Hi Pedro,
Can you please post a concrete example of a record configuration that used to work in EPICS 3.14.x or 3.15.x and no longer does in EPICS 7.0.x? If you can simplify that to a small number of soft records in
each of 2 IOCs that would help us understand and replicate your specific issue. I don’t immediately recognize it as anything that we’ve explicitly changed, but we might have broken your use-case by mistake. Once we see the specific problem we may be able to
suggest alternative configurations.
- Andrew
Complexity comes for free, Simplicity you have to work for.
I am writing to get your advice on managing system unavailability within EPICS 7. In our current operational model we can switch between different instruments seamlessly if one encounters
an issue and becomes unavailable. This strategy was effective in previous EPICS versions. However, after migrating to EPICS 7, records reading data from systems that are no longer available stop processing, even if we don't rely on the data from that particular
system to continue observing. The issue arises because broken CA links set the alarm severity (SEVR) to INVALID, the alarm status (STAT) to LINK, and halt the record processing of the downstream records. We want a mechanism to override the alarm severity when
an instrument becomes unresponsive, ideally with minimal operator intervention.
We have identified three potential ways of achieving this:
Maximize Severity Attribute: The idea was to use this attribute to prevent the alarm propagation, but it seems that it does not provide what we need.
SIMM Field: Setting the SIMM field to YES enables the record to continue processing without being affected by the INVALID alarm status. The SVAL field
can be used to define a simulation value and the SIMS field specifies the simulation mode alarm severity (NO_ALARM in our case). We have tested this approach and it seems to work well. STAT is set to SIMM and the downstream records process without problems.
DISA Field: Making DISA=DISV disables the record. The DISS field defines the record's disable severity (e.g. NO_ALARM). This approach also seems to work.
STAT is set to DISABLE and the downstream records process without problems as well.
The SIMM field seems to be the most promising option. I would greatly appreciate your insights on this, as well as any alternative approaches that you might suggest.
Thank you,
Pedro
- Re: alarm handling in EPICS 7 Pedro Gigoux via Tech-talk
- alarm handling in EPICS 7 Pedro Gigoux via Tech-talk
Re: Connect to IOC in container from another host in different network, via CA Gateway Gonzalez, Jose Carlos via Tech-talk
<2025>
2026
<2025>
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
