1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Problems GHA building motor, asyn rpc/rpc.h
From: Torsten Bögershausen via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 14 May 2025 15:26:20 +0200
Hej experts,
I have problems building motor on github.
After ubuntu 20.04 has disappeared as the runner,
I failed to update the motor into a compiling version:
<https://urldefense.us/v3/__https://github.com/EuropeanSpallationSource/motor/tree/torsten/250514-1219-gha__;!!G_uCfscf7eWS!eVFsDhMZM-fgVpTrZgK6KZI5rMaIDchTwHAFpb6z2Vr8nQuov0uii8Xnx6GOMFmKyd118nlfdQHmgZ2W5yU$ >
It seems as if libtirpc-dev is installed, but asyn fails to compile.
Trying to steal the files from asyn itself, I got stuck:
2025-05-14T10:23:32.6837566Z Unpacking libreadline-dev:amd64 (8.2-4build1) ...
2025-05-14T10:23:32.7094526Z Selecting previously unselected package re2c.
2025-05-14T10:23:32.7236379Z Preparing to unpack .../re2c_3.1-1build1_amd64.deb ...
2025-05-14T10:23:32.7246450Z Unpacking re2c (3.1-1build1) ...
2025-05-14T10:23:32.7868656Z Selecting previously unselected package libtirpc-dev:amd64. 2025-05-14T10:23:32.8009333Z Preparing to unpack .../libtirpc-dev_1.3.4+ds-1.1build1_amd64.deb ... 2025-05-14T10:23:32.8028953Z Unpacking libtirpc-dev:amd64 (1.3.4+ds-1.1build1) ... 2025-05-14T10:23:32.8552566Z Setting up libreadline-dev:amd64 (8.2-4build1) ... 2025-05-14T10:23:32.8574588Z Setting up libtirpc-dev:amd64 (1.3.4+ds-1.1build1) ...
2025-05-14T10:23:32.8603412Z Setting up re2c (3.1-1build1) ...
2025-05-14T10:23:32.8625881Z Processing triggers for man-db (2.12.0-4build2) ... 2025-05-14T10:23:37.8752531Z Processing triggers for install-info (7.1-3build2) ...
2025-05-14T10:29:43.7020563Z In file included from vxi11core_xdr.c:6:
2025-05-14T10:29:43.7021891Z ./vxi11core.h:9:10: fatal error: 'rpc/rpc.h' file not found
Any help is appreciated (Ralph ?)
/Torsten
<https://urldefense.us/v3/__https://github.com/EuropeanSpallationSource/motor/actions/runs/15018239784/job/42201108430__;!!G_uCfscf7eWS!eVFsDhMZM-fgVpTrZgK6KZI5rMaIDchTwHAFpb6z2Vr8nQuov0uii8Xnx6GOMFmKyd118nlfdQHmnYVjGbI$ >
Re: Problems GHA building motor, asyn rpc/rpc.h Mark Rivers via Tech-talk
Prev: Re: Area Detector manta camera communication issue Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Next: RE: [Ext]RE: Help with BiSS encoders and Galil controller Pearson, Matthew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: RE: Area Detector manta camera communication issue Matt Shaw - STFC UKRI via Tech-talk
Next: Re: Problems GHA building motor, asyn rpc/rpc.h Mark Rivers via Tech-talk
