1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: MRF kernel modules not seeing hardware
From: "Daykin, Evan via Tech-talk" <[email protected]>
To: Han Lee <[email protected]>, Jerzy Jamroz <[email protected]>, "Timo Korhonen" <[email protected]>
Date: Wed, 29 Jan 2025 22:36:35 +0000
Hi Han,
Thanks for your assistance. I am stuck at step (2) for udev rules - since the driver isn't showing up in /proc/devices, I can't create a /dev node via udev or otherwise. The bizarre thing is that when I replace the problem CPU card/installation with a known "working" installation, the device ids are the typical,  supported "Signal processing controller: Device 1a3e:152c/252c, everything corresponding to your pciids repo.
Going back to the problem version, running depmod -e -F <my system.map file> yields a slew of missing symbols, indicating the driver is somehow thinking vmlinux, System.map and the module's kernel target are all consistent when they are actually not.
I think the next thing I'll try is starting over with a fresh install on the next most recent minor rt kernel version, of which we have a verified working example.
-Evan
Sent: Wednesday, January 29, 2025 4:49:01 PM
To: Jerzy Jamroz <[email protected]>; Timo Korhonen <[email protected]>
Cc: [email protected] <[email protected]>; Daykin, Evan <[email protected]>
[EXTERNAL] This email originated from outside of FRIB
On Wed, Jan 29, 2025 at 1:34 PM Han Lee <[email protected]> wrote:
Hi Evan,
Three steps you have to configure.
  1. Kernel Driver
  2. udev rules
  3. dkms configuration if you want to keep the kernel driver up-to-date to any latest kernel update.
Please check the old repository for the further information, especially, configuration and setup
Your lspci returns the strange (not linux default) result from my understanding, since the standard pciids file doesn't contain " Micro-Research Finland Oy".
You probably use the similar my old repository pciid file instead of the standard Linux one.
1a3e:150c
1a3e:250c
Hi Jerzy and Timo,
Happy Lunar New Year!
My question is that the above two hardwares (150c/205c) are supported by the current mrfioc2 fully?
Evan, if they are not fully integrated into the mrfioc2, someone needs to add their support to the mrfioc2 repository.
If you can share the hardware, if ESS has them, information with me, I can update the pciids file for others.
I hope that ESS is still willing to share its local changes with the community.
Best,
Han
If you let me know which hardware you are using, I can add them into the old and still up-to-date repository.
Best,
Han
On Wed, Jan 29, 2025 at 7:17 AM Daykin, Evan via Tech-talk <[email protected]> wrote:
Hello,
On a new linux kernel 6.1.0-30-rt-amd64 installation, I am trying to install the mrfioc2 PCI kernel module by running the following:
sudo make KERNELDIR=/lib/modules/$(uname -r)/build modules_install
make -C /lib/modules/6.1.0-30-rt-amd64/build DRV_VERSION='3' M=/home/daykin/git/mrfioc2/mrmShared/linux modules_install
make[1]: Entering directory '/usr/src/linux-headers-6.1.0-30-rt-amd64'
  INSTALL /lib/modules/6.1.0-30-rt-amd64/extra/mrf.ko
  DEPMOD  /lib/modules/6.1.0-30-rt-amd64
Warning: modules_install: missing 'System.map' file. Skipping depmod.
make[1]: Leaving directory '/usr/src/linux-headers-6.1.0-30-rt-amd64'
depmod -a && modprobe: <no output>
lsmod|grep mrf
mrf                    24576  0
uio                    28672  1 mrf
parport                73728  1 mrf
cat /proc/devices
Character devices:
  1 mem
  4 /dev/vc/0
  4 tty
  4 ttyS
  5 /dev/tty
  5 /dev/console
  5 /dev/ptmx
  7 vcs
10 misc
13 input
29 fb
116 alsa
128 ptm
136 pts
153 spi
180 usb
189 usb_device
226 drm
238 uio
239 aux
240 cec
241 lirc
242 ipmidev
243 watchdog
244 mei
245 nvme-generic
246 nvme
247 cxl
248 bsg
249 ptp
250 pps
251 rtc
252 dax
253 tpm
254 gpiochip
Block devices:
  7 loop
254 device-mapper
259 blkext
sudo dmesg|grep mrf
[  508.671574] mrf: loading out-of-tree module taints kernel.
[  508.671603] mrf: module verification failed: signature and/or required key missing - tainting kernel
I have also tried uninstalling the mrfioc2 version and installing Jukka’s driver (https://github.com/jpietari/mrf-linux-driver) after some small modifications for the deprecation of HAS_UNLOCKED_IOCTL and ioremap_nocache, the module builds successfully but the module_load script also indicates it doesn’t see any EVGs/EVRs.
In both cases, the device files /dev/uio* or /dev/era* are not installed, and the output of lspci is as follows:
sudo lspci -vv -nn -s 07:0f.0
07:0f.0 Signal processing controller [1180]: Micro-Research Finland Oy Device [1a3e:150c] (rev 01)
     Subsystem: Micro-Research Finland Oy Device [1a3e:150c]
     Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
     Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=slow >TAbort+ <TAbort- <MAbort- >SERR- <PERR- INTx-
     Interrupt: pin A routed to IRQ 255
     IOMMU group: 15
     Region 0: Memory at a1000000 (32-bit, non-prefetchable) [disabled] [size=1M]
     Capabilities: [40] Null
sudo lspci -vv -nn -s 07:0e.0
07:0e.0 Signal processing controller [1180]: Micro-Research Finland Oy Device [1a3e:250c] (rev 01)
     Subsystem: Micro-Research Finland Oy Device [1a3e:250c]
     IOMMU group: 15
     Region 0: Memory at a1100000 (32-bit, non-prefetchable) [disabled] [size=1M]
I’ve tried with multiple cards, including some known to be working on older installations and hardware. Is there something I’m missing?
Evan
Jeong Han Lee, Dr.rer.nat.
Lawrence Berkeley National Laboratory
MRF kernel modules not seeing hardware Daykin, Evan via Tech-talk
Re: MRF kernel modules not seeing hardware Han Lee via Tech-talk
Prev: archiver appliance and CA -> PVA Pierrick M Hanlet via Tech-talk
Next: Re: MRF kernel modules not seeing hardware Di Wang via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: MRF kernel modules not seeing hardware Han Lee via Tech-talk
