1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Use of elog inside Phoebus
From: Florian Feldbauer via Tech-talk <[email protected]>
To: [email protected]
Date: Tue, 29 Apr 2025 09:39:25 +0200
Hey all,
so my answer to Andrea is also visible for everyone else.
I wrote the elog client for Phoebus in 2020.
Some time later the abstract logbook API within Phoebus has been refactored but unfortunately I did not notice these changes.
By the time I noticed, I didn't have the time to work on this project as I'm working since several years mainly on the DAQ for our tracking detector instead of the detector control system.
When I build the first version of the elog client, I dug through the code to find the interfaces I had to implement and to find all the files I needed to modify.
I'm usually not programming in Java so it that was quiet a time consuming task for me.
Does some documentation exists, that explains how to write and integrate such plugins to Phoebus?
If someone could point me to such a documentation or maybe provide a simple example, I would try to find some time and update my elog client for the new phoebus version.
Cheers,
Florian
On 4/26/25 10:38, Andrea Celentano via Tech-talk wrote:
Dear colleagues,
I am trying to use the elog application inside Phoebus. The details I found about this are in these slides: https://indico.fhi-berlin.mpg.de/event/52/contributions/564/attachments/222/683/phoebus-elog-client.pdf
I did the following:
1. I compiled phoebus from scratch with maven (master from gitlab), adding the elog application to build.xml
    <ant dir="app/logbook/ui"/>
    <ant dir="app/logbook/elog"/>       —-> My addiction
    <ant dir="app/log-configuration"/>
2. I checked inside my elog installation to read the password:
 <password encoding="SHA256”>My password</password>
3. I added the following to my settings file:
org.phoebus.logbook/logbook_factory=elog
org.phoebus.logbook.ui/logbook_factory=elog
org.phoebus.elog.api/elog_url=http://my_elog_host:8080/Main
org.phoebus.elog.api/username=shift
org.phoebus.elog.api/password=My password
org.phoebus.elog.api/categories=Info, Problem, Shift summary, Data quality, Micromegas, ECAL, MasterTime, MSADC
org.phoebus.elog.api/types=
When I start Phoebus with ./phoebus.sh -settings my_settings.ini and I open the logbook, I get the following error:
2025-04-26 10:37:40 INFO [org.phoebus.logbook.olog.ui.LogEntryTableViewController] Single search: *
2025-04-26 10:37:40 SEVERE [org.phoebus.logbook.olog.ui.LogbookSearchJob] Failed to obtain logs
org.phoebus.logbook.LogbookException: java.lang.UnsupportedOperationException
at org.phoebus.logbook.LogClient.search(LogClient.java:494)
at org.phoebus.logbook.olog.ui.LogbookSearchJob.lambda$getRunnable$0(LogbookSearchJob.java:59)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
at java.base/java.lang.Thread.run(Thread.java:842)
Caused by: java.lang.UnsupportedOperationException
... 9 more
What I do not understand is why the “olog” app is referred to in this error, since I am not using it at all..
Bests,
Andrea Celentano
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
Re: Use of elog inside Phoebus Wang, Lin via Tech-talk
Use of elog inside Phoebus Andrea Celentano via Tech-talk
Prev: RE: Unable to mind .lib files after successfully compiling EPICS using mingw64 Wang, Andrew via Tech-talk
Next: Re: Handling Polling and CPU Bottleneck for Large Image Capture in areaDetector Kim, Kuktae via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Use of elog inside Phoebus Andrea Celentano via Tech-talk
Next: Re: Use of elog inside Phoebus Wang, Lin via Tech-talk
