1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Is there an easy way to implement continuing EPICS logging while the console line is open?
From: Maren Purves via Tech-talk <[email protected]>
To: Ralph Lange <[email protected]>
Date: Mon, 12 May 2025 15:54:10 -1000
Thanks Ralph, that looks promising!
Maren
On Mon, May 12, 2025 at 2:12 AM Ralph Lange via Tech-talk
<[email protected]> wrote:
> Hi Maren,
> Have a look at conserver (conserver . com)
> That's basically a daemon that grabs the serial, does the logging and - via its own TCP-based protocol - allows users to connect , disconnect, bump someone else, ...
> It also nicely hides differences between consoles (serial vs. soft IOC, different terminal server ports etc.).
> Maybe not an *easy* way, but definitely a *nice* way with other benefits.
> Cheers,
> ~Ralph
Is there an easy way to implement continuing EPICS logging while the console line is open? Maren Purves via Tech-talk
Re: Is there an easy way to implement continuing EPICS logging while the console line is open? Ralph Lange via Tech-talk
Prev: Re: How to know which CA client(IP address) modified a PV LiangChih Chiang via Tech-talk
Next: Re: Use of elog inside Phoebus Wang, Lin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Re: Is there an easy way to implement continuing EPICS logging while the console line is open? Ralph Lange via Tech-talk
Next: EPICS Support for NI-9223 Abdalla Ahmad via Tech-talk
