1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: FYI, the msys2 compilation approach is not working
From: "Wang, Andrew via Tech-talk" <[email protected]>
To: Freddie Akeroyd - STFC UKRI <[email protected]>, EPICS tech-talk <[email protected]>
Date: Mon, 28 Apr 2025 18:14:53 +0000
Update: So when I looked at the epics-base code on GitHub, the list_character_set function (https://github.com/epics-base/epics-base/blob/7.0/modules/libcom/src/flex/ccl.c) is different than the one in the tar.gz (https://epics-controls.org/download/base/base-7.0.4.1.tar.gz). I decided to compile the epics-base code instead, and it appears to be working so far.
Sent: Monday, April 28, 2025 11:04 AM
To: Freddie Akeroyd - STFC UKRI <[email protected]>; EPICS tech-talk <[email protected]>
Hi Freddie,
An update. The compiler is complaining about this block of code in modules/libcom/src/flex. I copied the logs at the bottom too.
void list_character_set(FILE *file, int cset[])
    int i;
    char *readable_form();
    putc( '[', file );
    for ( i = 0; i < csize; ++i )
        if ( cset[i] )
            int start_char = i;
            putc( ' ', file );
            fputs( readable_form( i ), file );
            while ( ++i < csize && cset[i] )
            if ( i - 1 > start_char )
                /* this was a run */
                fprintf( file, "-%s", readable_form( i - 1 ) );
            putc( ' ', file );
    putc( ']', file );
../flex/ccl.c: In function 'list_character_set':
../flex/ccl.c:147:20: error: too many arguments to function 'readable_form'; expected 0, have 1
  147 |             fputs( readable_form( i ), file );
../flex/ccl.c:135:11: note: declared here
  135 |     char *readable_form();
../flex/ccl.c:154:39: error: too many arguments to function 'readable_form'; expected 0, have 1
  154 |                 fprintf( file, "-%s", readable_form( i - 1 ) );
Installing PERL_MODULES file ../../../../lib/perl/EPICS/macLib.pm
make[4]: *** No rule to make target 'ccl.obj', needed by 'e_flex.exe'.  Stop.
make[4]: Leaving directory '/c/Users/wang126/base-R7.0.4.1/modules/libcom/src/O.windows-x64-mingw'
make[3]: *** [../../../configure/RULES_ARCHS:58: install.windows-x64-mingw] Error 2
make[3]: Leaving directory '/c/Users/wang126/base-R7.0.4.1/modules/libcom/src'
make[2]: *** [../../configure/RULES_DIRS:85: src.install] Error 2
make[2]: Leaving directory '/c/Users/wang126/base-R7.0.4.1/modules/libcom'
make[1]: *** [../configure/RULES_DIRS:85: libcom.install] Error 2
make[1]: Leaving directory '/c/Users/wang126/base-R7.0.4.1/modules'
make: *** [configure/RULES_DIRS:85: modules.install] Error 2
From: Freddie Akeroyd - STFC UKRI <[email protected]>
Sent: Monday, April 28, 2025 10:39 AM
To: Freddie Akeroyd - STFC UKRI <[email protected]>; Wang, Andrew <[email protected]>; EPICS tech-talk <[email protected]>
I’ve just installed the default gcc for the “MSYS2 MSYS” terminal and i get the same result as you for a gcc -v, so it looks like you build is somehow picking up the “MSYS2 MSYS” environment rather than “MSYS2 MinGW 64bit”
Freddie
From: Tech-talk <[email protected]> On Behalf Of Freddie Akeroyd - STFC UKRI via Tech-talk
Sent: 28 April 2025 18:24
To: Wang, Andrew <[email protected]>; EPICS tech-talk <[email protected]>
Your gcc seems to be targetting    x86_64-pc-msys    whereas mine targets       x86_64-w64-mingw32      I think that may be the problem. For gcc -v I see
$ gcc -v
Using built-in specs.
COLLECT_GCC=C:\msys64\mingw64\bin\gcc.exe
COLLECT_LTO_WRAPPER=C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/14.2.0/lto-wrapper.exe
Target: x86_64-w64-mingw32
Configured with: ../gcc-14.2.0/configure --prefix=/mingw64 --with-local-prefix=/mingw64/local --buil
d=x86_64-w64-mingw32 --host=x86_64-w64-mingw32 --target=x86_64-w64-mingw32 --with-native-system-head
er-dir=/mingw64/include --libexecdir=/mingw64/lib --enable-bootstrap --enable-checking=release --wit
h-arch=nocona --with-tune=generic --enable-mingw-wildcard --enable-languages=c,lto,c++,fortran,ada,o
bjc,obj-c++,rust,jit --enable-shared --enable-static --enable-libatomic --enable-threads=posix --ena
ble-graphite --enable-fully-dynamic-string --enable-libstdcxx-filesystem-ts --enable-libstdcxx-time
--disable-libstdcxx-pch --enable-lto --enable-libgomp --disable-libssp --disable-multilib --disable-
rpath --disable-win32-registry --disable-nls --disable-werror --disable-symvers --with-libiconv --wi
th-system-zlib --with-gmp=/mingw64 --with-mpfr=/mingw64 --with-mpc=/mingw64 --with-isl=/mingw64 --wi
th-pkgversion='Rev3, Built by MSYS2 project' --with-bugurl=https://github.com/msys2/MINGW-packages/i
ssues --with-gnu-as --with-gnu-ld --disable-libstdcxx-debug --enable-plugin --with-boot-ldflags=-sta
tic-libstdc++ --with-stage1-ldflags=-static-libstdc++
Thread model: posix
Supported LTO compression algorithms: zlib zstd
gcc version 14.2.0 (Rev3, Built by MSYS2 project)
Sent: 28 April 2025 18:15
To: Akeroyd, Freddie (STFC,RAL,ISIS) <[email protected]>; EPICS tech-talk <[email protected]>
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-pc-msys/13.3.0/lto-wrapper.exe
Target: x86_64-pc-msys
Configured with: /c/S/B/src/gcc-13.3.0/configure --build=x86_64-pc-msys --prefix=/usr --libexecdir=/usr/lib --enable-bootstrap --enable-static --enable-shared --enable-shared-libgcc --enable-version-specific-runtime-libs --with-arch=nocona --with-tune=generic --disable-multilib --enable-__cxa_atexit --with-dwarf2 --enable-languages=c,c++,lto --enable-graphite --enable-threads=posix --enable-libatomic --enable-libgomp --disable-libitm --enable-libquadmath --enable-libquadmath-support --disable-libssp --disable-win32-registry --disable-symvers --with-gnu-ld --with-gnu-as --disable-isl-version-check --enable-checking=release --without-libiconv-prefix --without-libintl-prefix --with-system-zlib --enable-linker-build-id --enable-libstdcxx-filesystem-ts
Thread model: posix
gcc version 13.3.0 (GCC)
Sent: Monday, April 28, 2025 10:13 AM
The windows-x64 target is only for a visual studio windows build,  windows-x64-mingw is correct for MinGW. Can you just check that you ran this build from a “MSYS2 MinGW 64bit” window rather than a  “MSYS2 MSYS” terminal.  What does
    gcc -v
Show?
Freddie
From: Tech-talk <[email protected]> On Behalf Of Wang, Andrew via Tech-talk
Sent: 28 April 2025 17:38
To: EPICS tech-talk <[email protected]>
Subject: FYI, the msys2 compilation approach is not working
Hi all,
I’m following the instructions on this webpage for installing EPICS using msys2.
Everything worked fine up until the “Download and build EPICS Base” section. After running “export EPICS_HOST_ARCH=windows-x64-mingw”, I get the following errors. Do you suggest that I potentially change the architecture to windows-x64, rather than windows-x64-mingw?
../osi/os/WIN32/epicsTempFile.c: In function ‘epicsTempFile’:
../osi/os/WIN32/epicsTempFile.c:31:20: warning: implicit declaration of function ‘_tempnam’; did you mean ‘tempnam’? [-Wimplicit-function-declaration]
   31 |     char * pName = _tempnam("c:\\tmp", "epics");
      |                    tempnam
../osi/os/WIN32/epicsTempFile.c:31:20: warning: initialization of ‘char *’ from ‘int’ makes pointer from integer without a cast [-Wint-conversion]
../osi/os/WIN32/epicsTempFile.c:45:24: error: ‘_O_CREAT’ undeclared (first use in this function); did you mean ‘O_CREAT’?
   45 |         int openFlag = _O_CREAT | _O_EXCL | _O_RDWR |
      |                        O_CREAT
../osi/os/WIN32/epicsTempFile.c:45:24: note: each undeclared identifier is reported only once for each function it appears in
../osi/os/WIN32/epicsTempFile.c:45:35: error: ‘_O_EXCL’ undeclared (first use in this function); did you mean ‘O_EXCL’?
      |                                   O_EXCL
../osi/os/WIN32/epicsTempFile.c:45:45: error: ‘_O_RDWR’ undeclared (first use in this function); did you mean ‘O_RDWR’?
      |                                             O_RDWR
../osi/os/WIN32/epicsTempFile.c:46:13: error: ‘_O_SHORT_LIVED’ undeclared (first use in this function)
   46 |             _O_SHORT_LIVED | _O_BINARY | _O_TEMPORARY;
../osi/os/WIN32/epicsTempFile.c:46:30: error: ‘_O_BINARY’ undeclared (first use in this function); did you mean ‘O_BINARY’?
      |                              O_BINARY
../osi/os/WIN32/epicsTempFile.c:46:42: error: ‘_O_TEMPORARY’ undeclared (first use in this function)
../osi/os/WIN32/epicsTempFile.c:47:40: error: ‘_S_IWRITE’ undeclared (first use in this function); did you mean ‘S_IWRITE’?
   47 |         int fd = open(pName, openFlag, _S_IWRITE);
      |                                        S_IWRITE
../osi/os/WIN32/epicsTempFile.c:50:24: warning: implicit declaration of function ‘_fdopen’; did you mean ‘fdopen’? [-Wimplicit-function-declaration]
   50 |             pNewFile = _fdopen(fd, "w+b");
      |                        fdopen
../osi/os/WIN32/epicsTempFile.c:50:22: warning: assignment to ‘FILE *’ from ‘int’ makes pointer from integer without a cast [-Wint-conversion]
gcc             -D_MINGW -D__USE_MINGW_ANSI_STDIO      -O3   -Wall      -m64    -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/WIN32 -I../../../../include         -o ccl.obj -c ../flex/ccl.c
In file included from ../flex/flexdef.h:38,
                 from ../flex/ccl.c:29:
../osi/os/WIN32/osiUnistd.h:16:10: fatal error: direct.h: No such file or directory
   16 | #include <direct.h>
compilation terminated.
Purple ribbon awareness
Re: FYI, the msys2 compilation approach is not working Johnson, Andrew N. via Tech-talk
FYI, the msys2 compilation approach is not working Wang, Andrew via Tech-talk
RE: FYI, the msys2 compilation approach is not working Freddie Akeroyd - STFC UKRI via Tech-talk
RE: FYI, the msys2 compilation approach is not working Wang, Andrew via Tech-talk
Prev: RE: FYI, the msys2 compilation approach is not working Wang, Andrew via Tech-talk
Next: Re: FYI, the msys2 compilation approach is not working Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
