Hello Alex,
the ‘USE_POSIX_THREAD_PRIORITY_SCHEDULING = NO’' is an EPICS thing.
I don't know exactly what this does as I have never used it with RTEMS.
I think that cancels out the whole point of a priority-based system ;-)
All your jobs have a very low priority 253 (in RTEMS) and priority 2 in Posix.
Based on my gut feeling, I would recommend setting back to USE_POSIX_THREAD_PRIORITY_SCHEDULING=YES and then
in rtems_init for POSIX_Init() to set the priority high. You can use the code element I sent to you in the last tech-talk-reply.
Then all the interrupt handlers will also get a high priority and I assume that the crashes will also go away.
Would you like to try that?
Good luck,
Heinz
> On 20. Mar 2025, at 12:50, Wells, Alex (DLSLtd,RAL,LSCI) <[email protected]> wrote:
> Hi Heinz,
> Thank you for the information. There's definitely something fishy going on with the thread priorities somewhere; it seems that everything is being started with the same priority.
> I will also note that we are building RTEMS with "USE_POSIX_THREAD_PRIORITY_SCHEDULING = NO". This appears to be required, as we use EPICS Mutexes in an interrupt context, and if we leave this set to "YES" we see a crashes. Could this be related to the oddities below?
smime.p7s
Description: S/MIME cryptographic signature
- Re: [EXTERNAL] Re: Channel Access performance with RTEMS on MVME5500 Kasemir, Kay via Tech-talk
- Channel Access performance with RTEMS on MVME5500 Wells, Alex (DLSLtd,RAL,LSCI) via Tech-talk
- Re: Channel Access performance with RTEMS on MVME5500 Michael Davidsaver via Tech-talk
- Re: Channel Access performance with RTEMS on MVME5500 Wells, Alex (DLSLtd,RAL,LSCI) via Tech-talk
- Re: Channel Access performance with RTEMS on MVME5500 Heinz Junkes via Tech-talk
Re: Thermo Fischer FHT 6020 Radiation Monitor Chandler, Brendan via Tech-talk
<2025>
2026
<2025>
2026
