1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Writing array data in an AreaDetector application
From: Iain Marcuson via Tech-talk <[email protected]>
Date: Thu, 1 May 2025 16:24:04 +0000
I am attempting to add a configuration parameter to an areaDetector application.  The parameter is an array.
To implement the actual sending, I added method mmpadDetector::writeFloat64Array() to the application.
I created the waveform record
record(waveform, "$(P)$(R)PADDigiCorr")
    field(DTYP, "asynFloat64ArrayOut")
    field(INP, "@asyn($(PORT),$(ADDR),$(TIMEOUT))PADDIGICORR")
    field(FTVL, "DOUBLE")
    field(NELM, "16")
I can write to the array with caput.  However, I do not see any output from EPICS, and I have added prints to let me know I am in the writeFloat64Array() function.  I also note that waveform has no OUT field.  Does that have something to do with why the write function isn’t called?
Thank you,
Iain.
This message has been scanned for malware by Forcepoint. www.forcepoint.com
Re: Writing array data in an AreaDetector application Ralph Lange via Tech-talk
Prev: Control System Studio Original Version Startup Error Vargo, Will via Tech-talk
Next: Re: Writing array data in an AreaDetector application Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
