1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: areaDetector build system question
From: Abdalla Ahmad via Tech-talk <[email protected]>
To: "[email protected]" <[email protected]>, Jörn Dreyer <[email protected]>
Date: Sun, 16 Mar 2025 06:44:05 +0000
Here at SESAME, we build the used AD modules outside their tree just by modifying the configure/RELEASE file of any module, this is necessary for our RPM packaging. An example here is the RELEASE file we use to build ADCore:
#RELEASE Location of external products
# Run "gnumake clean uninstall install" in the application
# top directory each time this file is changed.
# -include $(TOP)/../configure/RELEASE_LIBS_INCLUDE
# -include $(TOP)/RELEASE.local
# -include $(TOP)/configure/RELEASE.local
ASYN = /opt/epics/support/asyn
ADSUPPORT = /opt/epics/support/areaDetector/support
EPICS_BASE = /opt/epics/base
WITH_BITSHUFFLE=YES
WITH_BLOSC=YES
WITH_GRAPHICSMAGICK=YES
WITH_HDF5=YES
WITH_JPEG=YES
WITH_NETCDF=YES
WITH_NEXUS=YES
WITH_SZIP=YES
WITH_TIFF=YES
WITH_ZLIB=YES
BITSHUFFLE_EXTERNAL=NO
BLOSC_EXTERNAL=NO
GRAPHICSMAGICK_EXTERNAL=NO
HDF5_EXTERNAL=NO
JPEG_EXTERNAL=NO
NETCDF_EXTERNAL=NO
NEXUS_EXTERNAL=NO
SZIP_EXTERNAL=NO
TIFF_EXTERNAL=NO
XML2_EXTERNAL=NO
ZLIB_EXTERNAL=NO
More release files can be seen in the project’s repository: https://github.com/AbdallaDalleh/epics-rpm-spec
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME
From: Tech-talk <[email protected]> On Behalf Of Johnson, Andrew N. via Tech-talk
Sent: Thursday, March 13, 2025 7:43 PM
To: Jörn Dreyer <[email protected]>; [email protected]
Subject: Re: areaDetector build system question
Hi Jörn,
At APS we use Sumo to build AreaDetector (including ADCore and ADSupport), many of the standard plugins as external modules, and many IOCs which use these. I suggested changes to the AreaDetector build system to make that work, although my PR has bit-rotted somewhat in the 3-4 years since I last worked on it. Our local AreaDetector version has some additional changes that aren’t in the PR, but the plugins don’t require any modification IIRC.
Here is the configure/MODULES file from our camera IOC area, showing that it is possible to do this:
$ cat configure/MODULES
    "extra": [
        "ADCORE=$(AREA_DETECTOR)/ADCore",
        "ADSUPPORT=$(AREA_DETECTOR)/ADSupport"
    "module": [
        "ADARAVIS:2.2.1-C2-1",
        "ADGENICAM:1.10-C2-1",
        "ADPOINTGREY:2.9-C2-1",
        "ADSPINNAKER:3.3-C2-1",
        "AREA_DETECTOR:3.12.1-C2-2",
        "ASYN:4.42-C2-2",
        "AUTOSAVE:5.10.2-C2-1",
        "BASE:7.0.6.1-C2-3",
        "BUSY:1.7.3-C2-1",
        "CALC:3.7.4-C2-1",
        "IOCSTATS:3.2.0-C2-2",
        "IOCSTD:4.5.0-C2-1",
        "NDDRIVERSTDARRAYS:1.4-C2-1",
        "SEQ:2.2.9-C2-1",
        "SSCAN:2.11.5-C2-1",
        "ZLIB:1.2.11-C2-1"
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 3/12/25, 11:21 PM, "Tech-talk" <[email protected]> wrote:
is it possible to build an areaDetector module outside of the tree?
Background:
I have an areaDetector driver for a special camera that I would like to use in a setup using sumo.
I have sumo setup to to build all the dependencies for areaDetector.  I would like to get my camera code included to be alble to use
it in multiple ioc configurations.
My driver compiles if added inside the areaDetector tree, but as a normal EPICS module it fails. Has anybody achieved this?
It look very much that my CONFIG_SITE.local file is not read and thus the relevant configuration is missed.
Jörn
Re: areaDetector build system question Jörn Dreyer via Tech-talk
Re: areaDetector build system question Johnson, Andrew N. via Tech-talk
Prev: RE: Link error in MRF event system due to reference clock glitch Abdalla Ahmad via Tech-talk
Next: RE: Thermo Fischer FHT 6020 Radiation Monitor Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: areaDetector build system question Johnson, Andrew N. via Tech-talk
Next: Re: areaDetector build system question Jörn Dreyer via Tech-talk
