1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Phoebus: How to populate table widget with waveform array
From: Simon Friederich via Tech-talk <[email protected]>
Date: Tue, 6 May 2025 17:51:40 +0200
Dear EPICS community,
I have a waveform PV with 256 elements containing the following (see another topic in the tech talk from me):
U0, I0, U1, I1, U2, I2, ... , U127, I127
i.e. the measured voltage and current of a 128 channel power supply (updated every 10 seconds).
I want to display this and thought about the table widget (I've also tested the array widget, but here I'd need to be able to select even and odd numbers, which I don't know if that was possible; I don't want to place 256 text update fields).
Has anyone worked with the table widget in Phoebus before like this? I guess I'd have to work with a script here?
Best regards
Simon
Re: [EXTERNAL] Phoebus: How to populate table widget with waveform array Kasemir, Kay via Tech-talk
Prev: Re: IOC warning when connecting to 64 devices Mark Rivers via Tech-talk
Next: Re: [EXTERNAL] Phoebus: How to populate table widget with waveform array Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
