1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Archiver Appliance 2.0.5 error 500
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Eusebio Naif Al-Soliman Fuentes <[email protected]>
Cc: Tech Talk <[email protected]>
Date: Fri, 24 Jan 2025 09:59:12 -0800
On 1/24/25 05:01, Eusebio Naif Al-Soliman Fuentes via Tech-talk wrote:
Hello everybody.
I have installed the EPICS Archiver Appliance 2.0.5 with the single_machine_install.sh script.
When I access the web interface, an error 500 appears. The complete message is the next one:
I think the essential part of this error message is:
The appliance archiver cannot function without knowning the characters that separate the components of a PV name
Which I think is an indication that the 'siteNameSpaceSeparators' property, typically in an archappl.properties file is not being found.
The full property name is:
org.epics.archiverappliance.config.ConvertPVNameToKey.siteNameSpaceSeparators = [\\:\\-]
  Estado HTTP 500 – Internal Server Error
*Tipo*Informe de estado
*mensaje*The config service for this installation did not start up correctly. Please check the logs for any exceptions or FATAL errors. The appliance archiver cannot function without knowning the characters that separate the components of a PV name <i>org.epics.archiverappliance.config.exception.ConfigException: The appliance archiver cannot function without knowning the characters that separate the components of a PV name at org.epics.archiverappliance.config.ConvertPVNameToKey.initialize(ConvertPVNameToKey.java:82) at org.epics.archiverappliance.config.DefaultConfigService.initialize(DefaultConfigService.java:301) at org.epics.archiverappliance.config.ArchServletContextListener.contextInitialized(ArchServletContextListener.java:47) at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4018) at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:4460) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:164) at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:599) at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:571) at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:603) at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:1014) at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1866) at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264) at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75) at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:123) at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:816) at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:468) at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1584) at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:312) at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:109) at org.apache.catalina.util.LifecycleBase.setStateInternal(LifecycleBase.java:389) at org.apache.catalina.util.LifecycleBase.setState(LifecycleBase.java:336) at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:776) at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:721) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:164) at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1203) at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1193) at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264) at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75) at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:145) at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:749) at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:211) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:164) at org.apache.catalina.core.StandardService.startInternal(StandardService.java:415) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:164) at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:874) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:164) at org.apache.catalina.startup.Catalina.start(Catalina.java:739) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.base/java.lang.reflect.Method.invoke(Method.java:569) at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:345) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.base/java.lang.reflect.Method.invoke(Method.java:569) at org.apache.commons.daemon.support.DaemonLoader.start(DaemonLoader.java:234) </i>
*Descripción*El servidor encontró un error interno que hizo que no pudiera rellenar este requerimiento.
      Apache Tomcat/9.0.98
Thanks in advance, Eusebio.
Saludos/Best regards
*University of Granada *
*MSc. Data Science and Computer Engineering*
[email protected]
Archiver Appliance 2.0.5 error 500 Eusebio Naif Al-Soliman Fuentes via Tech-talk
Prev: Re: Motor driver and lost TCP connection Mark Rivers via Tech-talk
Next: Re: Archiver Appliance 2.0.5 error 500 Wang, Lin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Archiver Appliance 2.0.5 error 500 Eusebio Naif Al-Soliman Fuentes via Tech-talk
