Hi Evan, The MRF kernel driver code defines the supported MRF cards defined in as Di mentioned. The hardware support is the same as +5 years ago in the mrf kernel support, when I left the MTCA-verse at ESS. So my question is now, what MRF hardwares do you use currently? Since I don't see your PCI ID in the kernel source and my pci.ids file, we need to understand what hardware you have now. If this is the case, we can modify the mrfioc2 kernel driver to support your hardware. 1. In most cases, mrfioc2 will work, I guess your hardware is strongly based on the MTCA MRF product lines. 2. In the worst case scenario, someone has to test the hardware and update the device support within the mrfioc2 kernel. ESS may have the latest kernel driver for your hardware, I guess. Jerzy will confirm it. Best, Han On Wed, Jan 29, 2025 at 8:40 PM Daykin, Evan <[email protected]> wrote:
-- Jeong Han Lee, Dr.rer.nat. Lawrence Berkeley National Laboratory
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
