1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Area Detector manta camera communication issue
From: "Cobb, Tom \(DLSLtd,RAL,LSCI\) via Tech-talk" <[email protected]>
To: Matt Shaw - STFC UKRI <[email protected]>, "Jemian, Peter R" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 14 May 2025 12:29:52 +0000
Interesting, maybe the firmware got corrupted... Maybe updating the firmware (or reloading the same firmware) would fix it?
Tom
Sent: 14 May 2025 12:59
To: Jemian, Peter R <[email protected]>; Cobb, Tom (DLSLtd,RAL,LSCI) <[email protected]>; [email protected] <[email protected]>
Subject: RE: Area Detector manta camera communication issue
You don't often get email from [email protected]. Learn why this is important
Hi Pete,
If I run xmllint on the file I get my xml I get an encoder error
parser error : Input is not proper UTF-8, indicate encoding !
Bytes: 0xEF 0x61 0x64 0x3C
  <pInvalidator>UserSetLad</pInvalidator>
I would expect the to be an o
But if I grep my xml I don’t see that
Cheers,
Matt
Sent: 14 May 2025 12:48
To: Cobb, Tom (DLSLtd,RAL,LSCI) <[email protected]>; [email protected]; Shaw, Matt (STFC,DL,TECH) <[email protected]>
Can you syntax check that XML file using xmllint?
  -  Pete
From: Tech-talk <[email protected]> on behalf of Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk <[email protected]>
Sent: Wednesday, May 14, 2025 6:23:09 AM
To: [email protected] <[email protected]>; Matt Shaw - STFC UKRI <[email protected]>
Hi Matt,
Does downloading the genicam XML (as specified on https://areadetector.github.io/areaDetector/ADGenICam/ADGenICam.html#downloading-the-xml-file) work? If so, what does the encoding on the XML file look like?
Tom
From: Tech-talk <[email protected]> on behalf of Matt Shaw - STFC UKRI via Tech-talk <[email protected]>
Sent: 14 May 2025 11:55
Subject: Area Detector manta camera communication issue
I’m having an issue with connecting to certain manta cameras (G-235B & G-319B)
The cameras are pingable from my ioc, and I can see them via arv-tool-0.8, but when I try to connect via the IOC I get the following
aravisConfig("CAM08", "xxx.xxx.xxx.xxx", 0, 0, 0)
ADAravis: Looking for camera xxx.xxx.xxx.xxx...
(process:3830): XML-CRITICAL **: 11:09:34.977: Input is not proper UTF-8, indicate encoding !
ADAravis: Your tick frequency is 1000000000
So your timestamp resolution is 1.000000 ns
2025/05/14 11:09:34.984 ADAravis:makeStreamObject: Making stream failed, err=No stream channel found, retrying in 5s...
(process:3830): XML-CRITICAL **: 11:09:40.352: Input is not proper UTF-8, indicate encoding !
(process:3830): GLib-WARNING **: 11:09:40.356: GError set over the top of a previous GError or uninitialized memory.
This indicates a bug in someone's code. You must ensure an error is NULL before it's set.
The overwriting error message was: No stream channel found
2025/05/14 11:09:40.357 ADAravis:makeStreamObject: Making stream failed, err=No stream channel found
If I try to pull info from the camera via arv-tool-0.8 I get a similar response:
~]$ arv-tool-0.8 -a 192.168.1.147
(arv-tool-0.8:5000): XML-CRITICAL **: 11:37:59.483: Input is not proper UTF-8, indicate encoding !
I assume that this is an issue with the XML coming from the camera in the wrong format / missing some data, but I can’t find reference to this “XML-CRITICAL”
Has anyone experienced this behaviour before and been able to fix?
Thank you in advance
Matt Shaw
(Daresbury Lab)
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd.
Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom.
Re: Area Detector manta camera communication issue Pratt, Linda (DLSLtd, RAL, LSCI) via Tech-talk
Area Detector manta camera communication issue Matt Shaw - STFC UKRI via Tech-talk
Re: Area Detector manta camera communication issue Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Re: Area Detector manta camera communication issue Jemian, Peter R via Tech-talk
RE: Area Detector manta camera communication issue Matt Shaw - STFC UKRI via Tech-talk
Prev: RE: Area Detector manta camera communication issue Matt Shaw - STFC UKRI via Tech-talk
Next: Problems GHA building motor, asyn rpc/rpc.h Torsten Bögershausen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Next: Re: Area Detector manta camera communication issue Pratt, Linda (DLSLtd, RAL, LSCI) via Tech-talk
