A similar problem was fixed in ADCore recently. You might want to look at that:
On May 14, 2025, at 8:26 AM, Torsten Bögershausen via Tech-talk <[email protected]> wrote:
Hej experts,
I have problems building motor on github.
After ubuntu 20.04 has disappeared as the runner,
I failed to update the motor into a compiling version:
<https://urldefense.us/v3/__https://github.com/EuropeanSpallationSource/motor/tree/torsten/250514-1219-gha__;!!G_uCfscf7eWS!eVFsDhMZM-fgVpTrZgK6KZI5rMaIDchTwHAFpb6z2Vr8nQuov0uii8Xnx6GOMFmKyd118nlfdQHmgZ2W5yU$ >
It seems as if libtirpc-dev is installed, but asyn fails to compile.
Trying to steal the files from asyn itself, I got stuck:
2025-05-14T10:23:32.6837566Z Unpacking libreadline-dev:amd64 (8.2-4build1) ...
2025-05-14T10:23:32.7094526Z Selecting previously unselected package re2c.
2025-05-14T10:23:32.7236379Z Preparing to unpack .../re2c_3.1-1build1_amd64.deb ...
2025-05-14T10:23:32.7246450Z Unpacking re2c (3.1-1build1) ...
2025-05-14T10:23:32.7868656Z Selecting previously unselected package libtirpc-dev:amd64.
2025-05-14T10:23:32.8009333Z Preparing to unpack .../libtirpc-dev_1.3.4+ds-1.1build1_amd64.deb ...
2025-05-14T10:23:32.8028953Z Unpacking libtirpc-dev:amd64 (1.3.4+ds-1.1build1) ...
2025-05-14T10:23:32.8552566Z Setting up libreadline-dev:amd64 (8.2-4build1) ...
2025-05-14T10:23:32.8574588Z Setting up libtirpc-dev:amd64 (1.3.4+ds-1.1build1) ...
2025-05-14T10:23:32.8603412Z Setting up re2c (3.1-1build1) ...
2025-05-14T10:23:32.8625881Z Processing triggers for man-db (2.12.0-4build2) ...
2025-05-14T10:23:37.8752531Z Processing triggers for install-info (7.1-3build2) ...
2025-05-14T10:29:43.7020563Z In file included from vxi11core_xdr.c:6:
2025-05-14T10:29:43.7021891Z [1m./vxi11core.h:9:10: [0m[0;1;31mfatal error: [0m[1m'rpc/rpc.h' file not found[0m
Any help is appreciated (Ralph ?)
/Torsten
<https://urldefense.us/v3/__https://github.com/EuropeanSpallationSource/motor/actions/runs/15018239784/job/42201108430__;!!G_uCfscf7eWS!eVFsDhMZM-fgVpTrZgK6KZI5rMaIDchTwHAFpb6z2Vr8nQuov0uii8Xnx6GOMFmKyd118nlfdQHmnYVjGbI$ >
- Re: Problems GHA building motor, asyn rpc/rpc.h Ralph Lange via Tech-talk
- Problems GHA building motor, asyn rpc/rpc.h Torsten Bögershausen via Tech-talk
RE: [Ext]RE: Help with BiSS encoders and Galil controller Pearson, Matthew via Tech-talk
Re: [Ext]RE: Help with BiSS encoders and Galil controller Jesse Hopkins via Tech-talk
<2025>
2026
<2025>
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
