1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: Help with BiSS encoders and Galil controller
Date: Thu, 15 May 2025 12:39:52 +1000
Hi Jesse,
The steps I use to configure an axis for BISS would be:
1.  Set either reverse/forward limit according to requirements, OR
     Set the absolute encoder scale so that the direction matches requirements 2.  Set either reverse/forward limit to match encoder scale direction decided in 1 above, OR      Set absolute encoder scale to match  reverse/forward limit direction decided in 1 above. 3.  Finally set motor direction to match limits/encoder scale. Prefer using EPICS driver facilities over wiring changes.
     The motor wiring should be consistent across installations.
Kind regards,
Mark Clift.
This email has been checked for viruses by AVG antivirus software.
https://urldefense.us/v3/__http://www.avg.com__;!!G_uCfscf7eWS!bnQCpm5KzNXIIeYIZCc1QS2avSLtkFNhiyP0PD6G54_08s4KfRJJedUEzMKA5odivQ2RK2F0zDaKhZ9jfKY$
Prev: How to use Optics Slit records with absolute encoders? Jesse Hopkins via Tech-talk
Next: How to use Optics Slit records with absolute encoders? Mark via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: RE: Help with BiSS encoders and Galil controller Mark via Tech-talk
Next: Area Detector manta camera communication issue Matt Shaw - STFC UKRI via Tech-talk
