1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: alarm handling in EPICS 7
From: Pedro Gigoux via Tech-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Date: Fri, 28 Mar 2025 15:31:25 -0300
On Fri, 28 Mar 2025 at 14:19, Johnson, Andrew N. <[email protected]> wrote:
Hi Pedro,
Can you please post a concrete example of a record configuration that used to work in EPICS 3.14.x or 3.15.x and no longer does in EPICS 7.0.x? If you can simplify that to a small number of soft records in each of 2 IOCs that would help us understand and replicate your specific issue. I don’t immediately recognize it as anything that we’ve explicitly changed, but we might have broken your use-case by mistake. Once we see the specific problem we may be able to suggest alternative configurations.
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 3/28/25, 3:51PM, "Tech-talk" <[email protected]> wrote:
Hello,
I am writing to get your advice on managing system unavailability within EPICS 7. In our current operational model we can switch between different instruments seamlessly if one encounters an issue and becomes unavailable. This strategy was effective in previous EPICS versions. However, after migrating to EPICS 7, records reading data from systems that are no longer available stop processing, even if we don't rely on the data from that particular system to continue observing. The issue arises because broken CA links set the alarm severity (SEVR) to INVALID, the alarm status (STAT) to LINK, and halt the record processing of the downstream records. We want a mechanism to override the alarm severity when an instrument becomes unresponsive, ideally with minimal operator intervention.
We have identified three potential ways of achieving this:
·         Maximize Severity Attribute: The idea was to use this attribute to prevent the alarm propagation, but it seems that it does not provide what we need.
·         SIMM Field: Setting the SIMM field to YES enables the record to continue processing without being affected by the INVALID alarm status. The SVAL field can be used to define a simulation value and the SIMS field specifies the simulation mode alarm severity (NO_ALARM in our case). We have tested this approach and it seems to work well. STAT is set to SIMM and the downstream records process without problems.
·         DISA Field: Making DISA=DISV disables the record. The DISS field defines the record's disable severity (e.g. NO_ALARM). This approach also seems to work. STAT is set to DISABLE and the downstream records process without problems as well.
The SIMM field seems to be the most promising option. I would greatly appreciate your insights on this, as well as any alternative approaches that you might suggest.
Thank you,
Pedro
Attachment: schematic.png
Description: PNG image
Attachment: test.db
Description: Binary data
Re: alarm handling in EPICS 7 Maren Purves via Tech-talk
alarm handling in EPICS 7 Pedro Gigoux via Tech-talk
Re: alarm handling in EPICS 7 Johnson, Andrew N. via Tech-talk
Prev: Re: alarm handling in EPICS 7 Johnson, Andrew N. via Tech-talk
Next: Re: alarm handling in EPICS 7 Maren Purves via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
