1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: SNL question to the community
From: "Vodopivec, Klemen via Tech-talk" <[email protected]>
Date: Sun, 9 Mar 2025 22:50:18 +0000
Ralph,
Having a generic solution/API for EPICS process database like you and Michael propose would be beneficial for other projects as well, ie PyDevice where a lot of people now use PyEpics when interfacing with PVs inside same or remote IOCs.
-- Klemen
From: Tech-talk <[email protected]> on behalf of Pierrick M Hanlet via Tech-talk <[email protected]>
Date: Saturday, March 8, 2025 at 11:29
AM
To: [email protected] <[email protected]>
Subject: [EXTERNAL] Re: SNL question to the community
Thanks Ralph, I essentially have the same model as you see it; I'm glad to know that I'm not out on a limb in my thinking. I like Michael's idea, analogous to aSub, which made its way into base. Cheers, Pierrick On 3/8/25 04:23, Ralph Lange
Thanks Ralph,
Cheers,
Pierrick
On 3/8/25 04:23, Ralph Lange via Tech-talk wrote:
> [EXTERNAL] – This message is from an external sender
> Hi Pierrick,
> This has been discussed in the past... on Tech-Talk and at meetings.
> Ben, the current author/maintainer of SNL/SNC, has stated on tech-talk
> that he doesn't see an easy straightforward way to integrate SNL with
> PVA without fundamentally changing the concepts of SNL.
> But. SNL/SNC is the best-tested and best-documented EPICS module.
> (Most of that is Ben's work. Kudos!) It is in use at almost every
> installation and nothing could replace it any time soon. It will not
> go away.
> I see the sequencer's strength in implementing small state machines,
> close to the device, running on an IOC. Ramps, switch-on/switch-off
> procedures, slow feedback-type applications, that genre.
> Complicated procedure sequencers, driving whole sub-systems using
> 1000s of PVs across many IOCs - that's the scope for high-level
> operations sequencers like oac-tree. For these applications, SNL/SNC
> doesn't scale well enough and has conceptual limitations.
> With Channel Access slowly being sunset, the current SNL/SNC as a pure
> CA client will not be maintainable forever.
> The more I think about it, the more I like Michael Davidsaver's idea:
> Make SNC/SNL directly work with the EPICS process database, with no
> Channel Access involved. That would cut down the code base,
> significantly reduce complexity, and put the sequencer exactly where
> it belongs - inside the IOC, complementing the process database as a
> local tool to implement finite state machines. If state machines need
> access to resources outside the IOC, local proxy records can do the
> remote connection - using standard PVA or CA provided by Base for
> cross-IOC links.
> Cheers,
> ~Ralph
-- Pierrick Hanlet
+1-630-840-5555 office
+1-312-687-4980 mobile
=== "Whether you think you can or think you can't, either way, you're correct" -- Henry Ford
Re: SNL question to the community Ralph Lange via Tech-talk
SNL question to the community Pierrick M Hanlet via Tech-talk
Re: SNL question to the community Pierrick M Hanlet via Tech-talk
Prev: Re: SNL question to the community Pierrick M Hanlet via Tech-talk
Next: Monitoring events over CA doesn't work when using nameserver and old IOCs Vodopivec, Klemen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Next: Re: SNL question to the community Ralph Lange via Tech-talk
