Hi Andrea,
yes this error is well known. I stumbled across that some years ago when I did my first archiver installation.
You forgot to download and install the mysql-connector jar file relevant for your mysql version.
It needs to be placed in the tomcat folder. Check the documentation of the archiver for the exact location.
Hope this helps,
Jörn
Am Freitag, 7. Februar 2025, 14:50:57 Mitteleuropäische Normalzeit schrieb Andrea Celentano via Tech-talk:
> Dear colleagues,
> I am currently developing the slow-controls system for a small-scale
> experiment (~ 100 PVs), and I'd like to use the EPICS archiver to
> properly track them.
> I am using the following setup:
> * Centos7 machine (I cannot change this at the moment)
> * Java JDK version 16.0.2
> * Archiver release 2.0.5
> (https://urldefense.us/v3/__https://github.com/archiver-appliance/epicsarchiverap/releases/tag/2.0.5__;!!G_uCfscf7eWS!dfP3pgsViV5i5uqOcqz-MWHrFko78Ypy28FydNixfzs_o8UBmRRyBJPjpqZGCwptaFyl7HX0PwxiW6n-WE7VLlepoB0sdgprJNw$ )
> * Tomcat version apache-tomcat-9.0.20
> * mysql connector version 5.1.21
> Following the guide
> (https://urldefense.us/v3/__https://epicsarchiver.readthedocs.io/en/latest/sysadmin/installguide.html__;!!G_uCfscf7eWS!dfP3pgsViV5i5uqOcqz-MWHrFko78Ypy28FydNixfzs_o8UBmRRyBJPjpqZGCwptaFyl7HX0PwxiW6n-WE7VLlepoB0seOqUtEE$ ),
> I am using the script "single_machine_install.sh". Everything goes well,
> I obtain the script "sampleStartup.sh" in the folder where Tomcat
> Instances are located.
> If I execute it, and then I open the file "mgmt/logs/catalina.err", I
> see the following error. and the archiver does not start.
> java.sql.SQLException: Unable to load class: com.mysql.jdbc.Driver from
> ClassLoader:java.net.URLClassLoader@4617c264;ClassLoader:ParallelWebappClassLoader
> context: mgmt
> delegate: false
> ----------> Parent Classloader:
> at
> org.apache.tomcat.jdbc.pool.PooledConnection.connectUsingDriver(PooledConnection.java:292)
> at
> org.apache.tomcat.jdbc.pool.PooledConnection.connect(PooledConnection.java:212)
> at
> org.apache.tomcat.jdbc.pool.ConnectionPool.createConnection(ConnectionPool.java:744)
> at
> org.apache.tomcat.jdbc.pool.ConnectionPool.borrowConnection(ConnectionPool.java:676)
> at
> org.apache.tomcat.jdbc.pool.ConnectionPool.init(ConnectionPool.java:483)
> at
> org.apache.tomcat.jdbc.pool.ConnectionPool.<init>(ConnectionPool.java:154)
> at
> org.apache.tomcat.jdbc.pool.DataSourceProxy.pCreatePool(DataSourceProxy.java:118)
> at
> org.apache.tomcat.jdbc.pool.DataSourceProxy.createPool(DataSourceProxy.java:107)
> at
> org.apache.tomcat.jdbc.pool.DataSourceFactory.createDataSource(DataSourceFactory.java:560)
> at
> org.apache.tomcat.jdbc.pool.DataSourceFactory.getObjectInstance(DataSourceFactory.java:244)
> at
> org.apache.naming.factory.FactoryBase.getObjectInstance(FactoryBase.java:94)
> at
> java.naming/javax.naming.spi.NamingManager.getObjectInstance(NamingManager.java:341)
> at org.apache.naming.NamingContext.lookup(NamingContext.java:840)
> at org.apache.naming.NamingContext.lookup(NamingContext.java:159)
> at org.apache.naming.NamingContext.lookup(NamingContext.java:827)
> at org.apache.naming.NamingContext.lookup(NamingContext.java:173)
> at
> org.apache.catalina.core.NamingContextListener.addResource(NamingContextListener.java:1017)
> at
> org.apache.catalina.core.NamingContextListener.createNamingContext(NamingContextListener.java:557)
> at
> org.apache.catalina.core.NamingContextListener.lifecycleEvent(NamingContextListener.java:253)
> at
> org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:123)
> at
> org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5048)
> at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183)
> at
> org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:713)
> at
> org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:690)
> at
> org.apache.catalina.core.StandardHost.addChild(StandardHost.java:705)
> at
> org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:978)
> at
> org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1849)
> at
> java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
> at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
> at
> org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75)
> at
> java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:123)
> at
> org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:773)
> at
> org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:427)
> at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1576)
> at
> org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:309)
> at
> at
> org.apache.catalina.util.LifecycleBase.setStateInternal(LifecycleBase.java:423)
> at
> org.apache.catalina.util.LifecycleBase.setState(LifecycleBase.java:366)
> at
> org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:929)
> at
> org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:841)
> at
> org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1377)
> at
> org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1367)
> at
> at
> java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:145)
> at
> org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:902)
> at
> org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:262)
> at
> org.apache.catalina.core.StandardService.startInternal(StandardService.java:421)
> at
> org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:932)
> at org.apache.catalina.startup.Catalina.start(Catalina.java:633)
> at
> java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native
> Method)
> at
> java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:78)
> at
> java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at java.base/java.lang.reflect.Method.invoke(Method.java:567)
> at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:344)
> at
> Method)
> at
> at
> at
> org.apache.commons.daemon.support.DaemonLoader.start(DaemonLoader.java:241)
> Caused by: java.lang.ClassNotFoundException: Unable to load class:
> Has anyone ever seen this?
> Thanks,
> Andrea
- Re: Installation of EPICS archiver on a single Centos7 machine Andrea Celentano via Tech-talk
- Installation of EPICS archiver on a single Centos7 machine Andrea Celentano via Tech-talk
Re: Installation of EPICS archiver on a single Centos7 machine Wang, Lin via Tech-talk
<2025>
<2025>
