1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: AW: Areadetector Plugin Enable/Disable Issue and Design Question
From: "Blomley, Edmund \(IBPT\) via Tech-talk" <[email protected]>
Date: Mon, 24 Mar 2025 07:51:43 +0000
Hey Mark,
> First want to check that setting callbackSetQueueSize(5000) does indeed fix
> the problem with incorrect RBV callback values? Is that true?
For the first IOC (with 6 cameras) setting "callbackSetQueueSize(5000)" fixed
the "callbackRequest: cbLow ring buffer full" errors and the _RBV are now
consistent with the set value instead of inverted.
For a second IOC instance with more cameras (14, but in this case only one
will ever be active at the same time) 5000 was not enough, but with a queue
size of around 15000 the callbeackRequest error disappeared.
What is the consequence of increasing the queue size? Would it be better to
split up the IOC into multiple IOCs with less cameras each?
Yes, it fixed the  "callbackRequest: cbLow ring buffer full" errors and the
_RBV are now consistent with the set value instead of inverted.
Cheers
eddy
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: Areadetector Plugin Enable/Disable Issue and Design Question Ralph Lange via Tech-talk
Areadetector Plugin Enable/Disable Issue and Design Question Blomley, Edmund (IBPT) via Tech-talk
Re: Areadetector Plugin Enable/Disable Issue and Design Question Mark Rivers via Tech-talk
AW: Areadetector Plugin Enable/Disable Issue and Design Question Blomley, Edmund (IBPT) via Tech-talk
RE: Areadetector Plugin Enable/Disable Issue and Design Question Mark Rivers via Tech-talk
Prev: Re: Areadetector Plugin Enable/Disable Issue and Design Question Mark Rivers via Tech-talk
Next: Re: Areadetector Plugin Enable/Disable Issue and Design Question Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
