the DIR to Neg, without moving the
> > motor, the LLS will become 1 and the HLS will be 0.
> > Is the logic intentionally designed this way, or is it because my
> > code is not good enough?
> > Zhibang Shen
> > Institute of High Energy Physics, Chinese Academy of Sciences
> > 19B Yuquan Road, Shijingshan District, Beijing, China
> > 100049
Re: RE: Re: Question Regarding HLS/LLS Settings and DIR Values Zhibang Shen via Tech-talk
Re: Question Regarding HLS/LLS Settings and DIR Values Torsten Bögershausen via Tech-talk
Re: Re: Question Regarding HLS/LLS Settings and DIR Values Zhibang Shen via Tech-talk
Prev: Re: Re: Question Regarding HLS/LLS Settings and DIR Values Zhibang Shen via Tech-talk
Next: Re: RE: Re: Question Regarding HLS/LLS Settings and DIR Values Zhibang Shen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
