1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Unable to mind .lib files after successfully compiling EPICS using mingw64
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Tue, 29 Apr 2025 20:00:32 +0200
On Tue, 29 Apr 2025 at 17:56, Wang, Andrew via Tech-talk <[email protected]> wrote:
I decided to recompile EPICS by using Strawberry Perl and Visual Studio. MATLAB CA works beautifully now.
Yes, mixing C++ code generated by the two compilers (GNU / VS) does not work. (I hope this is mentioned in the doc somewhere.)
Having some VS-based Windows libraries that need to be linked against is a very common reason to use the VS compilers.
Cheers,
~Ralph
RE: Unable to mind .lib files after successfully compiling EPICS using mingw64 Freddie Akeroyd - STFC UKRI via Tech-talk
Unable to mind .lib files after successfully compiling EPICS using mingw64 Wang, Andrew via Tech-talk
Re: Unable to mind .lib files after successfully compiling EPICS using mingw64 Mark Rivers via Tech-talk
RE: Unable to mind .lib files after successfully compiling EPICS using mingw64 Wang, Andrew via Tech-talk
Re: Unable to mind .lib files after successfully compiling EPICS using mingw64 Wang, Andrew via Tech-talk
Prev: Re: Would this motor record documentation be considered "current" Graeme Winter via Tech-talk
Next: Re: Would this motor record documentation be considered "current" Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: Unable to mind .lib files after successfully compiling EPICS using mingw64 Wang, Andrew via Tech-talk
Next: RE: Unable to mind .lib files after successfully compiling EPICS using mingw64 Freddie Akeroyd - STFC UKRI via Tech-talk
