Hi Jonathon,
What version of EPICS base are you using? Have you modified anything in it?
Last week you reported a problem building asyn. I could not reproduce your problem, and then Andrew Johnson suggested that you move support/ so it was not under EPICS base. Did you do that, and did it fix
your problem?
I am not aware of anyone else reporting a problem with lexer, so there must be something different with your installation. Is this Ubuntu 22? I built base successfully on that last week, including seq and
sscan with base 7.0.9.
On Behalf Of Jonathan Hai via Tech-talk
Sent: Monday, March 10, 2025 12:39 PM
To: [email protected]
Subject: Re: Issues Installing Galil EPICS Drivers – sscan & seq Dependencies Not Building
Subject: Follow-up: Issues Installing Galil EPICS Drivers –
seq &
sscan Still Not Building
I appreciate the help so far regarding my
Galil motor driver installation issues. I've followed the advice given and have attempted multiple fixes, but I’m still unable to get the required dependencies (seq and
sscan) to build.
I need to install the Galil motor drivers, but the build fails because
sscan does not compile. -
sscan fails because
scanProg.o is missing, which (I believe) needs
seq to be installed. -
seq fails to build due to a missing
lexer.c, which should be generated from
lexer.l by
e_flex. -
e_flex is broken on my system, preventing
lexer.c from being created.
Steps I Have Taken So Far
1. Verified
e_flex and
antelope Exist in EPICS Base
Both
e_flex and
antelope are present in
/home/jonathanhai/epics-base/bin/linux-x86_64/. -
Running
antelope --version
works, but running e_flex --help
produces an error:
· /home/jonathanhai/epics-base/bin/linux-x86_64/e_flex: unknown flag '-'
2. Checked for
lexer.l in
seq
lexer.l is present in
/home/jonathanhai/support/seq/src/snc/, but running
e_flex fails with:
· /home/jonathanhai/epics-base/bin/linux-x86_64/e_flex: could not create
Running
e_flex manually gives:
· /home/jonathanhai/epics-base/bin/linux-x86_64/e_flex: can't open skeleton file DEFAULT_SKELETON_FILE
3. Checked for
flex.skl (Skeleton File Required by
e_flex)
· find ~/epics-base -name "flex.skl"
returns no results, meaning this file is missing.
· /home/jonathanhai/epics-base/configure/os/Linux/flex.skl: No such file or directory
4. Installed System
flex and
bison as an Alternative
· sudo apt install flex bison
flex version:
2.6.4 -
bison version:
3.8.2
Tried running system
flex manually:
· cd ~/support/seq/src/snc
· flex -o lexer.c lexer.l
o lexer.l:1: premature EOF
· cd ~/epics-base
· make clean
· make
No change,
e_flex still does not work.
Current Issues & Questions
It fails with "unknown flag '-'" when run manually.
It also reports "can't open skeleton file DEFAULT_SKELETON_FILE" when used.
Should I be specifying a
FLEX_SKEL environment variable?
Why is
lexer.l failing with "premature EOF" when running
flex?
Could
lexer.l be corrupted or incomplete? -
If so, can I manually download a working version?
Is there a way to bypass
e_flex and manually create
lexer.c?
If I download a pre-generated
lexer.c, will the build proceed?
Would switching to an older version of
seq help?
If so, which version would you recommend?
I really appreciate any further guidance on this! Thanks again for your time.
When you build epics base, that generates base/bin/…./antelope and e_flex, so basically yacc and (f)lex.
Do you have the base/bin/HOST_ARCH folder on your PATH?
Then it should find those when building the other modules
