I just attempted to reproduce your problem and I cannot.
TahoeU18:/corvette/usr/local/epics-devel/base-7.0.9> lsb_release -a
No LSB modules are available.
Description: Ubuntu 22.04.2 LTS
I just built base-7.0.9, and asyn. I am using the master branch of asyn, but there are only trivial changes since R4-45.
asyn built with no errors.
This is the output of ldd for the "test" IOC application:
TahoeU18:/corvette/home/epics/devel/asyn> ldd bin/linux-x86_64-ub22/test
linux-vdso.so.1 (0x00007ffd1a8b0000)
libtestSupport.so => /corvette/home/epics/devel/asyn-4-45/lib/linux-x86_64-ub22/libtestSupport.so (0x00007f78d1423000)
libasyn.so => /corvette/home/epics/devel/asyn-4-45/lib/linux-x86_64-ub22/libasyn.so (0x00007f78d135f000)
libdbRecStd.so.3.24.0 => /corvette/usr/local/epics-devel/base-7.0.9/lib/linux-x86_64-ub22/libdbRecStd.so.3.24.0 (0x00007f78d1315000)
libdbCore.so.3.24.0 => /corvette/usr/local/epics-devel/base-7.0.9/lib/linux-x86_64-ub22/libdbCore.so.3.24.0 (0x00007f78d1274000)
libCom.so.3.24.0 => /corvette/usr/local/epics-devel/base-7.0.9/lib/linux-x86_64-ub22/libCom.so.3.24.0 (0x00007f78d11ed000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f78d0fa8000)
libtirpc.so.3 => /lib/x86_64-linux-gnu/libtirpc.so.3 (0x00007f78d0f7a000)
libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f78d0d4e000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f78d0d2e000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f78d0c45000)
libca.so.4.14.5 => /corvette/usr/local/epics-devel/base-7.0.9/lib/linux-x86_64-ub22/libca.so.4.14.5 (0x00007f78d0bdb000)
libreadline.so.8 => /lib/x86_64-linux-gnu/libreadline.so.8 (0x00007f78d0b87000)
/lib64/ld-linux-x86-64.so.2 (0x00007f78d143e000)
libgssapi_krb5.so.2 => /lib/x86_64-linux-gnu/libgssapi_krb5.so.2 (0x00007f78d0b33000)
libtinfo.so.6 => /lib/x86_64-linux-gnu/libtinfo.so.6 (0x00007f78d0b01000)
libkrb5.so.3 => /lib/x86_64-linux-gnu/libkrb5.so.3 (0x00007f78d0a34000)
libk5crypto.so.3 => /lib/x86_64-linux-gnu/libk5crypto.so.3 (0x00007f78d0a05000)
libcom_err.so.2 => /lib/x86_64-linux-gnu/libcom_err.so.2 (0x00007f78d09ff000)
libkrb5support.so.0 => /lib/x86_64-linux-gnu/libkrb5support.so.0 (0x00007f78d09f1000)
libkeyutils.so.1 => /lib/x86_64-linux-gnu/libkeyutils.so.1 (0x00007f78d09ea000)
libresolv.so.2 => /lib/x86_64-linux-gnu/libresolv.so.2 (0x00007f78d09d6000)
When I run that "test" IOC it works fine:
TahoeU18:/corvette/home/epics/devel/asyn/iocBoot/ioctest> ../../bin/linux-x86_64-ub22/test st.cmd
dbLoadDatabase("../../dbd/test.dbd")
test_registerRecordDeviceDriver(pdbbase)
#drvAsynIPPortConfigure("A","164.54.9.90:4001",0,0,0)
asynSetAutoConnectTimeout(.5)
echoDriverInit("A",0.05,0,0)
asynSetTraceIOMask("A",-1,2)
#asynSetTraceMask("A",-1,255)
asynOctetConnect("AA","A",0)
interposeInterfaceInit("interpose","A",0)
asynOctetWriteRead("AA","Test A addr=0 count 1")
asynOctetWriteRead("AA","Test A addr=0 count 2")
echoDriverInit("B",0.05,0,1)
#asynSetTraceMask("B",-1,0xff)
#asynSetTraceMask("B",0,0xff)
#asynSetTraceMask("B",1,0xff)
asynSetTraceIOMask("B",-1,0x2)
asynSetTraceIOMask("B",0,0x2)
asynSetTraceIOMask("B",1,0x2)
asynOctetConnect("B0","B",0)
asynOctetWriteRead("B0","B0 count 1")
asynOctetConnect("B1","B",1)
asynOctetWriteRead("B1","B1 count 1")
addrChangeDriverInit("MA","A",0)
dbLoadRecords("../../db/asynRecord.db","P=asyn,R=Record_PA_A0,PORT=A,ADDR=0,OMAX=0,IMAX=0")
dbLoadRecords("../../db/test.db","P=test,R=Client,PORT=A,A=0")
dbLoadRecords("../../db/asynRecord.db","P=asyn,R=Record_PB_A-1,PORT=B,ADDR=-1,OMAX=0,IMAX=0")
dbLoadRecords("../../db/asynRecord.db","P=asyn,R=Record_PB_A0,PORT=B,ADDR=0,OMAX=0,IMAX=0")
dbLoadRecords("../../db/test.db","P=test,R=Client,PORT=B,A=0")
dbLoadRecords("../../db/asynRecord.db","P=asyn,R=Record_PB_A1,PORT=B,ADDR=1,OMAX=0,IMAX=0")
dbLoadRecords("../../db/test.db","P=test,R=Client,PORT=B,A=1")
dbLoadRecords("../../db/asynRecord.db","P=asyn,R=Record,PORT=A,ADDR=0,OMAX=0,IMAX=0")
dbLoadRecords("../../db/asynRecord.db","P=asyn,R=Record_PMA_A-1,PORT=MA,ADDR=-1,OMAX=0,IMAX=0")
dbLoadRecords("../../db/asynRecord.db","P=asyn,R=Record_PMA_A0,PORT=MA,ADDR=0,OMAX=0,IMAX=0")
dbLoadRecords("../../db/test.db","P=test,R=Client,PORT=MA,A=0")
dbLoadRecords("../../db/asynRecord.db","P=asyn,R=Record_PMA_A1,PORT=MA,ADDR=1,OMAX=0,IMAX=0")
dbLoadRecords("../../db/test.db","P=test,R=Client,PORT=MA,A=1")
dbLoadRecords("../../db/testBlock.db","P=test,R=Block,PORT=B,A=0,VAL= ")
dbLoadRecords("../../db/testBlock.db","P=test,R=Block,PORT=B,A=1,VAL= ")
dbLoadRecords("../../db/testBlock.db","P=test,R=BlockAll,PORT=B,A=0,VAL=blockAll")
dbLoadRecords("../../db/testBlock.db","P=test,R=BlockAll,PORT=B,A=1,VAL=blockAll")
## Rev. Date Git: 2025-02-21 17:31:33 -0600
B multiDevice:Yes canBlock:Yes autoConnect:Yes
enabled:Yes connected:Yes numberConnects 1
nDevices 2 nQueued 0 blocked:No
asynManagerLock:No synchronousLock:No
exceptionActive:No exceptionUsers 1 exceptionNotifys 0
traceMask:0x1 traceIOMask:0x2 traceInfoMask:0x1
asynOctet pinterface 0x7ff7417d24a0 drvPvt 0x5583dedd6e20
asynCommon pinterface 0x7ff7417de120 drvPvt 0x5583dedd42c0
asynOctet pinterface 0x5583dedd6338 drvPvt 0x5583dedd42c0
addr 0 autoConnect Yes enabled Yes connected Yes exceptionActive No
exceptionActive No exceptionUsers 1 exceptionNotifys 0
addr 1 autoConnect Yes enabled Yes connected Yes exceptionActive No
echoDriver. multiDevice:Yes connected:Yes delay = 0.050000
device 0 connected:Yes nchars = 0
device 1 connected:Yes nchars = 0
asynOctetWriteRead("B0","B0 count 2")
asynOctetWriteRead("B1","B1 count 2")
asynOctetWriteRead("B0","B0 count 3")
asynOctetWriteRead("B1","B1 count 3")
Something seems wrong with your build, but I'm not sure what.
Sent: Thursday, March 6, 2025 2:19 PM
To: Mark Rivers <[email protected]>
Subject: Re: Request for Help with EPICS Asyn Build Issues
Yes, I'm referring to the testioc IOC shipped with asyn. My apologies for the confusion. I ended up being able to compile asyn, and was curious about the errors I ran into.
However, more pressingly the testioc seems to be failing. I have solved a few issues on my own, and now am getting a segmentation fault when attempting to run the iocBoot/testioc/st.cmd
jonathanhai@FRIDAY:~/epics-base/support/asyn-R4-45$ make -s clean
jonathanhai@FRIDAY:~/epics-base/support/asyn-R4-45$ make -sj
vxi11core_xdr.c: In function ‘xdr_Device_Link’:
vxi11core_xdr.c:11:27: warning: unused variable ‘buf’ [-Wunused-variable]
11 | register int32_t *buf;
vxi11core_xdr.c: In function ‘xdr_Device_AddrFamily’:
vxi11core_xdr.c:21:27: warning: unused variable ‘buf’ [-Wunused-variable]
21 | register int32_t *buf;
vxi11core_xdr.c: In function ‘xdr_Device_Flags’:
vxi11core_xdr.c:31:27: warning: unused variable ‘buf’ [-Wunused-variable]
31 | register int32_t *buf;
vxi11core_xdr.c: In function ‘xdr_Device_ErrorCode’:
vxi11core_xdr.c:41:27: warning: unused variable ‘buf’ [-Wunused-variable]
41 | register int32_t *buf;
vxi11core_xdr.c: In function ‘xdr_Device_Error’:
vxi11core_xdr.c:51:27: warning: unused variable ‘buf’ [-Wunused-variable]
51 | register int32_t *buf;
vxi11core_xdr.c: In function ‘xdr_Create_LinkResp’:
vxi11core_xdr.c:116:27: warning: unused variable ‘buf’ [-Wunused-variable]
116 | register int32_t *buf;
vxi11core_xdr.c: In function ‘xdr_Device_WriteParms’:
vxi11core_xdr.c:132:27: warning: unused variable ‘buf’ [-Wunused-variable]
132 | register int32_t *buf;
vxi11core_xdr.c: In function ‘xdr_Device_WriteResp’:
vxi11core_xdr.c:150:27: warning: unused variable ‘buf’ [-Wunused-variable]
150 | register int32_t *buf;
vxi11core_xdr.c: In function ‘xdr_Device_ReadResp’:
vxi11core_xdr.c:229:27: warning: unused variable ‘buf’ [-Wunused-variable]
229 | register int32_t *buf;
vxi11core_xdr.c: In function ‘xdr_Device_ReadStbResp’:
vxi11core_xdr.c:243:27: warning: unused variable ‘buf’ [-Wunused-variable]
243 | register int32_t *buf;
vxi11core_xdr.c: In function ‘xdr_Device_GenericParms’:
vxi11core_xdr.c:255:27: warning: unused variable ‘buf’ [-Wunused-variable]
255 | register int32_t *buf;
vxi11core_xdr.c: In function ‘xdr_Device_EnableSrqParms’:
vxi11core_xdr.c:334:27: warning: unused variable ‘buf’ [-Wunused-variable]
334 | register int32_t *buf;
vxi11core_xdr.c: In function ‘xdr_Device_LockParms’:
vxi11core_xdr.c:348:27: warning: unused variable ‘buf’ [-Wunused-variable]
348 | register int32_t *buf;
vxi11core_xdr.c: In function ‘xdr_Device_DocmdResp’:
vxi11core_xdr.c:445:27: warning: unused variable ‘buf’ [-Wunused-variable]
445 | register int32_t *buf;
../../asyn/asynRecord/asynRecord.c: In function ‘reportError’:
../../asyn/asynRecord/asynRecord.c:2045:9: warning: ‘__builtin_strncpy’ specified bound 100 equals destination size [-Wstringop-truncation]
2045 | strncpy(pasynRecPvt->old.errs, pasynRec->errs, ERR_SIZE);
../../asyn/asynRecord/asynRecord.c: In function ‘process’:
../../asyn/asynRecord/asynRecord.c:2056:9: warning: ‘__builtin_strncpy’ specified bound 100 equals destination size [-Wstringop-truncation]
2056 | strncpy(pasynRecPvt->old.errs, pasynRec->errs, ERR_SIZE);
../../asyn/asynRecord/asynRecord.c: In function ‘connectDevice’:
../../asyn/asynRecord/asynRecord.c: In function ‘asynCallbackProcess’:
../../asyn/asynRecord/asynRecord.c: In function ‘special’:
../testBroadcastAsyn.c: In function ‘main’:
../testBroadcastAsyn.c:58:6: warning: ignoring return value of ‘system’ declared with attribute ‘warn_unused_result’ [-Wunused-result]
58 | system("netstat -a | grep 164.54.160.255 | grep -v ca-2");
../testBroadcastNoAsyn.c: In function ‘main’:
../testBroadcastNoAsyn.c:54:5: warning: ignoring return value of ‘system’ declared with attribute ‘warn_unused_result’ [-Wunused-result]
54 | system("netstat -a | grep 164.54.160.255 | grep -v ca-2");
Here is a log of what I get from attempting to run the ioc, including valgrind and gdb outputs.
jonathanhai@FRIDAY:~/epics-base/support/asyn-R4-45/iocBoot/ioctest$ ldd ../../bin/linux-x86_64/test
linux-vdso.so.1 (0x00007b8f3eecf000)
libtestSupport.so => /home/jonathanhai/epics-base/support/asyn-R4-45/lib/linux-x86_64/libtestSupport.so (0x00007b8f3eeb3000)
libasyn.so => /home/jonathanhai/epics-base/support/asyn-R4-45/lib/linux-x86_64/libasyn.so (0x00007b8f3edf2000)
libdbRecStd.so.3.24.0 => /home/jonathanhai/epics-base/lib/linux-x86_64/libdbRecStd.so.3.24.0 (0x00007b8f3eda9000)
libdbCore.so.3.24.0 => /home/jonathanhai/epics-base/lib/linux-x86_64/libdbCore.so.3.24.0 (0x00007b8f3ed07000)
libCom.so.3.24.0 => /home/jonathanhai/epics-base/lib/linux-x86_64/libCom.so.3.24.0 (0x00007b8f3ec83000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007b8f3ea00000)
libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007b8f3e600000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007b8f3ec44000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007b8f3e917000)
libca.so.4.14.5 => /home/jonathanhai/epics-base/lib/linux-x86_64/libca.so.4.14.5 (0x00007b8f3e8ae000)
libreadline.so.8 => /lib/x86_64-linux-gnu/libreadline.so.8 (0x00007b8f3e5ab000)
/lib64/ld-linux-x86-64.so.2 (0x00007b8f3eed1000)
libtinfo.so.6 => /lib/x86_64-linux-gnu/libtinfo.so.6 (0x00007b8f3e577000)
jonathanhai@FRIDAY:~/epics-base/support/asyn-R4-45/iocBoot/ioctest$ file ../../bin/linux-x86_64/test
../../bin/linux-x86_64/test: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=b9bf61c168c9947cffd98e78b0aab53d8e2fb0d7,
with debug_info, not stripped
jonathanhai@FRIDAY:~/epics-base/support/asyn-R4-45/iocBoot/ioctest$ gdb --args ../../bin/linux-x86_64/test st.cmd
GNU gdb (Ubuntu 15.0.50.20240403-0ubuntu1) 15.0.50.20240403-git
Copyright (C) 2024 Free Software Foundation, Inc.
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Type "show copying" and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
Find the GDB manual and other documentation resources online at:
Type "apropos word" to search for commands related to "word"...
Reading symbols from ../../bin/linux-x86_64/test...
Starting program: /home/jonathanhai/epics-base/support/asyn-R4-45/bin/linux-x86_64/test st.cmd
This GDB supports auto-downloading debuginfo from the following URLs:
Enable debuginfod for this session? (y or [n]) y
Debuginfod has been enabled.
To make this setting permanent, add 'set debuginfod enabled on' to .gdbinit.
Downloading separate debug info for system-supplied DSO at 0x7ffff7ff1000
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff7ff3000 in ?? ()
#0 0x00007ffff7ff3000 in ?? ()
#1 0x0000000000000002 in ?? ()
#2 0x00007fffffffdde5 in ?? ()
#3 0x00007fffffffde2b in ?? ()
#4 0x0000000000000000 in ?? ()
A debugging session is active.
Inferior 1 [process 12683] will be killed.
jonathanhai@FRIDAY:~/epics-base/support/asyn-R4-45/iocBoot/ioctest$ valgrind --track-origins=yes ../../bin/linux-x86_64/test st.cmd
==12691== Memcheck, a memory error detector
==12691== Copyright (C) 2002-2022, and GNU GPL'd, by Julian Seward et al.
==12691== Using Valgrind-3.22.0 and LibVEX; rerun with -h for copyright info
==12691== Command: ../../bin/linux-x86_64/test st.cmd
==12691== Process terminating with default action of signal 11 (SIGSEGV)
==12691== Bad permissions for mapped region at address 0x108000
==12691== at 0x108000: ??? (in /home/jonathanhai/epics-base/support/asyn-R4-45/bin/linux-x86_64/test)
==12691== by 0x1FFEFFFD8A: ???
==12691== by 0x1FFEFFFDA6: ???
==12691== in use at exit: 0 bytes in 0 blocks
==12691== total heap usage: 0 allocs, 0 frees, 0 bytes allocated
==12691== All heap blocks were freed -- no leaks are possible
==12691== For lists of detected and suppressed errors, rerun with: -s
==12691== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 0 from 0)
Segmentation fault (core dumped)
jonathanhai@FRIDAY:~/epics-base/support/asyn-R4-45/iocBoot/ioctest$ ../../bin/linux-x86_64/test st.cmd
Thanks for your assistance.
Jonathan Hai
Researcher/Tech Monkey
CNBL | Department of Physics and Astronomy
McMaster University
Sapere Aude
Hi Jonathon,
Initially, after compiling Asyn and running the IOC (st.cmd), many Asyn-related commands
(asynReport,
asynOctetWriteRead, etc.) were missing.
What IOC are you referring to? One that is included in asyn, or a separate IOC you are building outside of asyn? If the problem is an IOC outside of asyn, have you verified that the test IOCs inside
of asyn build OK?
Please do the following at the top-level of asyn and send the complete output.
make -s clean
make -sj
You said the following:
I am encountering persistent build issues while compiling Asyn (asyn-R4-43) with EPICS Base 7.0.9 on Ubuntu 22.04 (Linux x86_64). Despite multiple attempts to resolve the issues, the
build process fails with the following error:
(asynReport,
Those 2 statements seem contradictory, since first you said you could not build asyn, and then you said that after building asyn you got run-time errors when running the IOC.
I have not tested base 7.0.9, but I have successfully built asyn on 7.0.8 and I think it is unlikely that base 7.0.9 is causing the problem.
I am encountering persistent build issues while compiling Asyn (asyn-R4-43) with EPICS Base 7.0.9 on Ubuntu 22.04 (Linux x86_64). Despite multiple attempts to resolve the issues, the build
No rule to make target '../%', needed by 'asynRecord.dbd'.
I would appreciate any guidance on how to fix this issue. Below is a summary of what I have tried so far.
Initial Build Attempt (Missing Asyn Support)
(asynReport,
The error messages included:
· ERROR: Command asyn_registerRecordDeviceDriver not found.
· ERROR: Can't open include file "asynRecord.dbd".
· ERROR: Can't open include file "devEpics.dbd".
Verified Asyn libraries (libasyn.so) and DBD files (asynRecord.dbd,
devEpics.dbd) exist.
Modified
testApp/src/Makefile to include:
Ensured
st.cmd includes:
· dbLoadDatabase("../../dbd/asyn.dbd")
· dbLoadDatabase("../../dbd/asynRecord.dbd")
· dbLoadDatabase("../../dbd/devEpics.dbd")
· asyn_registerRecordDeviceDriver(pdbbase)
Rebuilt Asyn using:
The missing commands were still not found.
asynRecord.dbd and
devEpics.dbd were still missing or not properly recognized.
Missing
asynRecord.dbd and
devEpics.dbd
Despite confirming that
asynRecord.dbd exists (ls -l ~/epics-base/support/asyn/asyn-R4-43/dbd/),
the build system could not find it.
make install failed with:
· No rule to make target '../%', needed by 'asynRecord.dbd'.
Verified
INSTALL_DBD in
configure/CONFIG:
· INSTALL_DBD += asyn.dbd
· INSTALL_DBD += asynRecord.dbd
· INSTALL_DBD += devEpics.dbd
Checked
configure/CONFIG for
INSTALL_LOCATION:
· INSTALL_LOCATION = $(TOP)
Ensured
asyn.dbd includes:
· include "asynRecord.dbd"
Rebuilt Asyn and the IOC:
The same error persisted:
Debugging
Makefile Dependency Issues
The wildcard rule (%) in the Makefile might be broken or misconfigured.
Checked
asyn/Makefile for incorrect
% rules:
· ../%: $(INSTALL_LOCATION)/%
o
Commented it out to prevent the broken rule:
o #../%: $(INSTALL_LOCATION)/%
Rebuilt everything:
Still getting the same error.
Request for Help
Key Questions
1.
Why is the build system trying to use
../% as a dependency for
asynRecord.dbd?
2.
Is there a known issue with Asyn (asyn-R4-43) and EPICS Base compatibility?
3.
How can I properly ensure
asynRecord.dbd is installed and recognized?
4.
Are there specific EPICS build settings I should check to resolve this?
System & Build Environment
EPICS Base: 7.0.9
Asyn Version: asyn-R4-43
OS: Ubuntu 22.04 (Linux x86_64)
Compiler: gcc (Ubuntu 11.3.0-1ubuntu1~22.04)
I appreciate any insights or suggestions on how to resolve this issue.
Jonathan Hai
McMaster University
Sapere Aude
