Hello Ziga
Thanks, this is working as I expected by setting the waveform scan to 1 second. This maybe a general question not related only to my
case, but how to conditionally trigger a PV from within EPICS records? I just had an idea where I want to export or scan the waveform once I had 200 samples exactly, already in the IOC I am tracking the number of samples.
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME
P.O. Box 7, Allan 19252, Jordan
Tel: +96253511348 , ext. 265
Fax: +96253511423
Email :
[email protected]
Website:
www.sesame.org.jo
Hi Abdalla,
One way how to create waveform from scalars with EPICS records is Compress Record with an ALG field set to Circular Buffer and INP field pointing to your AI record.
https://epics.anl.gov/base/R7-0/8-docs/compressRecord.html
You still have to configure processing of the compress record (either FLNK from AI record, or CP flag on the INP link) to capture all the 200 samples.
Then you can point a waveform record to read the 200 sample with either 1 second SCAN rate or you can create some other (“complex”) logic to extract the data into waveform only when 200 “fresh” samples are
in the compress record.
Hope this helps,
Žiga
On Behalf Of Abdalla Ahmad via Tech-talk
Sent: Thursday, February 20, 2025 07:56
To: [email protected]
Subject: Make waveform from ai record
I have a fast ai record (200 Hz) in a stream-device-based IOC. Is there a "standard way" within EPICS records to transform these 200 samples into a single waveform record of size 200 processed at 1 second for example? Thanks.
Best Regards,
Abdalla.
Control Engineer
SESAME
- Re: Make waveform from ai record Ralph Lange via Tech-talk
- Make waveform from ai record Abdalla Ahmad via Tech-talk
- RE: Make waveform from ai record Žiga Oven via Tech-talk
Re: [EXTERNAL] History of EPICS Foster, Andrew (Observatory Science, RAL, TEC) via Tech-talk
<2025>
2026
<2025>
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
