1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: RE: Streams format converters question ( how to convert 10100 to 1.0E+00, 10011 to 1.0E-11)
From: Zimoch Dirk via Tech-talk <[email protected]>
To: Peter Sx <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 27 Mar 2025 15:24:31 +0000
Hi Susheng
Nice format. People always invent something new.
I would try to pre-process the format with regular _expression_ substitution (%#/regex/subs/) so that it fits the normal %f format.
We need to keep one digit, then insert a period dot, then take the next digit, insert an “e”, convert a 0 to a – and a 1 to a + and then copy the next two digits. The sign magic is the nasty part.
This may do the trick: (I have not tested it yet)
in "%#/([0-9])([0-9])0([0-9][0-9])/\1.\2e-\3/%#/([0-9])([0-9])1([0-9][0-9])/\1.\2e+\3/%f";
Output too?
From: Tech-talk <[email protected]> On Behalf Of Peter Sx via Tech-talk
Sent: Donnerstag, 27. März 2025 14:54
To: [email protected]
Cc: [email protected]
Subject: Streams format converters question ( how to convert 10100 to 1.0E+00, 10011 to 1.0E-11)
Hi EPICS Specialists:
I've run into a problem converting data to exponential readings. I have a device that outputs messages and data in the same channel. I have separated the readings from messages with data by using the following records and protocol.
I am wondering whether I can add some arguments in the protocol and convert the data through calcout, but I am new to Streams and can't figure out the details.
Data format:  ppsee (p.p * 10see):
Symbols   Description
pp        Mantissa of the reading (1.0 to 9.9)
s         Sign of the exponent (0 = negative, 1 = positive)
ee        Exponent (00 to 11)
record(ai, "$(Sys)$(Dev)Ch1_Reading")
    field(DESC, "Ch1 Reading")
    field(DTYP, "stream")
    field(INP, "@Televac.proto get_Ch1_reading($(Sys)$(Dev)Ch1message) $(PORT)")
    field(SCAN, ".1 second")
record(stringin, "$(Sys)$(Dev)Ch1message")
get_Ch1_reading {
    out "S101";
    in "%f";
    @mismatch {in "%(\$1)39c";}
Current channel readback examples:
[sxin@eic-905-pc01 ~]$ caget 905-HC1-Televac:Ch5_Reading    device panel reading 1.0E-11
905-HC1-Televac:Ch5_Reading    10011
[sxin@eic-905-pc01 ~]$ caget 905-HC1-Televac:Ch6message
905-HC1-Televac:Ch6message     OFF
Thank you!
Susheng
Streams format converters question ( how to convert 10100 to 1.0E+00, 10011 to 1.0E-11) Peter Sx via Tech-talk
Prev: Streams format converters question ( how to convert 10100 to 1.0E+00, 10011 to 1.0E-11) Peter Sx via Tech-talk
Next: Re: Structured PVs archiving and archived data retrieval problem Aleš Kete via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Next: Connect to IOC in container from another host in different network, via CA Gateway Gonzalez, Jose Carlos via Tech-talk
