1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Would this motor record documentation be considered "current"
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Tue, 29 Apr 2025 20:05:03 +0200
On Tue, 29 Apr 2025 at 18:17, Graeme Winter via Tech-talk <[email protected]> wrote:
I’ll try following them in parallel to see if I can get an idea of where things deviate… though maybe EPICS 3 and 7 deviate little in this area?
Correct (for EPICS Base).
7 = 3 + 4
EPICS 7 = The IOC (from EPICS v3) plus PVAccess (initially called "EPICS 4")
Good luck!
~Ralph
Would this motor record documentation be considered "current" Graeme Winter via Tech-talk
RE: Would this motor record documentation be considered "current" Foster, Andrew (-,RAL,TEC) via Tech-talk
Re: Would this motor record documentation be considered "current" Graeme Winter via Tech-talk
Prev: Re: Unable to mind .lib files after successfully compiling EPICS using mingw64 Ralph Lange via Tech-talk
Next: RE: Unable to mind .lib files after successfully compiling EPICS using mingw64 Freddie Akeroyd - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: Would this motor record documentation be considered "current" Graeme Winter via Tech-talk
Next: Re: Would this motor record documentation be considered "current" Torsten Bögershausen via Tech-talk
