1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Would this motor record documentation be considered "current"
From: Torsten Bögershausen via Tech-talk <[email protected]>
To: "Paduan Donadio, Marcio" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 30 Apr 2025 20:52:42 +0200
The motor module itself has a docs/ directory
(which is worth reading, I think)
In this file:
<https://urldefense.us/v3/__https://github.com/epics-modules/motor/blob/master/docs/motorDeviceDriver.html__;!!G_uCfscf7eWS!ccGdcfT2hS1jAttRXBrG0WuW8l2lNuWdNMgtobqvEK0VwxKnIdy-B7s94AES-BX1voCIrCZM2HTrTTSzPFY$ >
We can read:
<https://urldefense.us/v3/__https://htmlpreview.github.io/?https:**Agithub.com*epics-modules*motor*blob*master*docs*motorDeviceDriver.html__;Ly8vLy8vLy8!!G_uCfscf7eWS!ccGdcfT2hS1jAttRXBrG0WuW8l2lNuWdNMgtobqvEK0VwxKnIdy-B7s94AES-BX1voCIrCZM2HTrSnEF_Qc$ >
The ACS MCB-4B is the simplest Model 3 driver,
consisting of only 336 lines of well-commented C++ code (ACSSrc/MCB4BDriver.h and MCB4BDriver.cpp). It does not implement any controller-specific features, it only implements support for standard motor record features.
Does this help ?
Please don't hesitate to ask.
/Torsten
On 2025-04-30 20:25, Paduan Donadio, Marcio via Tech-talk wrote:
Hello!
Is there a good document explaining how to develop a model 3 device support for motors?
Thank you,
Márcio
*From:* Tech-talk <[email protected]> on behalf of Torsten Bögershausen via Tech-talk <[email protected]>
*Sent:* Wednesday, April 30, 2025 01:20
*To:* Graeme Winter <[email protected]>; Foster, Andrew (-,RAL,TEC) <[email protected]>
*Cc:* [email protected] <[email protected]>
*Subject:* Re: Would this motor record documentation be considered "current"
Now,
I would say that this document is not fully current.
- It seems to describe the model 1 driver
- It misses the model 3 driver "framework", which is what
    is used for all modern controllers.
- The Chapter 3.3 Backlash seems wrong.
I don't think that there is a difference between EPICS 3 and 7
regarding the EPICS motor module.
What information are you looking for ?
The "official" documentation is here:
<https://urldefense.us/v3/__https://github.com/epics-modules/motor/tree/ master/docs__;!!G_uCfscf7eWS!bcxx9VUxVgj00rhv7GcRujSbI- VVEzfqzYfZbdlNlgPVpX63Dmc661WHUFNZwXo52oV7GMu64E0WgVPhsPQ$ >
And then I gave some introduction here:
<https://urldefense.us/v3/__https://github.com/EPICS-motor-wg/epics-mwg- discussions/blob/master/documents/2024-04-16-MotionTraining-at-PAL/3- MotorRec2024-v4.pptx__;!!G_uCfscf7eWS!bcxx9VUxVgj00rhv7GcRujSbI- VVEzfqzYfZbdlNlgPVpX63Dmc661WHUFNZwXo52oV7GMu64E0Wcco47Ts$ >
HTH
/Torsten
On 2025-04-29 18:16, Graeme Winter via Tech-talk wrote:
Thanks Andy
Yes, I had found that one also - however that one feels much more an index of definitions than a narrative on how to get started :-)
I’ll try following them in parallel to see if I can get an idea of where things deviate… though maybe EPICS 3 and 7 deviate little in this area?
All the best Graeme
On Apr 29, 2025, at 11:13 AM, Foster, Andrew (-,RAL,TEC) <[email protected]> wrote:
Hi Graeme,
I’m not familiar with that document, I always look here:
https://urldefense.us/v3/__https://epics-modules.github.io/motor/
motorRecord.html__;!!G_uCfscf7eWS!bcxx9VUxVgj00rhv7GcRujSbI- VVEzfqzYfZbdlNlgPVpX63Dmc661WHUFNZwXo52oV7GMu64E0WYs45UsU$ <https:// urldefense.us/v3/__https://urldefense.us/v3/__https://epics-modules.github.io/motor/__;!!G_uCfscf7eWS!ccGdcfT2hS1jAttRXBrG0WuW8l2lNuWdNMgtobqvEK0VwxKnIdy-B7s94AES-BX1voCIrCZM2HTr0HYNGLM$ motorRecord.html__;!!G_uCfscf7eWS!bcxx9VUxVgj00rhv7GcRujSbI- VVEzfqzYfZbdlNlgPVpX63Dmc661WHUFNZwXo52oV7GMu64E0WYs45UsU$>  <https://
nam12.safelinks.protection.outlook.com/?url=https%3A%2F%2Fepics- modules.github.io%2Fmotor%2FmotorRecord.html&data=05%7C02%7Cgw363%40cornell.edu%7Cd98be9eddd8b49bcda6c08dd8738d606%7C5d7e43661b9b45cf8e79b14b27df46e1%7C0%7C0%7C638815400507629612%7CUnknown%7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ%3D%3D%7C0%7C%7C%7C&sdata=xSHUzBvBgw%2BRhuRN4Bkg21wEDBnYlwKthI6w9ZZCoIg%3D&reserved=0>
Cheers, Andy
*From:*Tech-talk <[email protected] <mailto:tech-talk-
[email protected]>>*On Behalf Of*Graeme Winter via Tech-talk
*Sent:*29 April 2025 16:40
*To:*[email protected] <mailto:[email protected] <mailto:[email protected]>>
*Subject:*Would this motor record documentation be considered "current"
Good morning
Before I start committing too much of this to memory or putting it into effect, would this be considered “current”?
<image001.png>
epics-motor <https://urldefense.us/v3/__https://
nam12.safelinks.protection.outlook.com/?__;!!G_uCfscf7eWS! bcxx9VUxVgj00rhv7GcRujSbI- VVEzfqzYfZbdlNlgPVpX63Dmc661WHUFNZwXo52oV7GMu64E0W5fMXQaM$
url=https%3A%2F%2Fmdavidsaver.github.io%2Fepics-doc%2Fepics- motor.pdf&data=05%7C02%7Cgw363%40cornell.edu%7Cd98be9eddd8b49bcda6c08dd8738d606%7C5d7e43661b9b45cf8e79b14b27df46e1%7C0%7C0%7C638815400507648712%7CUnknown%7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ%3D%3D%7C0%7C%7C%7C&sdata=PsYmq0bx87OSQ9L5iTFyrxyX1wyVuatTwnj840nZAlk%3D&reserved=0> PDF Document · 178 KB <https:// nam12.safelinks.protection.outlook.com/? url=https%3A%2F%2Fmdavidsaver.github.io%2Fepics-doc%2Fepics- motor.pdf&data=05%7C02%7Cgw363%40cornell.edu%7Cd98be9eddd8b49bcda6c08dd8738d606%7C5d7e43661b9b45cf8e79b14b27df46e1%7C0%7C0%7C638815400507663645%7CUnknown%7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ%3D%3D%7C0%7C%7C%7C&sdata=%2F3Zd6m2zw%2Bsl7yqtlMxURVcU0WxsJbOefFheopU0WGY%3D&reserved=0>
I note it is from 2010, which may or may not be recent in EPICSland
Thanks and all the best Graeme
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd. Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments are free from viruses and we cannot accept liability for any damage which you may sustain as a result of software viruses which may be transmitted in or with the message. Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom.
Would this motor record documentation be considered "current" Graeme Winter via Tech-talk
RE: Would this motor record documentation be considered "current" Foster, Andrew (-,RAL,TEC) via Tech-talk
Re: Would this motor record documentation be considered "current" Graeme Winter via Tech-talk
Re: Would this motor record documentation be considered "current" Torsten Bögershausen via Tech-talk
Re: Would this motor record documentation be considered "current" Paduan Donadio, Marcio via Tech-talk
Prev: Re: Would this motor record documentation be considered "current" Paduan Donadio, Marcio via Tech-talk
Next: RE: Would this motor record documentation be considered "current" Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
