1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Problems setting up MCA BrukerQM100
From: "Lott, Eva via Tech-talk" <[email protected]>
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 28 Apr 2025 14:48:32 +0000
Hi Mark,
Many thanks for the fast response! That makes sense, I'm nearly there with the following st.cmd:
                < envPaths
                epicsEnvSet(STARTUP, $(TOP)\iocBoot\$(IOC))
                dbLoadDatabase("..\..\dbd\mcaBrukerQM100.dbd", 0, 0)
                mcaBrukerQM100_registerRecordDeviceDriver(pdbbase)
                BrukerQM100Config(L0, "edx", "redacted_password", "Local server", 1)
                # =========== Works after manually adding "$(BUSY)/dbd/busySupport.dbd" to Makefile ==========================
                dbLoadRecords("..\..\mcaApp\Db\mca.db","P=XFLASH:,M=mca1,NCHAN=1024,DTYP=asynMCA,INP=@asyn(L0)")
                dbLoadRecords("$(ASYN)\db\asynRecord.db","P=XFLASH:,R=L0,PORT=L0,ADDR=0,OMAX=256,IMAX=256")
                # ======== init the ioc ========
                iocInit()
                # < ..\save_restore.cmd
                # ======== save settings every thirty seconds
                # create_monitor_set("auto_settings.req",30,"P=XFLASH:")
1)
The error I get with this is
       (BrukerQM100Config) Unable to find function OpenClient
       (BrukerQM100Config) Unable to find function SendRCLCommand
       (BrukerQM100Config) Unable to find function ReadSpectrum
       (BrukerQM100Config) Unable to find function GetSpectrum
       (roentecServer) Unable to find function StartSpectrumMeasurement
       (roentecServer) Unable to find function StartSpectrumLifeTimeMeasurement
       (roentecServer) Unable to find function StartSpectrumCounterMeasurement
       (roentecServer) Unable to find function StopSpectrumMeasurement
... which I assume is because I compiled for 64 bit and the Makefile specification is
        BIN_INSTALLS_WIN32 += RTPCI.dll
However this happens when trying to use the 64 bit control driver too. I'm assuming that the 64 bit driver is currently unsupported?
2)
RontecXFlash.db requires the asynOctet interface on the given port. I assume this db would have to be rewritten for the port from BrukerQM100Config?
Best wishes,
Eva
Sent: 28 April 2025 14:29:04
To: [email protected]; Lott, Eva
Hi Eva,
  • My problem is that this ioc doesn't link `drvIPPortConfigure` - I need an IP port for running `BrukerQM100Config`.
That is not correct.  The BrukerQM100Config command is defined here:
It is
               int BrukerQM100Config(const char *portName, char *user, char *passwd, char *server, int spuno)
The portName argument to that command is the name of the asyn port to create for this driver.  It is not the name of a drvAsynIPPort.
You don't need to build your IOC with drvAsynIPPort.  The IP communication is done using their DLL, not with asyn.
From: Tech-talk <[email protected]> on behalf of Lott, Eva via Tech-talk <[email protected]>
Sent: Monday, April 28, 2025 4:14 AM
To: [email protected] <[email protected]>
Subject: Problems setting up MCA BrukerQM100
I've been trying to set up an MCA ioc for the Bruker XFlash. I've built `mcaBrukerQM100.exe` (linking the hardware control dll), and am now in the process of writing the iocBoot for it.
My problem is that this ioc doesn't link `drvIPPortConfigure` - I need an IP port for running `BrukerQM100Config`. I've tried linking drvAsynIPPort.dbd in https://github.com/epics-modules/mca/blob/master/mcaApp/RontecSrc/mcaBrukerQM100Include.dbd to no avail.
Does anyone have any examples of a production mcaBrukerQM100 support module that I can look at?
Eva
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
Diese E-Mail kann vertrauliche und/oder rechtlich geschützte Informationen enthalten. Wenn Sie diese E-Mail irrtümlich erhalten haben, informieren Sie bitte sofort den*die Absender*in und vernichten Sie diese Mail. Das unerlaubte Kopieren, die Veröffentlichung sowie die unbefugte Weitergabe dieser Mail ist nicht gestattet.
This email may contain confidential and/or proprietary information. If you have received this e-mail in error, please inform the sender immediately and destroy this e-mail. Unauthorized copying, publishing or distribution of this e-mail is not permitted.
Postadresse:
14109 Berlin
Deutschland
RE: Problems setting up MCA BrukerQM100 Mark Rivers via Tech-talk
Problems setting up MCA BrukerQM100 Lott, Eva via Tech-talk
Re: Problems setting up MCA BrukerQM100 Mark Rivers via Tech-talk
Prev: Re: Frequent Retrieval Service Failures on Archiver Appliance Node Shankar, Murali via Tech-talk
Next: Waveform to single ai (again) Dr. Simon Friederich via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: Problems setting up MCA BrukerQM100 Mark Rivers via Tech-talk
Next: RE: Problems setting up MCA BrukerQM100 Mark Rivers via Tech-talk
