1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Is there an easy way to implement continuing EPICS logging while the console line is open?
From: Maren Purves via Tech-talk <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Mon, 12 May 2025 00:40:03 -1000
Hi all,
this may be a bit of a dinosaur question, and I can't post a lot of
system details because the archive is public.
Our telescope operators open the console serial lines when they start.
This is mostly because sometimes other things grab the ports and they
wouldn't be able to connect if they had to. They usually leave it
sitting at the console switch prompt, and while that is  the case
logging continues. However, when they actually connect to a console,
e.g. to reboot something, the logging stops - and they don't
necessarily know how to disconnect.
Is there an easy way to have the logging continue when the serial line
is open? (working on a stone age system (3.13.8) and with very little
support outside of here)
TIA,
Maren
Head of Instrument and Telescope Software (which is a bit of an
exaggeration because I'm half time and there is one person in my group
at this time who in my book is already overworked)
East Asian Observatory / JCMT
Re: Is there an easy way to implement continuing EPICS logging while the console line is open? Ralph Lange via Tech-talk
Prev: Re: fedora 42 and makeBaseApp -t example Heinz Junkes via Tech-talk
Next: Re: Is there an easy way to implement continuing EPICS logging while the console line is open? Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Re: fedora 42 and makeBaseApp -t example Ralph Lange via Tech-talk
