1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Use of elog inside Phoebus
From: "Wang, Lin via Tech-talk" <[email protected]>
To: [email protected], "Florian Feldbauer" <[email protected]>
Date: Tue, 13 May 2025 14:39:11 +0800 (GMT+08:00)
Dear all,
It seems that a breaking change in 2021 caused the incompatibility issue, and I have created a PR which is trying to fix this issue.
https://github.com/ControlSystemStudio/phoebus/pull/3393
Although it works for me, it still need to be tested by other users, because the deployment of Elog is flexible and different deployments may behave differently.
If there is no Elog server available on hand, it can also be tested with the Elog official online demo with the following settings.ini,
https://elog.psi.ch/elogs/Linux%20Demo/
org.phoebus.logbook/logbook_factory=elog
org.phoebus.elog.api/elog_url=https://elog.psi.ch/elogs/Linux%20Demo/
org.phoebus.elog.api/categories=General, Hardware, Software, Network, Other
org.phoebus.elog.api/types=Routine, Software Installation, Problem Fixed, Configuration, Other
org.phoebus.elog.api/username=user
org.phoebus.elog.api/password=1234
Lin
-----Original Messages-----
From: "Florian Feldbauer via Tech-talk" <[email protected]>
Send time: Tuesday, 04/29/2025 15:39:25
Hey all,
so my answer to Andrea is also visible for everyone else.
I wrote the elog client for Phoebus in 2020.
Some time later the abstract logbook API within Phoebus has been refactored but unfortunately I did not notice these changes.
By the time I noticed, I didn't have the time to work on this project as I'm working since several years mainly on the DAQ for our tracking detector instead of the detector control system.
When I build the first version of the elog client, I dug through the code to find the interfaces I had to implement and to find all the files I needed to modify.
I'm usually not programming in Java so it that was quiet a time consuming task for me.
Does some documentation exists, that explains how to write and integrate such plugins to Phoebus?
If someone could point me to such a documentation or maybe provide a simple example, I would try to find some time and update my elog client for the new phoebus version.
Cheers,
Florian
On 4/26/25 10:38, Andrea Celentano via Tech-talk wrote:
Dear colleagues,
I am trying to use the elog application inside Phoebus. The details I found about this are in these slides: https://indico.fhi-berlin.mpg.de/event/52/contributions/564/attachments/222/683/phoebus-elog-client.pdf
I did the following:
1. I compiled phoebus from scratch with maven (master from gitlab), adding the elog application to build.xml
    <ant dir="app/logbook/ui"/>
    <ant dir="app/logbook/elog"/>       —-> My addiction
    <ant dir="app/log-configuration"/>
2. I checked inside my elog installation to read the password:
 <password encoding="SHA256”>My password</password>
3. I added the following to my settings file:
org.phoebus.logbook.ui/logbook_factory=elog
org.phoebus.elog.api/elog_url=http://my_elog_host:8080/Main
org.phoebus.elog.api/username=shift
org.phoebus.elog.api/password=My password
org.phoebus.elog.api/categories=Info, Problem, Shift summary, Data quality, Micromegas, ECAL, MasterTime, MSADC
When I start Phoebus with ./phoebus.sh -settings my_settings.ini and I open the logbook, I get the following error:
2025-04-26 10:37:40 INFO [org.phoebus.logbook.olog.ui.LogEntryTableViewController] Single search: *
2025-04-26 10:37:40 SEVERE [org.phoebus.logbook.olog.ui.LogbookSearchJob] Failed to obtain logs
org.phoebus.logbook.LogbookException: java.lang.UnsupportedOperationException
at org.phoebus.logbook.LogClient.search(LogClient.java:494)
at org.phoebus.logbook.olog.ui.LogbookSearchJob.lambda$getRunnable$0(LogbookSearchJob.java:59)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
at java.base/java.lang.Thread.run(Thread.java:842)
Caused by: java.lang.UnsupportedOperationException
... 9 more
What I do not understand is why the “olog” app is referred to in this error, since I am not using it at all..
Bests,
Andrea Celentano
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
Use of elog inside Phoebus Andrea Celentano via Tech-talk
Re: Use of elog inside Phoebus Florian Feldbauer via Tech-talk
Prev: Re: Is there an easy way to implement continuing EPICS logging while the console line is open? Maren Purves via Tech-talk
Next: Re: How to know which CA client(IP address) modified a PV Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: Use of elog inside Phoebus Florian Feldbauer via Tech-talk
Next: Re: Use of elog inside Phoebus Dr. Simon Friederich via Tech-talk
