1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: RE: SNL assign to field of PV
To: "Madden, Timothy J." <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 1 Apr 2025 22:43:53 +0000
Hi Tim,
Strictly speaking PVs don’t have fields, records have fields.  PVs are basically record fields.  So any place where you assign a PV to an SNL variable you can use an field name like .HIHI.
Here is an example where the .PROC field is used. https://github.com/epics-modules/ip/blob/1b39fea28d483e6ea008afafd96b0f471f169b42/ipApp/src/Keithley2kDMM_mf40.st#L142
Here is an example where the .RVAL field is used: https://github.com/epics-modules/ip/blob/1b39fea28d483e6ea008afafd96b0f471f169b42/ipApp/src/Oxford_CS800.st#L146
From: Tech-talk <[email protected]> On Behalf Of Madden, Timothy J. via Tech-talk
Sent: Tuesday, April 1, 2025 5:00 PM
To: [email protected]
Subject: SNL assign to field of PV
Tech Talk:
Is there a way to set or get specific fields of a PV from a SNL program? Example, say we want to pvPut
the HIHI field of a PV.  I see ways to get/put VAL by assign and pvGet()/pvPut(). But I don't see a way to get other fields of the PV.
Tim Madden
APS
Re: SNL assign to field of PV Madden, Timothy J. via Tech-talk
Prev: SNL assign to field of PV Madden, Timothy J. via Tech-talk
Next: Re: SNL assign to field of PV Madden, Timothy J. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
