1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: RE: Areadetector Plugin Enable/Disable Issue and Design Question
From: "Pearson, Matthew via Tech-talk" <[email protected]>
To: "Blomley, Edmund (IBPT)" <[email protected]>, Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 24 Mar 2025 13:59:28 +0000
Hi Eddy,
	Three small follow-up questions regarding the plugins:
	1. Is there a direct way to get the current background image into a StdArray, so I can display it on the panel?
If you're talking about the background array saved in the processing plugin, I don't think there is a direct way. However, one workaround is to have a dedicated stdArray plugin enabled when the background image is acquired, which is listening to the Asyn port of the processing plugin. Then you can disable that stdArray plugin so it will not process again, but the plugin will still serve the background array over channel access so it can be seen on a GUI. This enable/disable cycle could be automated as part of the process to acquire a background array.
Alternatively, the background array can also be a TIFF file, which could simply be opened by an image viewer program when needed.
	2. The profile PVs from the stats module contain the Y information for the plot, is there also an array which I can 	use for the x pv? (so an array from 0:DimX/Y)
The stats plugin already contains both the X and Y profile plots (averaged profiles and also at a specific X and Y coordinate).
	3. And connected to 2.: does one of the plugins provide the option to scale the pixel/dimensions to mm, so also all 	cacluclated stats etc are in mm?
I think that's something a GUI would do. The GUI would display the axis labels in terms of mm. It's been a long time since I used anything other than CS-Studio, but in terms of CS-Studio this would be done by setting the Image widget x_axis.minimum/maximum and y_axis.minimum/maximum properties. Note, this would also change how the ROI parameters and cross-hair parameters are set. However this wouldn't change any of the calculated statistics in the IOC, for example the centroid position - you'd need to do that on the IOC side via a few extra 'calc' records.
Cheers,
Matt
-----Ursprüngliche Nachricht-----
Von: Mark Rivers <[email protected]>
Gesendet: Freitag, 21. März 2025 16:55
An: Blomley, Edmund (IBPT) <[email protected]>; [email protected]
Betreff: RE: Areadetector Plugin Enable/Disable Issue and Design Question
Hi Eddy,
I am quite sure that the weird _RBV behavior is due to these errors you see after iocInit:
callbackRequest: cbLow ring buffer full
You can eliminate those by adding this line before iocInit.  It is already present at the end of commonPlugins.cmd if you use that.
# Set the callback queue size to 5000, up from default of 2000 in base.
# This can be needed to avoid errors "callbackRequest: cbLow ring buffer full".
callbackSetQueueSize(5000)
-----Original Message-----
Sent: Friday, March 21, 2025 9:55 AM
To: Mark Rivers <[email protected]>; [email protected]
Subject: AW: Areadetector Plugin Enable/Disable Issue and Design Question
Hey Mark,
	That should definitely not be happening, I have never heard of that issue before.
	Just to be sure it is not a problem with the GUI please test it as follows:
	• In one terminal window run the following camonitor command where the * is replaced by your actual prefix
      		camonitor *:Proc1:EnableCallbacks *:Proc1:EnableCallbacks_RBV
	• In a second terminal window run caput
      		caput *:Proc1:EnableCallbacks 1
	      caput *:Proc1:EnableCallbacks 0
So here is the terminal 1 (fresh after IOC restart):
$ caput *:Proc1:EnableCallbacks 1
Old : *:Proc1:EnableCallbacks Disable
New : *:Proc1:EnableCallbacks Enable
$caput *:EnableCallbacks 0
Old : *:Proc1:EnableCallbacks Enable
New : *:Proc1:EnableCallbacks Disable
$ caput *:Proc1:EnableCallbacks 0
And terminal 2 (first two lines are before the first caput after IOC init):
*:Proc1:EnableCallbacks 2025-03-21 15:37:01.331762 Disable *:Proc1:EnableCallbacks_RBV <undefined> Disable UDF INVALID *:Proc1:EnableCallbacks 2025-03-21 15:37:20.323116 Enable *:Proc1:EnableCallbacks_RBV 2025-03-21 15:37:20.323176 Disable *:Proc1:EnableCallbacks 2025-03-21 15:37:24.247508 Disable *:Proc1:EnableCallbacks_RBV 2025-03-21 15:37:24.247585 Enable STATE MINOR *:Proc1:EnableCallbacks 2025-03-21 15:37:29.191775 Enable *:Proc1:EnableCallbacks_RBV 2025-03-21 15:37:29.191858 Disable *:Proc1:EnableCallbacks 2025-03-21 15:37:35.575135 Disable *:Proc1:EnableCallbacks_RBV 2025-03-21 15:37:35.575210 Enable STATE MINOR
The plugin "works"/ is enabled as long as the *:Proc1:EnableCallbacks is 1.
The last few lines during IOC init:
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 41665, cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
2025-03-21T15:37:01.336 Using dynamically assigned TCP port 43249.
# Create autosave files for IOCStats
makeAutosaveFileFromDbInfo("iocStats_settings_kara_slm", "autosaveFields_pass0") create_monitor_set("auto_settings_kara_slm.req", 60) create_monitor_set("iocStats_settings_kara_slm.req", 60)
epics> iocStats_settings_kara_slm.sav: 63 of 63 PV's connected
auto_settings_kara_slm.sav: 360 of 360 PV's connected
epics>
but there are no new errors once initialized. But looking at the logs I wonder if this might be an issue, because our camera server has two network connections, one dedicated to the cameras and one to the rest of the accelerator network, but I am not sure if that explains the inverted behaviour for the set and readback value? We use this setup for years, but maybe now with the plugins and callbacks this creates issues which did not manifest beforehand?
Cheers
eddy
Areadetector Plugin Enable/Disable Issue and Design Question Blomley, Edmund (IBPT) via Tech-talk
Re: Areadetector Plugin Enable/Disable Issue and Design Question Mark Rivers via Tech-talk
AW: Areadetector Plugin Enable/Disable Issue and Design Question Blomley, Edmund (IBPT) via Tech-talk
RE: Areadetector Plugin Enable/Disable Issue and Design Question Mark Rivers via Tech-talk
Prev: RE: How to add KeySight Laser interferometer to EPICS Freddie Akeroyd - STFC UKRI via Tech-talk
Next: Question About ADEuresys XML File Support for the EPICS IOC Kim, Kuktae via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Re: Areadetector Plugin Enable/Disable Issue and Design Question Ralph Lange via Tech-talk
Next: Registration, call for abstracts, and other deadlines - Spring 2025 EPICS Collaboration Meeting Ivan Finch - STFC UKRI via Tech-talk
