1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: IOC warning when connecting to 64 devices
To: "[email protected]" <[email protected]>, Abdalla Ahmad <[email protected]>
Date: Tue, 6 May 2025 12:44:22 +0000
Hi Abdalla,
That is a fairly common problem when a lot of records are set to SCAN=I/O Intr and all process at iocInit.
The example startup script for areaDetector IOCs has this line at the end to prevent the ring buffer overflow:
callbackSetQueueSize(5000)
From: Tech-talk <[email protected]> on behalf of Abdalla Ahmad via Tech-talk <[email protected]>
Sent: Tuesday, May 6, 2025 2:47 AM
To: [email protected] <[email protected]>
Subject: IOC warning when connecting to 64 devices
Hi
We developed an asyn port driver for a group of power supplies, 64 in total, controlled via Ethernet. When the IOC was developed to connect to all power supplies at once, I got the following warning:
callbackRequest: cbLow ring buffer full
The IOC became slow and could not handle processing some PVs at .1 second scan. I ended up splitting the main IOC into 4 IOCs each controlling 16 devices and the system is working fine. I would like to know more what causes this warning and is it possible to have 1 IOC controlling all 64 devices?
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME
IOC warning when connecting to 64 devices Abdalla Ahmad via Tech-talk
Prev: Re: pvaPy syntax Veseli, Sinisa via Tech-talk
Next: Phoebus: How to populate table widget with waveform array Simon Friederich via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: IOC warning when connecting to 64 devices Ralph Lange via Tech-talk
