1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Is there an easy way to implement continuing EPICS logging while the console line is open?
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Mon, 12 May 2025 14:11:49 +0200
Hi Maren,
Have a look at conserver (conserver . com)
That's basically a daemon that grabs the serial, does the logging and - via its own TCP-based protocol - allows users to connect , disconnect, bump someone else, ...
It also nicely hides differences between consoles (serial vs. soft IOC, different terminal server ports etc.).
Maybe not an *easy* way, but definitely a *nice* way with other benefits.
Cheers,
~Ralph
Re: Is there an easy way to implement continuing EPICS logging while the console line is open? Maren Purves via Tech-talk
Prev: Is there an easy way to implement continuing EPICS logging while the console line is open? Maren Purves via Tech-talk
Next: Re: fedora 42 and makeBaseApp -t example Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: Re: Is there an easy way to implement continuing EPICS logging while the console line is open? Maren Purves via Tech-talk
