1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: How to know which CA client(IP address) modified a PV
From: "Shen, Guobao via Tech-talk" <[email protected]>
To: LiangChih Chiang <[email protected]>, "Mercado, Ronaldo (DLSLtd,RAL,LSCI)" <[email protected]>
Date: Mon, 12 May 2025 13:54:17 +0000
When using caPutLog, to avoid the info be flushed in your IOC terminal output due to its max line limit, you might want to redirect the output which you are interested into an external server, and you can always look back later.
At APS, we are using logstash to save the info we are interested in.
Guobao
From: Tech-talk <[email protected]> on behalf of LiangChih Chiang via Tech-talk <[email protected]>
Date: Sunday, May 11, 2025 at 9:30
 PM
To: Mercado, Ronaldo (DLSLtd,RAL,LSCI) <[email protected]>
Cc: [email protected] <[email protected]>
I tried caPutLog and succeeded.
Need more time to configure the access security file to restrict what to log.
I can't find the document of the pvlogging module.
Is there any?
On Fri, May 9, 2025 at 6:16 PM Mercado, Ronaldo (DLSLtd,RAL,LSCI) <[email protected]> wrote:
I have used pvlogging for this purpose.
https://github.com/DiamondLightSource/pvlogging
Ronaldo
From: Tech-talk <[email protected]> On Behalf Of LiangChih Chiang via Tech-talk
Sent: 09 May 2025 04:15
To: J. Lewis Muir <[email protected]>
Thanks.
caPutLog seems to be a satisfying solution. I will give it a try.
The log messages include host information as the following excerpt from the documentation:
    The actual log message sent from the IOC has this format:
    <iocLogPrefix><date> <time> <host> <user> <pv> <change>
On Fri, May 9, 2025 at 10:58 AM J. Lewis Muir <[email protected]> wrote:
On 05/09, LiangChih Chiang via Tech-talk wrote:
> How to know which CA client(IP address) modified a PV in EPICS version 3.14.
> I searched and got two methods:
> What other methods do you use or recommend?
Haven't used it myself, but there's caPutLog:
  https://github.com/epics-modules/caPutLog
Lewis
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd.
Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom.
Re: How to know which CA client(IP address) modified a PV LiangChih Chiang via Tech-talk
Re: How to know which CA client(IP address) modified a PV J. Lewis Muir via Tech-talk
RE: How to know which CA client(IP address) modified a PV Mercado, Ronaldo (DLSLtd, RAL, LSCI) via Tech-talk
Prev: Re: fedora 42 and makeBaseApp -t example Ralph Lange via Tech-talk
Next: Re: How to know which CA client(IP address) modified a PV LiangChih Chiang via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: RE: How to know which CA client(IP address) modified a PV Mercado, Ronaldo (DLSLtd, RAL, LSCI) via Tech-talk
