Please set each camera so it is acquiring continuously at 1 Hz. Then send a screen shot of the Gather plugin, which should have an Array Rate = 3.
Set the HDF5 plugin to Stream mode with NumCapture=100. Then press the Capture Start button to start streaming. It should save 3 arrays per second for 33 seconds and then close the file. Send a screenshot of the HDF5 screen after you press the Capture Start
button.
Hi Mark,
I checked the requirements and all are fullfilled:
1) all detectors are created in the same IOC:
># Adding Basler cameras. Modify the second parameter acording to the camera name.
>aravisConfig("$(PORT1)", "Basler-acA640-100gm-xxxxxxxx")
>aravisConfig("$(PORT2)", "Basler-acA640-100gm-yyyyyyyy")
>aravisConfig("$(PORT3)", "Basler-acA640-120gm-zzzzzzzz")
2) All cameras are of the same type, so the image size is the same (659 * 494) and of the same datatype (UINT8).
The attributes are the standard set. I did not add any.
I attached the screenshots of my NDPluginGather and NDPluginFileHDF5 settings.
There are no errors reported from the HDF5 plugin, but still only one image shows up in the output.
If I do a dump of the file structure, I get:
h5dump -n test_007.h5
HDF5 "test_007.h5" {
FILE_CONTENTS {
group /
group /entry
group /entry/data
dataset /entry/data/data
group /entry/instrument
group /entry/instrument/NDAttributes
dataset /entry/instrument/NDAttributes/BayerPattern
dataset /entry/instrument/NDAttributes/NDArrayEpicsTSSec
dataset /entry/instrument/NDAttributes/NDArrayEpicsTSnSec
dataset /entry/instrument/NDAttributes/NDArrayTimeStamp
dataset /entry/instrument/NDAttributes/NDArrayUniqueId
group /entry/instrument/detector
group /entry/instrument/detector/NDAttributes
dataset /entry/instrument/detector/NDAttributes/ColorMode
dataset /entry/instrument/detector/data -> /entry/data/data
group /entry/instrument/performance
dataset /entry/instrument/performance/timestamp
I tried the capture and the single mode. Always there is only one image in the file.
I used the commonPluginsExample.cmd with some modifications to be able to use the same file for all three cameras.
The Gather Plugin is from the first camera.
Jörn
Am Mittwoch, 19. Februar 2025, 17:35:20 Mitteleuropäische Normalzeit schrieb Mark Rivers:
> Hi Jörn,
> In principle NDPluginGather can do what you are asking. There are 2 restrictions:
> 1.
> All of the detectors must be running in the same IOC, i.e. the same process.
> 2.
> All of the detectors must be producing NDArrays with the same dimensions, data type, and attributes.
> The second restriction is due to the way the HDF5 plugin works. In Stream mode it saves a single dataset of dimensions [Nx, Ny, Nimages]. The datatype of that dataset and also the attribute datasets are determined by the first array it receives. All subsequent
arrays must be the same. If not, you should see an error at the IOC shell and on the OPI screen.
> If your setup meets these restrictions and you are still having problems, then please send screenshots of the Gather and HDF5 plugin screens.
> Mark
> ________________________________
> From: Tech-talk <
[email protected]> on behalf of Jörn Dreyer via Tech-talk <
[email protected]>
> Sent: Wednesday, February 19, 2025 2:21 AM
> To:
[email protected] <
[email protected]>
> Subject: Using NDPluginGather to collect NDArrays from multiple detectors?
> Hi,
> I would like to write the images from multiple detectors into a single file.
> Therefor I tried to setup an NDPluginGather and connected the Array ports to the asynArray's of the detectors.
> The output of this was connected to an NDPluginFileHDF5. But in the resulting HDF5 file was only one image.
> I gues I misunderstood the functionality of NDPluginGather.
> Looking at the documentation it seems as if it seems that it can only collect data from Plugins (Attributes).
> Is there a way to achieve that, or do I have to live with one file per detector?
> Regards
> Jörn
Dr. Jörn Dreyer
HIBEF DAQ + Controls
Institut für Strahlenpysik
Abt. FWKX
Tel: +49 351 260 3263
Fax: +49 351 260 123263
Helmholtz-Zentrum Dresden - Rossendorf e.V. (HZDR)
Bautzner Landstr. 400 | 01328 Dresden | Germany
Tel: +49 (0) 351 260 1234
http://www.hzdr.de
Vorstand: Prof. Dr. Sebastian M. Schmidt, Dr. Diana Stiller
Vereinsregister: VR 1693 beim Amtsgericht Dresden
