1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: Writing array data in an AreaDetector application
From: Iain Marcuson via Tech-talk <[email protected]>
To: Ralph Lange <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Thu, 1 May 2025 17:48:21 +0000
I do see a message I had overlooked before:
devAsynFloat64Array::initCommon, 13PIL1:cam1:PADDigiCorr find asynFloat64Array interface failed
I think I have the function names and signatures right, from looking at file asynPortDriver.h, if that is what you mean.
From: Tech-talk <[email protected]> On Behalf Of Ralph Lange via Tech-talk
Sent: Thursday, May 01, 2025 12:54 PM
To: EPICS Tech Talk <[email protected]>
Subject: Re: Writing array data in an AreaDetector application
Hi Iain,
Looking at the documentation [1] and your record, it all seems fine.
The waveform record type was created as an input - that's why the configuration field is INP. Unrelated to your problem.
It's most probably a code issue. Is your additional method properly declared in the class declaration, so that the default implementation of the method is overridden?
Cheers,
~Ralph
Click here to report this email as spam.
This message has been scanned for malware by Forcepoint. www.forcepoint.com
RE: Writing array data in an AreaDetector application Mark Rivers via Tech-talk
Writing array data in an AreaDetector application Iain Marcuson via Tech-talk
Re: Writing array data in an AreaDetector application Ralph Lange via Tech-talk
Prev: Re: Writing array data in an AreaDetector application Ralph Lange via Tech-talk
Next: RE: Writing array data in an AreaDetector application Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
