1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Subject: Run-away TCP-tx and TCP-rx
From: Matt Rippa via Tech-talk <tech-talk at aps.anl.gov>
To: Talk EPICS Tech <tech-talk at aps.anl.gov>
Date: Wed, 26 Feb 2025 00:19:13 -1000
Hi folks,
We have a relatively new EPICS 7 + PVAccess application on Linux details below.
I use MCoreUtils to manage 16 cores. I pin cpu's 3-15 and let the Linux kernel and unspecified threads have cpus 0-2 for housekeeping
I may have a flakey RJ-45. Randomly throughout the day yesterday I saw this in the logs:
Feb 24 17:18:14 hbfm2ts-lp2.hi.gemini.edu kernel: i40e 0000:1a:00.0 ens82f0: NIC Link is Down
Feb 24 17:18:17 hbfm2ts-lp2.hi.gemini.edu NetworkManager[1036]: <info>  [1740453497.6423] device (ens82f0): carrier: link connected
Feb 24 17:18:17 hbfm2ts-lp2.hi.gemini.edu kernel: i40e 0000:1a:00.0 ens82f0: NIC Link is Up, 1000 Mbps Full Duplex, Flow Control: TX
The symptom on my IOC was finding an uncontrolled proliferation of TCP-tx and TCP-rx threads. After just a few hours of ioc up time I counted 4800+ threads. These rouge TCP- threads are able to ignore the /etc/rtrules (attached below) and show up like this.
TCP-rx 0x7f6df0f8d9d0  1795781     20       0       OK       ? 0-2
TCP-tx 0x7f6df0fa8460  1795789     20       0       OK       ? 0-2
Notice the "?" in the Policy column.
When the issue shows up the PVAccess updates slow way down but don't completely stop. The 2 healthy TCP-rx and TCP-tx threads are properly running from what I can see and they're properly set with FIFO and assigned to cores 7 and 6:
TCP-tx 0x7f79e40220f0  2132240     20      20       OK    FIFO 6
TCP-rx 0x7f79e4021cc0  2132239     20      20       OK    FIFO 7
The full mcoreThreadShowAll is below. Anything we should pay attention to?
Thanks!
-Matt
4.18.0-513.18.1.rt7.320.el8_9.x86_64 #1 SMP PREEMPT_RT
[matt.rippa@hbfm2ts-lp2 epics-base]$ git submodule
+dead44c3cbe70b134766af13a56b571dbb40a278 .ci (v3.4.1-3-gdead44c)
7a2d264f2cb107bfd10adb23bc2b73d8323a79e4 modules/normativeTypes (6.0.1-3-g7a2d264)
+f1268adb8ecbacbd74bb66c172d02d9d427bedfd modules/pvAccess (7.1.7-2-gf1268adb)
+144f0228cc412d2dc1eaad7e09e310697d18532f modules/pvData (8.0.6-2-g144f022)
+f207e512d67addab79e33a00b712e3444228ba7c modules/pvDatabase (4.7.1-4-gf207e51)
949b3f63c2387bb92c1c22ca2f80f8d320805117 modules/pva2pva (1.4.1-1-g949b3f6)
8ed07fef96e41d35d47ab61276e29eb1a81e7fec modules/pvaClient (4.8.0-1-g8ed07fe)
[matt.rippa@hbfm2ts-lp2 epics-base]$ git lg -5
* 5dfc6caf3 - (1 year, 1 month ago) Accept should return SOCKET rather than int - Freddie Akeroyd (HEAD -> upstream-7, upstream/7.0)
* cb49bd013 - (12 months ago) Update ci-scripts to 3.4.1 - Ralph Lange
* 4720b61c1 - (1 year, 1 month ago) Move call to setThreadName() - Freddie Akeroyd
* 4383cf291 - (1 year ago) allow macros with defaults in dbLoadRecords without substitutions - Dirk Zimoch
* a6977ae73 - (1 year ago) Fix issue where VSCode makefile extension can delete files - Simon Rose
#!../../bin/linux-x86_64/m2ts
< envPaths
epicsEnvSet("IOC","iocm2ts")
epicsEnvSet("TOP","/home/matt.rippa/work/m2-cem-project/m2ts2")
epicsEnvSet("EPICS_BASE","/home/matt.rippa/work/vendor/epics-base")
epicsEnvSet("MCUtils","/home/matt.rippa/work/m2-cem-project/m2ts2/MCoreUtils")
epicsEnvSet("GCBRec","/home/matt.rippa/work/m2-cem-project/m2ts2/gcbCommandRecord")
cd "/home/matt.rippa/work/m2-cem-project/m2ts2"
epicsEnvSet("IOCSH_PS1","m2ts2> ")
epicsEnvSet("EPICS_PVA_ADDR_LIST","10.1.2.173")
epicsEnvSet("EPICS_PVA_SERVER_PORT","41366")
dbLoadDatabase "dbd/m2ts.dbd"
m2ts_registerRecordDeviceDriver pdbbase
MCoreUtils version 1.2.3-SNAPSHOT
MCoreUtils: Read 26 thread rule(s) from /etc/rtrules
MCoreUtils: Read 0 thread rule(s) from /root/.rtrules
## Load record instances
#dbLoadTemplate "db/user.substitutions"
#dbLoadRecords "db/m2tsVersion.db", "user=mrippa"
dbLoadRecords "db/AP323.db", "m2top="
#var mySubDebug 1
traceIocInit
iocInit will be traced
M2TSStartup
cd "/home/matt.rippa/work/m2-cem-project/m2ts2/iocBoot/iocm2ts"
iocInit
iocInit: Reached initHookAtIocBuild
Starting iocInit
iocInit: Reached initHookAtBeginning
< envPaths
#var mySubDebug 1
traceIocInit
M2TSStartup
iocInit
Starting iocInit
## EPICS R7.0.8.1-DEV
## Rev. R7.0.8-16-g5dfc6caf3c898b213c84-dirty
## Rev. Date Git: 2024-03-06 09:48:26 -0600
iocInit: Reached initHookAfterCallbackInit
iocInit: Reached initHookAfterCaLinkInit
iocInit: Reached initHookAfterInitDrvSup
iocInit: Reached initHookAfterInitRecSup
iocInit: Reached initHookAfterInitDevSup
iocInit: Reached initHookAfterInitDatabase
iocInit: Reached initHookAfterFinishDevSup
initPeriodic: Scan rate '.015 second' is not achievable.
iocInit: Reached initHookAfterScanInit
iocInit: Reached initHookAfterInitialProcess
iocInit: Reached initHookAfterCaServerInit
iocInit: Reached initHookAfterIocBuilt
iocInit: Reached initHookAtIocRun
iocInit: Reached initHookAfterDatabaseRunning
iocInit: Reached initHookAfterInterruptAccept
iocInit: Reached initHookAfterCaServerRunning
iocInit: Reached initHookAtEnd
iocInit: Reached initHookAfterIocRunning
m2ts2> mcoreThreadShowAll
           NAME       EPICS ID   LWP ID   OSIPRI  OSSPRI  STATE  POLICY CPUSET
         _main_       0x75b1d0  2989179      0       0       OK       ? ?
         errlog       0x775510  2989181     10      10       OK    FIFO 0-2
  TMpage1Writer       0x836ae0  2989182     87      86       OK    FIFO 5
TMwaveformWriter       0x831040  2989183     86      85       OK    FIFO 5
        TMTemps       0x8311e0  2989184     81      80       OK    FIFO 5
   TMTempEnable       0x831430  2989185     70      69       OK    FIFO 5
    AP323_ISR_1       0x8316f0  2989186     91      90       OK    FIFO 11
    AP323_ISR_2       0x831950  2989187     91      90       OK    FIFO 12
    AP323_ISR_0       0x831c00  2989188     91      90       OK    FIFO 10
M2MirrorControlT       0x831f80  2989189     90      89       OK    FIFO 13
   HSDataThread       0x832460  2989190     70      69       OK    FIFO 5
M2VibrationContr       0x832790  2989191     90      89       OK    FIFO 14
 SafetyShutdown       0x832c80  2989192     90      89       OK    FIFO 8
  StatusManager       0x832f50  2989193     89      88       OK    FIFO 5
         m2Init       0x833290  2989194     80      79       OK    FIFO 5
         taskwd       0x8488b0  2989195     10      10       OK    FIFO 0-2
     timerQueue       0x833df0  2989196     70      69       OK    FIFO 0-2
          cbLow       0x8440a0  2989197     59      58       OK    FIFO 0-2
       cbMedium       0x8336f0  2989198     64      63       OK    FIFO 0-2
         cbHigh       0x844fc0  2989199     71      70       OK    FIFO 0-2
       dbCaLink       0x8484d0  2989200     50      50       OK    FIFO 0-2
           PVAL       0x848580  2989201     50      50       OK    FIFO 0-2
      PDB-event       0x834f60  2989202     19      19       OK    FIFO 0-2
pvAccess-client        0x835ac0  2989203     35      35       OK    FIFO 3
UDP-rx 0.0.0.0:0       0x8432d0  2989204     50      50       OK    FIFO 6
UDP-rx 10.26.70.       0x843de0  2989205     50      50       OK    FIFO 6
UDP-rx 10.26.70.       0x83f2b0  2989206     50      50       OK    FIFO 6
UDP-rx 224.0.0.1       0x83fa20  2989207     50      50       OK    FIFO 6
       scanOnce       0x8407b0  2989208     68      67       OK    FIFO 0-2
        scan-10       0x840af0  2989209     65      64       OK    FIFO 5
         scan-5       0x840d40  2989210     66      65       OK    FIFO 5
         scan-2       0x840f90  2989211     67      66       OK    FIFO 5
         scan-1       0x8411e0  2989212     68      67       OK    FIFO 5
       scan-0.5       0x841430  2989213     69      68       OK    FIFO 5
       scan-0.2       0x841680  2989214     70      69       OK    FIFO 5
       scan-0.1       0x9c2500  2989215     71      70       OK    FIFO 5
     scan-0.015       0x9c2750  2989216     72      71       OK    FIFO 5
        CAS-TCP       0x9cb050  2989217     16      16       OK    FIFO 7
        CAS-UDP       0x9cb2a0  2989218     12      12       OK    FIFO 7
     CAS-beacon       0x9cb4f0  2989219     14      14       OK    FIFO 7
 ipToAsciiProxy 0x7fb8c400f7d0  2989220     10      10       OK    FIFO 0-2
    PVAS timers       0x9cbb20  2989221     25      25       OK    FIFO 0-2
     timerQueue 0x7fb8c400ff30  2989222     52      51       OK    FIFO 0-2
   TCP-acceptor       0x9cc6a0  2989223     50      50       OK    FIFO 6
        CAC-UDP 0x7fb8c40110b0  2989224     54      53       OK    FIFO 6
UDP-rx 0.0.0.0:0       0x9ed1f0  2989225     50      50       OK    FIFO 6
UDP-rx 10.26.70.       0xa2dca0  2989226     50      50       OK    FIFO 6
UDP-rx 10.26.70.       0xa2e0b0  2989227     50      50       OK    FIFO 6
UDP-rx 224.0.0.1       0xa4e7a0  2989228     50      50       OK    FIFO 6
m2tsStateTelemTh       0xa82520  2989229     90      89       OK    FIFO 3
    gcbCommandM       0xa8a890  2989230     81      80       OK    FIFO 9
     fastguider       0xaa7d90  2989231     89      88       OK    FIFO 13
   GCBProcessor       0xaa7ff0  2989233     84      83       OK    FIFO 3
         TCP-tx 0x7fb8680220f0  2989269     20      20       OK    FIFO 6
         TCP-rx 0x7fb868021cc0  2989268     20      20       OK    FIFO 7
UDP-rx 224.0.0.1 0x7fb848058a30  2990167     50      50       OK    FIFO 6
UDP-rx 10.26.70. 0x7fb848027c50  2990166     50      50       OK    FIFO 6
UDP-rx 10.26.70. 0x7fb848006a60  2990165     50      50       OK    FIFO 6
UDP-rx 0.0.0.0:0 0x7fb848068700  2990164     50      50       OK    FIFO 6
pvAccess-client  0x7fb8480062f0  2990163     35      35       OK    FIFO 3
/etc/rtrules:
# Format of each line:       name:policy:priority:affinity:pattern
# name      distinguishing tag
# policy    scheduling policy (first letter suffices, case independent, * = don't change)
# priority  scheduling priority (OSI units, + or - defines a relative change, * = don't change)
# affinity  CPU set (use , and - to specify ranges, * = don't change)
# pattern   regular _expression_ to match thread names against
# Intel(R) Xeon(R) Silver 4216 CPU @ 2.10GHz
errlog:f:10:4:errlog
m2Init:f:80:5:m2Init
HSDataT:f:70:5:HSDataThread
TMTempE:f:70:5:TMTempEnable
TMTemps:f:81:5:TMTemps
TMwfW:f:86:5:TMwaveformWriter
TMp1W:f:87:5:TMpage1Writer
StatMan:f:89:5:StatusManager
TCP-acc:f:*:6:TCP-acceptor.*
TCP-tx:f:*:6:TCP-tx.*
TCP-rx:f:*:7:TCP-rx.*
SSDTask:f:90:8:SafetyShutdown
gcbCommandM:f:81:9:gcbCommandM*
AP323_ISR_0:f:91:10:AP323_ISR_0
AP323_ISR_1:f:91:11:AP323_ISR_1
AP323_ISR_2:f:91:12:AP323_ISR_2
fastguider:f:89:13:fastguider
MCT1:f:90:13:M2MirrorControlT1
VCT1:f:90:14:M2VibrationControlT1
# The gcbCommandQueue is the GCBProcessor
gcbProc:f:84:3:GCBProcessor
# The Gui Status Record has is m2tsStateTelem
m2tsStateTelemTh:f:90:3:m2tsStateTelemTh
# pvaccess-client
pva-c:f:*:3:pvAccess-client
# set CAS threads to SCHED_RR on CPU 7
CAS-all:f:*:7:CAS-.*
# set CAC threads to SCHED_RR on CPU 6
CAC-all:f:*:6:CAC-.*
UDP-all:f:*:6:UDP-.*
# increase priority of all scan tasks by 5
scan:*:+5:5:scan-.*
Re: Run-away TCP-tx and TCP-rx Michael Davidsaver via Tech-talk
Prev: EPICS Spring 2026 Collaboration meeting location proposal Gaman Vojtěch via Tech-talk
Next: Re: [EXTERNAL] History of EPICS Richard Farnsworth via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Next: Re: Run-away TCP-tx and TCP-rx Michael Davidsaver via Tech-talk
ANJ, 26 Feb 2025 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
