1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Phytron support for EPICS motor (pull request #8)
To: "Peterson, Kevin M." <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 23 Jan 2025 13:07:15 +0100
Hi Kevin,
thank you for feedback.
I separated the motor database into two files, one is using the previous scheme requiring MRES and one new, which requires UREV. The reason was the easy support of high resolution steppers. This is more compatible with the known behavior of existing installations.
Best regards,
Lutz Rossa
Am 22.01.25 um 21:41 schrieb Peterson, Kevin M.:
Thanks for the pull request.  I added a comment to the PR discussion.  My only concern is related to the database that includes the motor record.
Kevin
From: Tech-talk on behalf of Lutz Rossa via Tech-talk
Sent: Saturday, January 18, 2025 6:30 AM
To: [email protected]
Subject: Phytron support for EPICS motor (pull request #8)
Hi tech-talk people,
I worked on the Phytron support for EPICS motor, that should also
support the smaller Phytron MCC-1/MCC-2 controllers, which fits
better for single/dual axis applications. These controllers come
also with analog input(s) and digital I/O.
It was matter of my heart to support analog and digital I/O of the
phyMOTION controller. Bernhard Kuner from HZB does not want to
continue his work (issue #5), so I tried to implement these ideas
for both controller types.
For those, who have a Phytron controller, please look at
<https://github.com/epics-motor/motorPhytron/pull/8>
and give comments for this change.
Best regards,
Lutz Rossa
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse: Hahn-Meitner-Platz 1, D-14109 Berlin
https://www.helmholtz-berlin.de
Attachment: smime.p7s
Description: Kryptografische S/MIME-Signatur
Phytron support for EPICS motor (pull request #8) Lutz Rossa via Tech-talk
Re: Phytron support for EPICS motor (pull request #8) Peterson, Kevin M. via Tech-talk
Prev: Re: Phytron support for EPICS motor (pull request #8) Peterson, Kevin M. via Tech-talk
Next: Does P4P Support Channel Access (CA) with a Provider Flag? Kim, Kuktae via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: EPICS INSTALL_LOCATION/FINAL_LOCATION doesn't work? J. Lewis Muir via Tech-talk
