1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: camonitor the PACT field
To: "[email protected]" <[email protected]>, "Neidherr, Dennis Dr." <[email protected]>
Date: Thu, 15 May 2025 12:40:54 +0000
Hi Dennis,
The PACT field does not send monitor events, so you can read it, but not monitor it.
The old EPICS Record Reference Manual makes this clear.  Note that the Rec Proc Monitor column is No for the PACT field.
Unfortunately, the new EPICS 7 Record Reference Manual does not have a column that indicates whether fields generate monitors.
For example, in the old manual it is clear that the STAT and SEVR fields generate monitors, but in the new manual that information is missing.
From: Tech-talk <[email protected]> on behalf of Neidherr, Dennis Dr. via Tech-talk <[email protected]>
Sent: Thursday, May 15, 2025 1:43 AM
To: [email protected] <[email protected]>
Subject: camonitor the PACT field
Dear all,
I have again a small question, this time about the reading out of the PACT field:
For this test I am using a small StreamDevice record which communicates with a connected device. If I execute the processing of this record and use a python script to monitor the status of the PACT field via cagets in a loop, I receive exactly what I expected, so the value of this field changes from 0 to 1 and back to 0. But if I try this with a camonitor (or a pvmonitor) no change is recognized. This also happens in a command prompt so it is no problem of the python library I am using.
Is this a normal behavior?
Thanks in advance, Greetings
Dennis
RE: camonitor the PACT field Neidherr, Dennis Dr. via Tech-talk
Re: camonitor the PACT field Johnson, Andrew N. via Tech-talk
Prev: Re: Area Detector manta camera communication issue Pratt, Linda (DLSLtd, RAL, LSCI) via Tech-talk
Next: RE: camonitor the PACT field Neidherr, Dennis Dr. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: camonitor the PACT field Neidherr, Dennis Dr. via Tech-talk
