1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: RE: Make waveform from ai record
To: Abdalla Ahmad <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 20 Feb 2025 07:36:41 +0000
Hi Abdalla,
One way how to create waveform from scalars with EPICS records is Compress Record with an ALG field set to Circular Buffer and INP field pointing to your AI record.
https://epics.anl.gov/base/R7-0/8-docs/compressRecord.html
You still have to configure processing of the compress record (either FLNK from AI record, or CP flag on the INP link) to capture all the 200 samples.
Then you can point a waveform record to read the 200 sample with either 1 second SCAN rate or you can create some other (“complex”) logic to extract the data into waveform only when 200 “fresh” samples are in the compress record.
Hope this helps,
Žiga
From: Tech-talk <[email protected]> On Behalf Of Abdalla Ahmad via Tech-talk
Sent: Thursday, February 20, 2025 07:56
To: [email protected]
Subject: Make waveform from ai record
Hi
I have a fast ai record (200 Hz) in a stream-device-based IOC. Is there a "standard way" within EPICS records to transform these 200 samples into a single waveform record of size 200 processed at 1 second for example? Thanks.
Best Regards,
Abdalla.
Control Engineer
SESAME
RE: Make waveform from ai record Abdalla Ahmad via Tech-talk
Prev: Make waveform from ai record Abdalla Ahmad via Tech-talk
Next: CAENels TetrAMM questions Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Next: RE: Make waveform from ai record Abdalla Ahmad via Tech-talk
