Hello Guobao,
>When using caPutLog,
to avoid the info be flushed in your IOC terminal output due to its max
line limit,
I am not aware this behavior exists. My IOC/caPutLog(version 3.5) doesn't output to terminal. Doesn't it just send log messages to a log server via TCP?
>you might want to redirect the output which you are
interested into an external server, and you can
always look back later. I use iocLogServer(in EPICS base libCom) to save the log messages into files.
>At APS, we are using logstash to save the info we are interested in.
Thanks for the info.
When using caPutLog, to avoid the info be flushed in your IOC terminal output due to its max line limit, you might want to redirect the output which you are interested into an external server, and you can
Guobao
I tried caPutLog and succeeded.
Need more time to configure the access security file to restrict what to log.
I can't find the document of the pvlogging module.
On Fri, May 9, 2025 at 6:16 PM Mercado, Ronaldo (DLSLtd,RAL,LSCI) <[email protected]>
wrote:
I have used pvlogging for this purpose.
https://github.com/DiamondLightSource/pvlogging
Ronaldo
caPutLog seems to be a satisfying solution. I will give it a try.
The log messages include host information as the following excerpt from the documentation:
The actual log message sent from the IOC has this format:
<iocLogPrefix><date> <time> <host> <user> <pv> <change>
On 05/09, LiangChih Chiang via Tech-talk wrote:
> How to know which CA client(IP address) modified a PV in EPICS version 3.14.
> I searched and got two methods:
> What other methods do you use or recommend?
Haven't used it myself, but there's caPutLog:
https://github.com/epics-modules/caPutLog
Lewis
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an
authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual
and not necessarily of Diamond Light Source Ltd.
Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom.
- Re: How to know which CA client(IP address) modified a PV Ralph Lange via Tech-talk
- How to know which CA client(IP address) modified a PV LiangChih Chiang via Tech-talk
- Re: How to know which CA client(IP address) modified a PV J. Lewis Muir via Tech-talk
- Re: How to know which CA client(IP address) modified a PV LiangChih Chiang via Tech-talk
- RE: How to know which CA client(IP address) modified a PV Mercado, Ronaldo (DLSLtd, RAL, LSCI) via Tech-talk
- Re: How to know which CA client(IP address) modified a PV Shen, Guobao via Tech-talk
Re: Is there an easy way to implement continuing EPICS logging while the console line is open? Maren Purves via Tech-talk
<2025>
2026
<2025>
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
