Hello Eusebio,
I think Michael have already pointed out what the problem is, and I just want to add more info here.
According to the following links, it seems that the archappl.properties file in version 2.0.5 is missing.
https://epics.anl.gov/tech-talk/2024/msg01220.php
https://epics.anl.gov/tech-talk/2024/msg01221.php
https://github.com/archiver-appliance/epicsarchiverap/issues/284
Currently, there are probably two workarounds,
1. Find the archappl.properties file from source code or old installation of Archiver Appliance, and copy it into the following directoies after running single_machine_install.sh,
./engine/webapps/engine/WEB-INF/classes
./etl/webapps/etl/WEB-INF/classes
./mgmt/webapps/mgmt/WEB-INF/classes
./retrieval/webapps/retrieval/WEB-INF/classes
2. Use the following line in sampleStartup.sh to point to the property file,
export ARCHAPPL_PROPERTIES_FILENAME=/home/control/tomcat_instances/archappl.properties
Lin
-----原始邮件-----
发件人: "Eusebio Naif Al-Soliman Fuentes via Tech-talk" <[email protected]>
发送时间: 2025-01-24 21:01:49 (星期五)
收件人: "Tech Talk" <[email protected]>
主题: Archiver Appliance 2.0.5 error 500
Hello everybody.
I have installed the EPICS Archiver Appliance 2.0.5 with the single_machine_install.sh script.
When I access the web interface, an error 500 appears. The complete message is the next one:
Estado HTTP 500 – Internal Server Error
Tipo Informe de estado
mensaje The config service for this installation did not start up correctly. Please check the logs for any exceptions or FATAL errors. The appliance archiver cannot function without knowning the characters that separate the components of a PV name <i>org.epics.archiverappliance.config.exception.ConfigException: The appliance archiver cannot function without knowning the characters that separate the components of a PV name at org.epics.archiverappliance.config.ConvertPVNameToKey.initialize(ConvertPVNameToKey.java:82) at org.epics.archiverappliance.config.DefaultConfigService.initialize(DefaultConfigService.java:301) at org.epics.archiverappliance.config.ArchServletContextListener.contextInitialized(ArchServletContextListener.java:47) at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4018) at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:4460) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:164) at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:599) at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:571) at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:603) at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:1014) at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1866) at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264) at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75) at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:123) at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:816) at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:468) at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1584) at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:312) at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:109) at org.apache.catalina.util.LifecycleBase.setStateInternal(LifecycleBase.java:389) at org.apache.catalina.util.LifecycleBase.setState(LifecycleBase.java:336) at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:776) at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:721) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:164) at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1203) at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1193) at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264) at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75) at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:145) at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:749) at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:211) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:164) at org.apache.catalina.core.StandardService.startInternal(StandardService.java:415) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:164) at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:874) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:164) at org.apache.catalina.startup.Catalina.start(Catalina.java:739) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.base/java.lang.reflect.Method.invoke(Method.java:569) at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:345) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.base/java.lang.reflect.Method.invoke(Method.java:569) at org.apache.commons.daemon.support.DaemonLoader.start(DaemonLoader.java:234) </i>
Descripción El servidor encontró un error interno que hizo que no pudiera rellenar este requerimiento.
Apache Tomcat/9.0.98
Thanks in advance, Eusebio.
Saludos/Best regards
University of Granada
MSc. Data Science and Computer Engineering
[email protected]
