1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: camonitor the PACT field
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Rivers, Mark L." <[email protected]>, "[email protected]" <[email protected]>, "Neidherr, Dennis Dr." <[email protected]>
Date: Thu, 15 May 2025 20:32:42 +0000
Hi Mark,
On 5/15/25, 7:41 AM, "Mark Rivers" wrote:
The PACT field does not send monitor events, so you can read it, but not monitor it.
The old EPICS Record Reference Manual makes this clear.  Note that the Rec Proc Monitor column is No for the PACT field.
Unfortunately, the new EPICS 7 Record Reference Manual does not have a column that indicates whether fields generate monitors.
https://docs.epics-controls.org/projects/base/en/r7.0.9/dbCommonRecord.html - scan-fields
For example, in the old manual it is clear that the STAT and SEVR fields generate monitors, but in the new manual that information is missing.
(I fixed your “new” link above)
The Rec Proc Monitor column in the old Record Reference Manual was added (by hand) based on the source code of the record types at the time, and keeping the tables current with the record sources was always a problem. When we switched to creating the record type reference tables automatically from the *Record.dbd files I had to choose between removing that column completely or manually annotating all of the fields that every record’s process() routine posts monitors on inside the *Record.dbd.pod files.
Unfortunately that information can’t always be determined from the record’s source code; device support can also post monitor events, and the common fields such as PACT aren’t always documented in the individual record type so some record types could post monitors on common fields that most records don’t. If the community wants to resurrect the Rec Proc Monitor field column using manual annotations that can be done, but it would take some volunteer effort (Codeathon?) to populate all the record fields.
- Andrew
Complexity comes for free, Simplicity you have to work for.
camonitor the PACT field Neidherr, Dennis Dr. via Tech-talk
Re: camonitor the PACT field Mark Rivers via Tech-talk
Prev: Re: Modbus problem bit swap Wago PLC Brown, Garth via Tech-talk
Next: Process PINI-Record again as soon as device is reconnected Dr. Simon Friederich via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: RE: camonitor the PACT field Neidherr, Dennis Dr. via Tech-talk
Next: A $ in a PV name? Brown, Garth via Tech-talk
