Hey Mark,
Thanks for that and sorry for overlooking that part in the common plugins file.
Three small follow-up questions regarding the plugins:
1. Is there a direct way to get the current background image into a StdArray, so I can display it on the panel?
2. The profile PVs from the stats module contain the Y information for the plot, is there also an array which I can use for the x pv? (so an array from 0:DimX/Y)
3. And connected to 2.: does one of the plugins provide the option to scale the pixel/dimensions to mm, so also all cacluclated stats etc are in mm?
Cheers
eddy
-----Ursprüngliche Nachricht-----
Von: Mark Rivers <[email protected]>
Gesendet: Freitag, 21. März 2025 16:55
An: Blomley, Edmund (IBPT) <[email protected]>; [email protected]
Betreff: RE: Areadetector Plugin Enable/Disable Issue and Design Question
Hi Eddy,
I am quite sure that the weird _RBV behavior is due to these errors you see after iocInit:
callbackRequest: cbLow ring buffer full
You can eliminate those by adding this line before iocInit. It is already present at the end of commonPlugins.cmd if you use that.
# Set the callback queue size to 5000, up from default of 2000 in base.
# This can be needed to avoid errors "callbackRequest: cbLow ring buffer full".
callbackSetQueueSize(5000)
-----Original Message-----
Sent: Friday, March 21, 2025 9:55 AM
To: Mark Rivers <[email protected]>; [email protected]
Subject: AW: Areadetector Plugin Enable/Disable Issue and Design Question
Hey Mark,
That should definitely not be happening, I have never heard of that issue before.
Just to be sure it is not a problem with the GUI please test it as follows:
• In one terminal window run the following camonitor command where the * is replaced by your actual prefix
camonitor *:Proc1:EnableCallbacks *:Proc1:EnableCallbacks_RBV
• In a second terminal window run caput
caput *:Proc1:EnableCallbacks 1
caput *:Proc1:EnableCallbacks 0
So here is the terminal 1 (fresh after IOC restart):
$ caput *:Proc1:EnableCallbacks 1
Old : *:Proc1:EnableCallbacks Disable
New : *:Proc1:EnableCallbacks Enable
$caput *:EnableCallbacks 0
Old : *:Proc1:EnableCallbacks Enable
New : *:Proc1:EnableCallbacks Disable
$ caput *:Proc1:EnableCallbacks 0
And terminal 2 (first two lines are before the first caput after IOC init):
*:Proc1:EnableCallbacks 2025-03-21 15:37:01.331762 Disable *:Proc1:EnableCallbacks_RBV <undefined> Disable UDF INVALID *:Proc1:EnableCallbacks 2025-03-21 15:37:20.323116 Enable *:Proc1:EnableCallbacks_RBV 2025-03-21 15:37:20.323176 Disable *:Proc1:EnableCallbacks 2025-03-21 15:37:24.247508 Disable *:Proc1:EnableCallbacks_RBV 2025-03-21 15:37:24.247585 Enable STATE MINOR *:Proc1:EnableCallbacks 2025-03-21 15:37:29.191775 Enable *:Proc1:EnableCallbacks_RBV 2025-03-21 15:37:29.191858 Disable *:Proc1:EnableCallbacks 2025-03-21 15:37:35.575135 Disable *:Proc1:EnableCallbacks_RBV 2025-03-21 15:37:35.575210 Enable STATE MINOR
The plugin "works"/ is enabled as long as the *:Proc1:EnableCallbacks is 1.
The last few lines during IOC init:
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 41665, cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
2025-03-21T15:37:01.336 Using dynamically assigned TCP port 43249.
# Create autosave files for IOCStats
makeAutosaveFileFromDbInfo("iocStats_settings_kara_slm", "autosaveFields_pass0") create_monitor_set("auto_settings_kara_slm.req", 60) create_monitor_set("iocStats_settings_kara_slm.req", 60)
epics> iocStats_settings_kara_slm.sav: 63 of 63 PV's connected
auto_settings_kara_slm.sav: 360 of 360 PV's connected
epics>
but there are no new errors once initialized. But looking at the logs I wonder if this might be an issue, because our camera server has two network connections, one dedicated to the cameras and one to the rest of the accelerator network, but I am not sure if that explains the inverted behaviour for the set and readback value? We use this setup for years, but maybe now with the plugins and callbacks this creates issues which did not manifest beforehand?
Cheers
eddy
smime.p7s
Description: S/MIME cryptographic signature
- Re: Areadetector Plugin Enable/Disable Issue and Design Question Mark Rivers via Tech-talk
- RE: Areadetector Plugin Enable/Disable Issue and Design Question Pearson, Matthew via Tech-talk
- Areadetector Plugin Enable/Disable Issue and Design Question Blomley, Edmund (IBPT) via Tech-talk
- AW: Areadetector Plugin Enable/Disable Issue and Design Question Blomley, Edmund (IBPT) via Tech-talk
- RE: Areadetector Plugin Enable/Disable Issue and Design Question Mark Rivers via Tech-talk
<2025>
2026
<2025>
2026
